Cruiser Varyag 1901 by Valeriy V - FINISHED - scale 1:75
Very clean work Valeriy, I wonder how you keep the soldering so neat?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Share on other sites
Valeriy, beautiful workmanship on the rail assembly. Have you been using heat sinks or different temp solders for the sequencing of the assembly? I understand the small tip in order to transfer heat to a small area if the soldering iron is of a high enough wattage, but will so many small items so close together and the melt point of the solder having a range even a small one I am wondering about the heat transfer to previously assembles parts.
Thanks Michael
Link to comment
Thanks, Michael !
In this assembly, I did not use any heat dissipation devices. I applied a simple scheme of sequential actions - initially massive metal parts are welded together and only after that small parts are soldered. In a short time of soldering smaller parts, the remaining larger ones do not have time to heat up very much. Therefore, the parts do not fall apart from overheating.
A special role is played by the composition of the solder:  Sn - 50%   Pb - 32%   Cd - 18%
This solder spreads very quickly in the right direction and this nuance allows you to reduce the heating time of the surrounding parts, protecting them from overheating.
With this soldering, I mainly use a 30W and 60W soldering iron, very rarely 80W. And only the sharp tip of the soldering iron.
Link to comment
Thank you Valeriy for your explanation, I will see what is available in Canada.
Michael
Link to comment
6 minutes ago, wefalck said:
Not sure we can still get solderof this composition - the use of lead and cadmium is being phased out at least in the EU.
It doesn’t matter, you can buy such solder in Ukraine. :)
For instance   http://www.zpsplav.com.ua/pripoi/posk50-18/
Link to comment
12 hours ago, Valeriy V said:
ammunition rail and bridge for the transition are soldered together.
Lovely work Valeriy. Like others I marvel at your soldering skills.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
You have been busy modeling since your last postings in October and what beautiful modeling it is!  Your davits and rail assembly are wonderfully made - an intimidating quantity of fragile pieces to solder up.  Beautiful work Valeriy!
Gary
Edited by FriedClams
Completed Scratch Builds
Link to comment
Sweet! (Political remark here) 😉
By far the most impressive build ever.
Tony
Savannah, Georgia
Multi hobby nut.
Link to comment
2 hours ago, wefalck said:
So, how did you make the cowls ? Galvanoplastic ?
Yes, Eberhard, these parts are made using electroforming.
The wax mold is coated with a conductive layer of graphite and lowered into a galvanic bath. I already told the details in my topic above.
Link to comment
Elegant way of forming the cog-wheel and the pinion by knurling. I probably would have cut them the hard and traditional way, as watchmakers do.
I don't understand, where the drive goes to and what the lever does. Is this a double bevel-gear drive that leads then down inside the ventilator ?
Link to comment
Beautiful work as ever Valeriy.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Omg that looks awesome, Great work valeriy
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
