Black Pearl by Old Collingwood - FINISHED - 1/72 Scale
Link to comment
Share on other sites
7 minutes ago, CDW said:
Interesting. So, are you just slipping the spar into the curved underside of the blade then letting the tool carve the spar as you draw it across the spar?
I have one of those tools but never considered using it for anything but plastic scribing.
I used it already on the dowels I put inside the masts (to strengthen them)   yep  - just a case of scraping using the curved insode section of the blade, Its very sharp and did a great job,   the idea is to do the same after making on the dowel each end where to start tapering it.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Gidday OC.
I've been away from the site for a little while.
I missed the whole "Scratched Lens" incident.
I am glad you found a resolution. Kudos to the members on this site.
Very interesting scraper you have there.
Wishing you and your family all the best.
Mark.
Link to comment
5 minutes ago, pontiachedmark said:
Gidday OC.
Mark.
Thank you mark.
OC.
Current builds
Completed works.
Link to comment
sorry I got to the fiasco late........not that I had an idea to add.   having an automotive background,  there is a product out there that is used to buff headlight lenses.   clear finger nail polish,  I believe,  is another old remedy.  ship doesn't look the worse for wear .........your still doing a stellar job!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
7 hours ago, Wallace said:
I too am happy that you got that cleared up (forgive the pun) OC.
Thank you wallace.
OC.
Current builds
Completed works.
Link to comment
Thank you denis    "I can see clearly now  - the glass I s clear"   sorry about that🤣
OC.
Current builds
Completed works.
Link to comment
Evening all,    firstly sincere thanks to all the likes/followers and comments   -  so onwards and upwards with the ratlines on the foremast,   I decided to fit them by eyeball  rather than making a paper mask,  seems straight forward enough  - just tricky as you need six pairs of hands  to tie/ tention and glue the lines around each shroud,   getting the spacing is fairly easy to do though  - I have been rotating from side to side.
Just a few pics.
OC.
Current builds
Completed works.
Link to comment
46 minutes ago, CDW said:
Ratlines look fantastic! If I were a sculptor, would sculpt some skeleton pirates to pose as climbing the ratlines....holding daggers with their teeth. 🙂
Thanks mate,   Im still on the look out for pirates  - will get some.:dancetl6:
OC.
Current builds
Completed works.
Link to comment
18 minutes ago, Wallace said:
You did a very good job considering you did this by eye O.C. Hats off to you sir.
Thank you wallace.
OC.
Current builds
Completed works.
Link to comment
these are from the warhammer range, which i think work out at about 1/64 scale
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Link to comment
So  - more ratlines to be done tomorrow  then they will need a tidy up of thier ends,    one thing did happen while I was working on them  - I managed to break off the topgallant where it meets the topmast 🤧I was able to keep it in place due to the stays  -  I put loads of ca around the break  and that seems to have done the trick........"Phewww.....🤞"
OC.
Current builds
Completed works.
Link to comment
Here are a few more in the same series as CDW posted on.
https://www.toysoldiersdepot.com/store.php?seller=thedustyloft&Tsearch=1/72 pirates&per=6&pd=8245937&num=
https://www.toysoldiersdepot.com/store.php?seller=thedustyloft&Tsearch=1/72 pirates&per=6&pd=8245854&num=6
All in 1/72, you could mix and match the normal guys and the zombie guys. For that matter you could add the Warhammer figures Carl shows and make it a really mixed crew.
Did you paint those figured Carl? They were really well done. I did some similar figures when the kids were into board games about 1.5 million years ago and I don't think any of them were as nice as that set.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Yep  I have those saved  from a UK seller  - they look not bad at all.
OC.
Current builds
Completed works.
Link to comment
7 hours ago, pontiachedmark said:
Gidday OC.
Looking good
Pity about the Topgallant.
As long as we learn something from our mistakes it is not a complete waste of time.
I wish you and your family all the best.
Mark.
Thank you mark.
OC.
Current builds
Completed works.
Link to comment
Evening all  I decided today to re - do the bobstay on the bowsprit  as the original was not tidy  - so I cut away the old a re fitted some fresh ropes and blocks, then I tentioned them correctly  - at the same time I fitted a fresh stay  from the center of the bowsprit underneath and fitted around the forecastle railng.
Looks a bit more supported now.
Heres the pics  -
OC.
Current builds
Completed works.
Link to comment
Looking good OC.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
1 hour ago, Piet said:
Looking good OC.
Cheers,
Thank you Piet.
OC.
Current builds
Completed works.
Link to comment
Evening all,   I have completed attaching the two topgallant post tention  ropes, down on to the two deadeyes  -  this means the foremast/bowsprit is now fully tentioned to each other,    while I was in the mood I decided to give the whole ship several clear matt coats, to flatten everything down as the paintwork still had a bit of a sheen to her.
Just the one (poor)  photo.
OC.
Current builds
Completed works.
Link to comment
Still has a bit of a way to go yet till I get her completely flat  - its seems to be taking several coats,   yet still some of the areas are still  what I would call  a satin finish.
OC.
Current builds
Completed works.
Link to comment
Right then folks  - I have finished the ratlines on the lower foremast shrouds   "Phewwwwww:dancetl6:
OC.
Current builds
Completed works.
Link to comment
3 hours ago, Wallace said:
Nice job on those ratlines OC and it is really evident how much of the "glossiness" that matt coating has removed. She's looking good sir.
Thank you wallace.
OC.
Current builds
Completed works.
Link to comment
Evenng all,   more work on the foremast  - I completed the futtock shrouds,   then started work on the upper mast shrouds  - so far two completed on the one side.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
