Cruiser Varyag 1901 by Valeriy V - FINISHED - scale 1:75
Masterful work Valeriy!  Everything fitting into place perfectly - so clean and precise.  Who knew a utilitarian metal stairway could also be an item of beauty?  Remarkable craftsmanship and the silver plating is an elegant touch.
Gary
Completed Scratch Builds
Link to comment
Share on other sites
Gary
Thanks Gary!
You are absolutely right - the method of highlighting small details on trivial nodes makes it possible to turn the simplest boat into an interesting art object.
After all, you yourself do this on your models. ;)
Link to comment
Such a pleasure to see your work Valiery. I would love to see more detail of your metal working. It hard to always see from the finished item how you went about the assembly
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thanks Keith. I do not have the opportunity to photograph the manufacturing process of all parts. There are a lot of them and there is always very little time. :)
 It will be easier if you ask me about a specific detail and I will try to answer your question in as much detail as possible.
Link to comment
On 9/21/2020 at 9:53 PM, KORTES said:
Valeriy,  as always, your work is  of an outstanding mastery , my best regards .
Greetings to you, Alexander!
Thank you for your feedback and I am a little behind the times, so the question for you is - have you started your new project or are you still choosing?
Link to comment
Beautiful work Valeriy but unless I'm missing something it appears that one of the "V" cut gears needs to be turned the other way, those teeth won't mesh like that.
Link to comment
Yes, Bedford,  you are right. :)
This is only a rough assembly, the shaft on the electric motor is also  temporary, it will be shortened later.
Link to comment
Yeah I didn't think you'd make a mistake like that but thought it should be pointed out just in case. There are people who really can't get their heads around gears and the like.
Link to comment
Valeriy
The shackles are terrific!   Are you making the flanges separately and soldering the to the ends of the half round rods or flattening the ends then filing them to shape or some other method?
Thanks for sharing!!
Allan
Edited by allanyed
Link to comment
More beautiful work Valeriy!  I ditto Druxey's remark - "That is the nicest miniature shackle I've seen."  Thanks for showing us how.
Gary
Link to comment
8 hours ago, allanyed said:
Valeriy
Allan
Allan, everything is very simple - I show it with the example of a large rod. ;)
Edited by Valeriy V
Link to comment
Valerie, excellent shackle - and the extra bit of explanation was yer helpful. What diameter wire did you use?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thanks, Keith. The photo shows a wire with a diameter of 0.9 mm, but for other shackles I use wire from 0.7 to 1.2 mm.
Link to comment
2 hours ago, Roger Pellett said:
Valeriy,
You must have a draw plate that converts round wire to that with a D shaped cross section.  What is it called?
Roger
Sorry Roger, but I don't know the exact name in English, maybe it's a die.
https://markis.su/shop/filernaya-doska-eagle/
Link to comment
Your metal work is awesome!  Well done!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
