HMS Triton by Jasseji - 1:64 - POB - CANCELLED
10 minutes ago, paulsutcliffe said:
I found the best way to bend small planks is to leave them a lot longer ie twice as long, bend carefully with heat and then use the piece in the middle where you have the correct curve that you need
Regards
Paul
yes, it's a learning curve ;)
Jacek
Current Build: HMS Sphinx 1775 - Vanguard Models 1/64
On Hold/Parallel: Lady Nelson - Amati/Victory Models 1/64
Link to comment
Share on other sites
Hello, i am taking a short break due to other Hobbies and Commitments, also i am waiting for the "AOTS Book: Pandora" so i can redesign the Stern Galleries (i have to sit in AutoCAD and redraw some parts for laser-cutting and hoping the Pandora Drawings will give some inspiration)
Jacek
Link to comment
  • 1 year later...
For all asking: Due to unrecoverable damage to the bulkheads and planking (massive encounter with the Admiral's cat) this build will not be continued.
I was considering redoing the damaged bulkheads but the false keel was cracked also the planking work i done (no further pics, sorry) i have decides to scrap this and rather do something else after i set up a Workshop in our new Home (Cat-Free Workshop :P)
Mods can lock or delete this topic
Edited by Jasseji
Jacek
Link to comment
