St Nectan by Kevin - FINISHED - Mountfleet Models - 1/32 - Steam Trawler - Completed June 2020
good evening everyone
Fish Hatches
well back to the pointy end, and the fish hatches Balsa wood,  sprayed back and dry-brushed to tone it all down,
Edited by Kevin
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Share on other sites
me again
thats the hatch covers nearly completed, just a bit more dry-brushing
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Fish Ponds
well that took a lot longer than anticipated, about 150 cuts of strip wood, took me most of the day, but for now it looks ok.
I still gave to adapt the bottom board to sit tight to the deck, and then see if i can simulate handles, or cut slots out to enable lifting, and then weather, and put back into the same position they were removed from, Real world DIY tomorrow so hopefully by the weekend
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Looking good Kevin   each part you do is adding to her.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
the fish pond slats have still to be stained, but the gutter boards are now fitted and for the photo i have just placed the bits and pieces in roughly where they are to be fitted, bu at present i am missing a piece the seals the stbd bulkhead under the waleback, which is a real pain as i have been looking for a week now
i cannot remember what these are
IMG_6314.thumb.JPG.8801d7569c9b6a78f820817675be56c1.JPGIMG_6313.thumb.JPG.5c5ab94f604fc034fdcdd53e3facdef4.JPG
and this was made up
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Good morning everyone
i was reading my own log last night, and i said i would open her up, somehow along the way I seam to have forgotten about it, is it time to rethink the idea, or just go for it?
NOT MY PHOTO, not even my build
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Well, that is an enormous amount of work in addition to finishing up the outside of your model. Then, how will a visible see-thru hull will fit with your diorama?
Yves
Link to comment
CUT AWAY ABANDONED
Been away a couple of days, and LOL not because i was sulking, but been planning more on how to display this monster when completed
these were the photos that convinced myself that at this stage the cutaway was not going to work,  the boiler is scaled down by about 10 to 15% and the damage required to fit is not worth the trouble. therefore i have finally abandoned the idea, the diorama gets the proper go ahead
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
yea....a dio like that should be done from the ground up  ;)    you've made some super progress Kev.......it's nice to see the hull painted finally  :)   the main deck is filling out nicely!   are you going to have supports for the aft deck?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
yes, each one is slightly different, so they are made up, ready to be painted
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
I think Popeye's right, Kevin.  A cutaway model needs to be planned from the ground up.
Perhaps for your next model you could build something like this model of M.V. 'Kingsville'.  :D The model is (or was) on display in the Norwegian Maritime Museum.
John
Link to comment
John
Good morning John, i have seen this photo before, gave me some great ideas last time i saw it
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Good evening everyone
lots i dont understand about this build, there is so much more that could have been put down in the instructions, the forward gallows need to set so that the centre is above the middle of the rubbing bars, but they are not in the same position both sides so i have put them in place identical both sides, so yet another compromise, same goes for the position of the fish pond stations, they had to be re positioned tonight annoying as i had them all ready to be fitted
oh hum, other than that loving this build, tomorrow i want to sort the ladder to the wale deck and get the mast fitted
IMG_6385.thumb.JPG.fabc30b62e16af0abe75a7ad9beb9267.JPGIMG_6384.thumb.JPG.3cd9db78d77013ef5f114631785fb4ef.JPGIMG_6387.thumb.JPG.aa1971ee48123221bb4630cfb4f0fd3e.JPGIMG_6388.thumb.JPG.a3def7f803de716d06e00b7573c33582.JPGIMG_6389.thumb.JPG.3380a53348b31ac1386c4cba1bfc90f2.JPG
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
i see the light at the end of the tunnel, its getting brighter, and no its not a train in the opposite direction
having spent ages messing around i decided to ensure the mast lights still worked, and they did, how ever, i am unsure of the lens colours to use, as i believe they were changeable, i have also get to sort out the night photos properly to show them off better
the ladder to the wale-back is now in place as are the braces to support the fwd gallows ,
IMG_6403.thumb.JPG.ca838c04fb1daffaa6ace918e1474279.JPGIMG_6404.thumb.JPG.d016524d96c19d635de30954fee8fb9a.JPGIMG_6405.thumb.JPG.6eb0d4cf605d6f56da090e4595f517bd.JPGIMG_6406.thumb.JPG.f2ca9498c2f874c0350ac3072112c5c6.JPGIMG_6407.thumb.JPG.f0777c8ebacadd51be9d7684cbf41be8.JPG
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
is that the proper rake for the mast?   I see you have it shimmed.   if not,  then perhaps adjusting the length of those two braces for the gallows will allow the mast collar to sit flush.   if the rake is correct,  and seeing that adjusting the collar itself looks impossible,  perhaps closing up the three sides will enable it to appear flush with the deck.   your progress continues to look really good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hi Kevin, nice job!
Regarding your lights, the following was copied from the International Regulations for the Prevention of Collisions at Sea:
Rule 26
Fishing Vessels
  • (a)
    A vessel engaged in fishing, whether underway or at anchor, shall exhibit only the lights and shapes prescribed in this Rule.
  • (b)
    A vessel when engaged in trawling, by which is meant the dragging through the water of a dredge net or other apparatus used as a fishing appliance, shall exhibit:
    • (i) two all-round lights in a vertical line, the upper being green and the lower white, or a shape consisting of two cones with their apexes together in a vertical line one above the other,
    • (ii) a masthead light abaft of and higher than the all-round green light; a vessel of less than 50 metres in length shall not be obliged to exhibit such a light but may do so,
    • (iii) when making way through the water, in addition to the lights prescribed in this paragraph, sidelights and a sternlight.
Hope that helps!
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Link to comment
thank you Andy, lovely to hear from you, are you and family ok?
being set in a diorama i wont need lights, other than to show they work for pre sea checks, but i could at least get the lens covers colour correct
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
no its not the correct rake, i have just been doen stairs and put it on the display shelf, and it is raked to far back, i thought it was about rightin comparison with photo and the after mast, which is about right, the angle i took is not correct, so tomorrow i will remove some of the chim and make it look better,
the rake to be set  is not in the instructions
here is what it should be like NOT MY PHOTO
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
it hardly ever is Kevin.......just one {kinda} important bit of detail they seem to leave out ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
from the previous photo's you can see a wedge under the mast , this was not required
this angle was to much so today i sorted it  out, what happened was, i required a shim to fit the main mast, as per the instructions, and did the same for the foremast, not thinking that the deck was already providing the required angle, wedge removed, two part epoxy and pins made it more hard work than was needed, im happier now its now fixed back in place
another fix sorted
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Looking great Kevin.  That model in the lake looks fantastic - your model is right there with it!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
thank you Mike
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Waleback fitting out
getting the pointy end over the finishing line, the  railings are still to be trimmed to size, nothing is fitted yet, i may use this area as a dumping fround when in the diorama setting, boxes, bikes, ropes, lol my mind runs riot with ideas, actually doing it is a different thing altogether
my next build will be the Talisman Paddle steamer in cutaway, having failed to do it on here as promised
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Hello Kevin, I've just trawled through your log and you've done a beautiful job with her!(no pun intended). Can I ask where the diorama log is?
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you Edward, although very much in the early days, and im not racing ahead with it, but the log is ni my signature list below
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Very fine work Kevein, those railings look like a real pain in the ......
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
