Cruiser Varyag 1901 by Valeriy V - FINISHED - scale 1:75
5 hours ago, yvesvidal said:
Valeriy,
You are not painting the hull before gluing the deck planks? It seems to me that it is going to be a daunting task to mask all the decks.
Yves
Yves,
Protecting the wooden deck during painting makes the whole process a little more difficult. But this is order.
 Before painting the hull it is necessary to install all the metalwork and for this you must first lay the deck boards.
Link to comment
Share on other sites
Valeriy -  I use black card / paper between deck planks to simulate caulking. I have found that the paper needs to be good quality and not fibrous. If it is fibrous the sanding dust tends to bed itself in the planks leaving them looking quite dirty - this is OK if you want a weathered look but otherwise much better to use top quality paper.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Keith, in order to protect myself from mistakes on the model, I try to always conduct an experiment with the material.
This black paper passed the exam! :)
Link to comment
7 hours ago, wefalck said:
I am applying a sanding filler before anything else. This stabilises the paper and sort of turns it into a compound material. The filler also prevents 'dirt' from getting into the wood pores.
Eberhard, could you explain in more detail about the sanding filler?
Perhaps the translator is incorrect.
Link to comment
Valery, this is just some sort of nitrocellulose laquer filled e.g. with very fine pumice powder. It is used as a primer on wood, to fill the pores. On decks and surfaces that will be matte, depending on the wood, often one coat is sufficient. It sands well and I finish with fine steel-wool.
Link to comment
lost track of your wonderful project........your metal work is awesome :)    great looking deck as well!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Wonderful and masterfully done.
Rob
Current build:
Finished build:
Current build(On hold):
Link to comment
Valeriy, you have done a great job on the deck.
michael
Link to comment
Very smart decking Valeriy.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
So you're saying the black caulking is black paper?  Then cut strips similar to your planks and lay them between the planks...then sand it all even....that's brilliant and time consuming for sure...especially when adding end seams as well as length seams.
Wonderfully done.
Rob
Edited by rwiederrich
Current build:
Finished build:
Link to comment
Wonderfully done.
Rob
Thanks, Rob!  :)
Yes,  this is black paper. At the beginning of the paper is glued to the wooden plank and then it is glued to the deck. I agree that this is a time-consuming operation, but over time comes the experience and speed of installation of boards increases. The longer the board, the less effort it requires.
Link to comment
Just amazing metal work........
Rob
Current build:
Finished build:
Link to comment
I second that.
Edited by GrandpaPhil
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Magic'!!!!!!!!!!!!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Colleagues, thank you for your feedbacks!  :)
16 hours ago, druxey said:
Are you also a watchmaker? That is extremely fine work.
No,  I'm not a watchmaker. I have an easy scale, only 1/75.
And watchmakers jeweler work on a smaller scale 1/160.  ;)
Link to comment
Valeriy,
Beautiful work! I love working with brass and solder, and you are doing an excellent job!
Commercial sanding sealers typically are clear paint with a fine powder - like talc - mixed in to fill in the pores in the wood. However, the white talcum powder can make the wood a lighter color. If the wood is to be painted with an opaque color this isn't a problem, but for "bright" or unpainted wood, like decks, it can create an unnatural look.
You can also mix very fine wood dust from sanding into clear paint and use it to seal the wooden decks. Then after sanding and finishing with fine steel wool the wood retains a natural color. If the deck planks are fine grained you can just use clear paint without a filler.
Edited by Dr PR
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
