usedtosail
Santa Lucia Sicilian Cargo Boat by usedtosail - Panart - 1/30 scale
After finishing the USS Constitution, I wanted to build something just a little simpler that would not take me another 5 years to build. I had a few kits on the shelf to choose from and I was leaning toward a Cris Craft runabout as something really different. But then my son, who has recently bought his first house, asked me to build something for his mantel, and when I showed him the kits I had he liked the Santa Lucia.
I got interested in this kit in the first place for a couple of reasons. First, I am half Sicilian and my grandmother on that side loved the song "Santa Lucia". Second, after seeing the build logs of this kit on this site (AnthonyUK and FernandoE), I really liked the look of the boat.  I found a kit on the web at a reasonable price and bought it a few years ago.
Here are some shots opening the box. I don't know how old this kit is but the wood still looks pretty good. There are a lot of brass fittings and the laser cut keel and frames looks pretty good too.DSC_0036.JPG.7d231b6522577eadd92f279d17b8311c.JPGDSC_0037.JPG.1e3226339fd84ee7842090271f5ca899.JPG
The blocks are huge and very ugly, so I am going to try to make new ones or if that fails I will buy some new ones from Chuck. I know very little about this boat so I am just going to follow the limited directions in the kit and see how it goes. There are 3 sheets of plans which are all in Italian. At least the other instructions are in a bunch of languages, including English.
Next up is getting the keel and frames cut out and cleaned up.
Share this post
Link to post
Share on other sites
I separated the keel, frames, and frame stiffener pieces from the laser cut sheets and dry fitted them. I am using the build board I made for the Constitution build, which holds the keel nicely.
There are a few frames that are loose in the keel slots even with the stiffener in place, so I will tighten them up with some scrap wood in the slots. I marked the locations of the bottoms of the frames to define the line of the rabbet that I am going to carve into the keel.
I then took the frames off the keel and used a ruler and French curve to draw the rabbet lines on both sides.
Before I start carving up the keel, I practiced on some scrap from the laser cut sheet. I am using a small flat chisel to make the groove initially, then a riffler file to clean up the slot. On the areas where the line curves up at the bow and stern, I will use a large flat file to taper the wood into the rabbets. This is a double ended boat, so both the bow and stern are going to be planked like the stern normally is on a larger ship.
Share this post
Link to post
I finished carving the rabbet into both sides of the keel and put it back into the build board. I added some 1/64" wood strips to the loose slots and used clothes pins as wedges while the glue is drying. If you look carefully you can see the rabbet.
Share this post
Link to post
Thanks K. I think it will be a fun build.
I glued the frames into the keel after filing the shims that I added to some of the slots. I glued the middle three first, then the aft three, then the bow three. With each group, I placed the keel stiffener in position to hold the frames square to the keel.
Once all the frames were in glued in place, I glued the keel stiffener down to the frames and the keel. I used some metal blocks as weights to hold it down. Everything fit very nicely and the keel is nice and straight. I also glued the two end frames to the keel that are above the keel stiffener.
When all that dried, I glued a few deck spacers to the tops of the frames, using binder clip plank clamps to hold them tight to the tops of the frames. I am not sure just having glue here is going to be a strong enough joint, but I will see how these three come out. I may put some wire pins to help hold these together if they seem not secure enough.
Share this post
Link to post
Thanks Anthony. Your build log is one that got me interested in this kit. The links to info on these boats has been very useful too.
The deck spacers seem to be well secured with just glue, so I glued the rest of them on.
The two pieces on the ends are two of the four end pieces that help form the rabbet at the stem and stern. These have to be shaped with pretty severe bevels, so I started on the two front pieces before I glued them in place.
I will finish the bevels as part of the fairing of the frames. Now to do the back two.
Edited by usedtosail
Share this post
Link to post
Hi Tom
I'm following along as well. My kit was over 30 years old when I got it from my brother late last year. I'll be interested if there have been any changes to their kit over the years as, in particular, I found the instructions hard to follow (I am a relative newbie though so it could just be me!).
Cheers.............Fernando :cheers:
Share this post
Link to post
Thanks guys. Fernando the instructions are still very hard to follow. They include planking instructions which I found hilarious.
Since the last update I have glued the end pieces in place after shaping them, then faired the frames.
I used battens to set up three planking bands per side. I think I'll be OK with the middle and bottom bands but the top band will need some spilled (spelling?) planks to fit up to the tops of the bulwarks supports. I soaked some planks for the bottom and middle bands and clamped them to the frames to dry.
In between the start of the planking I have started cleaning up the blocks supplied in the kit. They are all rather large (7 and 10mm) so they are easy to work with. I started by drilling second holes for each supplied hole so I could simulate the sieves. I used the mill with a starter bit to index from the old holes to the locations of the new holes, started the new holes, then finished them with a regular drill bit. This gave me very good results in the opposite sides of the blocks.
I then used a pointed chisel to carve the simulated sieve between the two holes on each side. I sanded the blocks so they would be more of an oval shape. Once they are all shaped I will put them into the block tumbler to soften the edges a bit more. This first block I shaped too much but you can see the sequence I followed.
Here are better shaped blocks.
I still have a bunch to do but it helps fill the time while waiting for things to dry.
Share this post
Link to post
Planking continues with a few planks per day. I trim them to width given the distances between the two first planks, then soak them for a few hours and clamp them to the hull to dry overnight. I then glue them in place again planking them to the frames and to to planks already in place. Here are the two planks that define the three bands after gluing them on.
Here the garboard strakes and the first of the top band planks are clamped on to dry after soaking.
And here the second middle band planks on each side are being glued in place.
While waiting for planks to dry, I measure and trim the next planks to be added. While this is a slow process, I am really trying to keep the amount of sanding after planking to a minimum so I am taking my time. So far so good.
Share this post
Link to post
Hi Tom, slow and steady is the way to go on this model. This was my fourth build and the hardest as far as planking was concerned....don't know why but I really had to work hard to make it work.
Cheers...........Fernando :cheers:
Share this post
Link to post
Thanks Fernando, Popeye, and EJ.
Fernando, I am a bit concerned about the planks that make up the outside of the bulwarks. Did you glue these to the parts of the frames that are to be cut away? I am leaning in that direction and then will clean then up inside when I remove those sections. I guess the second planking will help hold these together but just edge gluing them seems too flimsy to me.
Share this post
Link to post
Hi Tom
I was also concerned about the planks and did glue them (not a lot of glue but just enough to hold them in place). Once the second planking is in place there is more than enough strength to keep it all together.
Cheers.........Fernando  :cheers:
Share this post
Link to post
Hi Tom.
Nice steady build.
I replaced the blocks that came with the kit. Some I made and the rest were Syren's blocks.
Planking is a pain on this hull but it's a nice shape when finished.
All the best.
Regards Antony.
Share this post
Link to post
Thanks Anthony. I am just glad this model will have a second planking. This one is just the base.
Here is a nice planking process picture. I have a plank in the middle band clamped after soaking to get it to shape, another in the bottom band drying after being glued to the keel and frames, and in the background there are two wood strips that have the frame positions marked on them ready to be trimmed for the top band.
The supplied wood strips for the first planking are 1.5mm thick and 6 mm wide, and I have found that they only require soaking for a couple of hours and can be manipulated very well after that. I have not had to resort to any kind of heating for these strips. Those clothes pins between the frames reduce most of the clinkering since they clamp the wet plank to the previous one.
For the top planks I have flipped the frame over so I can work from the top. You can start to see the shape of the hull coming out.
Just more of the same for a while...
Share this post
Link to post
Thanks Popeye and the likes.
Planking is coming along as I am down to just a few planks left in each band. I am going to drop a few planks near the stem and stern in the middle and top bands as the remaining gaps are pretty small there. As usual I am using a variety of different clamps, but as the gaps get smaller the choices get more limited.
DSC_0002-004.JPG.5a234ecd9dadcc76b4364db0b4199cfd.JPGDSC_0003-005.JPG.e55b21b3fe9cd78b4e5cc1b98e2def34.JPG
Share this post
Link to post
Thanks Fernando and for the likes.
I am getting close to finishing the first planking. I have the bottom band done, which did not require any dropped or added planks. The middle band is almost done, but there are 4 drop planks to be added, one on each side at the bow and stern.
DSC_0001-005.JPG.742f138cc80a18f8e70eb64fde105f4d.JPGDSC_0002-005.JPG.b3cc1cad800e7dbb6b2cbaa7d612ffa8.JPGDSC_0003-006.JPG.6d8ad262dd09864ae288070005c99ce0.JPG
Here you can see how I am doing the drop planks. I am finishing two planks on a frame with 45 degree angles, then filling the remaining gap with a single plank the goes to the bow or stern. Normally I would surround a single dropped plank with two full length planks, going from 3 planks to 2 planks, but to do that on this model the two planks would have to be made from very wide stock. Even with the method used here I had to make two of the single planks from wider stock than the 6mm wide planks supplied with the kit, but they are short pieces so I didn't need much.
I have made those single planks and was able to soak them and clamp them to the hull to shape them. I though I might need to use heat with them after soaking because of their length, but that was not needed. I'll add pictures of the completed drop planks in a future post. As you can see I haven't done any scraping or sanding to the hull yet. Once I have the top planks glued on then I will be cleaning everything up in preparation for the second planking.
Share this post
Link to post
As promised here are the photos of the drop planks in place. (I have another photo but it doesn't want to upload). You can see I will be adding another drop plank at the top planks. You can also see a spot where the clamps I used forced a plank to bend in too far. I will add some filler there to fix it after the initial sanding of the first planking layer.
Here I have soaked the next top plank and clamped it to the frames. I am using a keel clamp to hold the hull when it is right side up.
I still have to put in the drop planks at the top and I also have to make and add two spieled planks at the bow, as a single plank all the way across at the very top can't be bent enough to fit right.
Share this post
Link to post
Welcome to all those that are now following along.
I have spent the last week or so trying to get the last couple of planks right, especially at the bow. I wanted to make sure I had a nice curve from the first frame into the keel. I ended up removing that section a few times and finally was able to make a nice spieled piece that fit well after I curved it with a planking iron. Here are some pics of that process.
DSC_0002-007.JPG.a7459d7b74e939bd91079bd995e1df79.JPGDSC_0003-007.JPG.79f8b936da169bcf439020cc1d058fd7.JPG
And the results.
DSC_0003-008.JPG.e4edac680d967c39be1666da68d0e798.JPGDSC_0004-006.JPG.7d47d4bf69d5c4b484a61fab00fa662a.JPGDSC_0005-003.JPG.1ec55adc241b3818818107f98910aba1.JPG
So now the first planking is on and I am ready to start getting it smooth for the second planking, which I will show in the next post.
Share this post
Link to post
Here is where it gets a bit ugly, as I can not for the life of me do a good planking job without clinker planks and gaps. So the first step is to add wood filler on those area that need it, which in my case is much of the hull.
Here is another hack that I have been doing. Even though I cut a rabbet at the bow and stern posts, the first planking strips were too thick to be bent enough to fit into it completely, so I just got the ends close while planking, knowing I could use wood filler to get them to curve into the posts better than trying to bend them.
So first I used a Dremel with a sanding disk to roughly sand down the plank ends.
Then I filled in the gaps with the wood filler.
Today I used a flat scraper to scrape down the filler along the posts but don't have a picture of that yet. Stay tuned and the next post will hopefully have a better looking hull as I continue to sand and scrape it down.
Share this post
Link to post
Hi Tom, if it's any consolation I found planking the hull one of the most challenging I've done. The second layer of planking hid many of the faults and filler used on my model.
Keep up the good work.
Cheers...... Fernando 🍻
Share this post
Link to post
Tom, no shame in wood fillers to make the first layer of planking fair and true. Most of us do the same on double planked hulls. It is the second planking that everyone sees anyway. Do whatever it takes to make this layer spot on and the second planking will go on much easier. :)
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
