Kevin
St Nectan by Kevin - Mountfleet Models - 1/32 - Steam Trawler
Good evening everyone
so the first list of DIY must do's are out of the way, now I am allowed to play for a few days
The living room has been the last room to be done in our revamp of our home, but this had some paint, curtains and new wallpaper as well
from this, time to get rid of the purple
IMG_5769.thumb.JPG.739909d095fac549542178a8ca37386c.JPGIMG_5772.thumb.JPG.c92233f79aa0ea39bc684c5d4944a8be.JPGIMG_5812.thumb.JPG.f17539195d1533b8695418c58937e8fc.JPG
to this
Edited by Kevin
Share this post
Link to post
Share on other sites
now that i have two life boats that look about the same, i have started to rig them to the boat, intentions are to get them completed by tomorrow night, and move on to other items on the boat deck
IMG_5806.thumb.JPG.76a37bdc04bdc43527e254993a003800.JPGIMG_5822.thumb.JPG.7affeaacf3385b41333c991fe0adfc84.JPGIMG_5823.thumb.JPG.454f9893c0d7382ac5e2a0f9ee130c64.JPGIMG_5824.thumb.JPG.8efafe7ebceb8186df7d0f4eebeb8b2c.JPGIMG_5825.thumb.JPG.dab47a40b077fa148a643bc22266287f.JPG
two questions are bugging me
the shrouds on these trawlers were they wire or rope?
when a rope or wire comes of a drum to a rig, in this case a davit, does the leading edge of the line come off the top of the drum or from the bottom of the drum
Edited by Kevin
Share this post
Link to post
The boats turned out extremely nice Kevin.  I especially like the wrinkles and creases in the fabric covers.
I would say the shrouds are steel cables.  I scratch built a 1941 sardine carrier (70 ft LOA) and plans of the vessel called for 1/2” steel cable for the shrouds.  That boat is about the same era as your trawler - so perhaps . . .
I can’t say for certain about the davit winches, but every trawl winch or mine hoist or tugger I have ever seen winds/unwinds off the top of the drum, as in the first of your two illustrations.
Keep up the great work.
Gary
Share this post
Link to post
the boats look great with the canvas Kevin.......you got me thinking of the ropes as well.  you have to look at it from a functional point of view.   leading out from the bottom,  are they going to rub on anything when in operation.  would they rub on the deck?  leading out from the top is what I usually do...a lot less apts of rubbing,  and the detail is more pronounce.   your structure work is top notch.......looks awesome!
Share this post
Link to post
thank you, i was thinking more of the trip hazard side of things, but using google today it  appears  they do lead from the top
Share this post
Link to post
Good morning everyone
apart from the handling ropes the life boats are finished,
i put everything in place according to the plans, and secured in position, however the forward drum reels are set  to far aft to be of use, it looked tight even on the plans, after looking at other builds and seeing the same issue they got moved about 1cm to make them more usable, i may have to move the after hatches now as they might not have enough room
IMG_5831.thumb.JPG.317145c71f179aa2e83155759e486533.JPGIMG_5832.thumb.JPG.ea18c793508215312c1a3c3568312556.JPGIMG_5833.thumb.JPG.b5202c77a41bd50d8477645e973918e0.JPGIMG_5834.thumb.JPG.f4f04b82398aead2f39fb219378645ff.JPGIMG_5835.thumb.JPG.fd56a02184bdaae07205bcecd9409041.JPGIMG_5836.thumb.JPG.275ecf669e9a2a95bd378af0a7f3ab8a.JPG
the middle picture drum reels are in place according to the plans, but in reality are to far aft to be of use
IMG_5841.thumb.JPG.f61f2c4fc0a5857c17f579c02eedf600.JPGIMG_5844.thumb.JPG.ef308f8d7feedf98a46129f261ebab4f.JPGIMG_5845.thumb.JPG.47293648cb736fbc51f8c190cc293ca5.JPGIMG_5846.thumb.JPG.71180bcd2cc7467a298395225682676c.JPGIMG_5847.thumb.JPG.f164a5d7c88a17067d046792ace8c36a.JPG
reels after being moved, dont quite know what to do about the stain damage on the wood
IMG_5848.thumb.JPG.47f1b1fa0ec2000395beaec1b0ecc227.JPGIMG_5849.thumb.JPG.aaa21679da97a3fe93327c37c4bd24dd.JPGIMG_5850.thumb.JPG.5191321861b365172f4667eccad44a30.JPGIMG_5851.thumb.JPG.a6e5835676a896d798a0b0e985fb4bb3.JPGIMG_5852.thumb.JPG.e841a06f97a6008d0ddf4fe3e79a808e.JPG
Share this post
Link to post
not progressed much at all since the last update, lol i dont think im confused so much now,
the main mast is supported by stays, but very few is any show any ratlines,
the instructions do say that the shrouds can be adapted to enable the mast to be removed for transportation purposes, so from that i presume from that no one went to the trouble, even though the superstructure is removable
mine will have ratlines, again the instructions call out for wire to make them, is this right?
Share this post
Link to post
you can.........not sure when the change occurred,  but most if not all steel hulled vessels had steel cables for the shrouds and back stays.  the turn buckles your using replaced the dead eyes that would have made up the early shroud adjustment lanyards.  you would have to research the vessel more to find out what was used.  on these vessels,  the ratlines are usually a single rung using two shroud lines.......the rest are back stays.   your life boat assembly looks awesome........love the way you rigged them up :)
Share this post
Link to post
If turnbuckles were used, the stays and shrouds connected to them would certainly be wire cable. The wire cable would be spliced around a solid wire thimble with a hole in the center through which the turnbuckle pin would be fastened. Alternately, the wire cable would have a "poured socket" terminal attached which would match the connection to the turnbuckle. (tongue to fork, pin through hole, etc."
These poured terminals would have the wire cable run through them and the wire cable unlaid (this unlaid end was then called the "broom.") Molten zinc, or modernly, epoxy, was then poured into the terminal and, when hardened, would lock the terminal to the cable.
These sockets are rather easily made to modeling scale from short lengths of copper tubing filed to shape at the terminal end and filed to a taper at the "neck." These scale terminals can be fastened to the cable the same way the real ones are. Just run the cable through the center of the terminal, unlay a bit of the end of the cable and then pull that down into the socket, and fill the socket with a bit of silver solder, CA adhesive, or epoxy.
Types of patent poured socket terminals:
Edited by Bob Cleek
Share this post
Link to post
good morning everyone
thank you for the comments
there is a deadeye arrangement set up for the fore mast and these turnbuckles for the after one, again i presume that it is a mixture to allow removing the mast for transport to shows and ponds
so on the main mast there are 3 shrouds and the back stays, i dont have are wire that would pass the test, could a silver stained rope representing wire pass?
the fore mast is going to be a while away
if i get something that resembles the wire i could ten use them as ratlines, but will not get the tautness, so maybe a single wire would work, go go to wooden battens
lol any suggestions?
this is Mountfleets show kit
Edited by Kevin
Share this post
Link to post
i had a light bulb moment, but it dont work
i stripped back some wire, and twisted the strands, but unless i make new adjustable turnbuckles, i am unable to get a decent tension, so it is try again
Share this post
Link to post
Kevin,
How about soaking the ropes in warm water for a little while, placing them under tension to the best of your abilities and then let them dry. A dry rope is always shorter than a wet rope.
Old barometric devices were based on that principle.
Yves
Share this post
Link to post
31 minutes ago, yvesvidal said:
Kevin,
Yves
im trying to replicate wire rope by using it, but the mast is very flexible, as i replaced it from wood to plastic tubing so as to run electrics through it, so it is very difficult to get any decent tension on it
the rope is fine, but i want it to look like wire
Share this post
Link to post
Thank you for like and comments
there was certainly far more reference material for the Victory, there are tons lots of phots of trawlers but they lack any detail, but i try to proceed onwards
the shrouds, certainly appear to be wire on the after ones hence the turnbuckels so i have been playing with thread and various colours of grey and silver, the one in the final shot is a warhammer silver and will see how this goes
next will be ratlines, i am still undecided if i should  go with wooden slats or wire, or the same as the shrouds
IMG_5859.thumb.JPG.979e3a60016f0022acbb9e56fe003186.JPGIMG_5860.thumb.JPG.f156a270cedaa2bdc1de3f220247d996.JPGIMG_5861.thumb.JPG.ff462b07f7c2a2d6950ba518d7bcd51e.JPGIMG_5862.thumb.JPG.ce9d159cce3238775f0266362ce2e6a7.JPGIMG_5863.thumb.JPG.c2e321262102ecc9bf094c1658c153fb.JPGIMG_5864.thumb.JPG.e9c0780ab3450647ca043133998ab5c8.JPGIMG_5865.thumb.JPG.e37f204b58f07201c13c15312a7816d9.JPG
Share this post
Link to post
Kevin, I'm a bit late on this discussion, but steel wire rope was usually a very dark grey unless very new.  That might give you a few more options.  I would suggest that a trawler of your model's age would have shroud eyes spliced around thimbles - easily done by the crew.
John
Share this post
Link to post
John
i wonder how Mountfleet got this wrong, and have these aft and deadeyes fwd
Share this post
Link to post
3 minutes ago, mtaylor said:
Hmm... just curious, Kevin.   Regarding the tensioning... do the turnbuckles actually work?
no Mark, just 1 piece white metal
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
