Revenue Cutter by sjanicki - FINISHED - BlueJacket Shipcrafters - Scale 1/48
Looks real nice so far. I love this style of ship and BlueJacket makes a far better kit than the Corel version I built.
Link to comment
Share on other sites
Starting the copper plating today! I did a bunch of reading on the forum and found this nice thread about plating:
My current plant is the follow the instructions in the thread and make three rows of plates parallel to the waterline and the rest based on the keel.  I should hopefully get some progress photos by the end of the day.
Link to comment
15 hours ago, sjanicki said:
I also used an x-acto knife to cut the plates from their sheet. Definitely a learning experience!
The best way to cut those plates cleanly and this is also true of photoetched brass, is to cut them on glass. Get a small piece of 1/8 tempered glass with nicely rounded edges and it's a perfect surface for making those kinds of cuts. Also, both cutting the metal and running into glass is hard on Xacto edges and they're expensive, so the best thing to do cost-wise is to buy a nice cheap pack of 100 single-edged razor blades and use those for thin metal cutting.
Link to comment
Thank you! This is a great idea
Link to comment
Was traveling for work for a couple weeks so glad to be back at it on the Revenue Cutter.
Made some more progress this evening on the plating. Using a clamp to keep things flat as I glue the plates on.
Any my recommendations on how to do this on the main part of the hull?
Also, cut a ton more plates out
Link to comment
  • 2 months later...
Is the copper fairly hard then and so a bit springy?
I don't have any brilliant ideas. Would contact adhesive work?
Richard.
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
Link to comment
I've never done coppering, so I have no advice, but your approach makes sense as it's basically the same idea as proper planking. If an item already has the shape it's supposed to, it'll be more likely to hold that shape when being glued. My other suggestion would be to read through build logs of similar kits using that style of plates and see what they did.
Link to comment
Great job progress.  Xuron also makes scissors specifically for PE.  Tiny little hardened edges let you get really close and they go through PE like the proverbial hot knife.  I'm doing a bunch of PE trimming and have found them to be indispensable.
Steve
Link to comment
Made some more progress this weekend on the plates. I feel that as I continue I keep getting better at shaping and applying the plates. When the intersect at the bow and stern they need to be cut to match properly which takes way more time than I would have guessed.
Anyways, learning a ton and looking forward to putting plates on my next model I work on as well.
3CA200AA-0557-4106-BBD9-8FE3EC0FE64F.thumb.jpeg.edcdad1d6674a346ff62edf4468e5ae8.jpegEB92A7EE-C9E7-4479-B727-B242D0249477.thumb.jpeg.26c40bda610deb57f22101192ff15fbb.jpeg
Link to comment
On 7/9/2019 at 10:54 PM, sjanicki said:
I suspect the second half will look much better (it’s already looking better) so I may have to be clever in displaying the finished model
I like to decide early on which side of a model is the "display" side and always work on the other side first to ensure I figure out any bugs before doing the "good" side. Your work certainly looks nice to me.
Link to comment
Had some unexpected time this evening and finished the plating!
One major difference I made this time was starting in the middle and working my way out to ensure an even overlap between each set of plates.
56206689-E27A-448F-957D-034B431D68D9.thumb.jpeg.5cd1c814239d5a1c2d4a90f5169d30b5.jpeg95E12C7F-95A4-476F-9F98-0C64929939E8.thumb.jpeg.c5700530ea5da8304ee7e2eb5b361d5d.jpeg695EABBF-ADD7-48CC-B31F-F171E498D191.thumb.jpeg.ffd4ec38cff55e7857d83f33ac02b890.jpeg
For my first time ever copper plating and only my third model ship I am pretty happy with it :)
Edited by sjanicki
Link to comment
Made some more progress this evening on some small details.
The first detail was sanding the cradle a but a bit so the keel would fit in again. The keel is now a little bit thicker because of the copper plates.
I bent and and installed the brass boom traveler into place. I have a cutting mat with one inch squares on it so it made bending the corners at an inch per the plans super easy.  I also cut off the extended bass on the backside and used a bit of touch up paint to cover the brass.
Next was painting the copper part of the rudder to prepare for the copper plates. I should have done this earlier but forgot.  I held it upright with a clothes pin for easier painting.
I then measured, cut and began priming the wales. They are laser cut to shape and match the hull and deck perfectly when bent - a great touch by Bluejacket.
I then applied a couple copper plates to the rudder being careful to cut, bend, and dry fit each plate before gluing. After coppering the hull I feel like I have learned a ton in the skill.
Link to comment
Hello what a great work so far. Wolfram zu Mondfeld recommended to clean the coppering with a kind of benzol wash (I donnot know the exact English - ask at you local drugstore so the superglue isn't effected by the cleaning!) So with this it would be possible to clean away all the fingerprints and than handling the hull per rubber glooves - to spray over the copper a row of layers of clear colour. After some years you do get the right warm and nice copper red tone - but be precisely with the cleaning!!! For the FBI
guys standung beside your showcase it will be of highest  intrest to catch any good fingerprint under the clear firnis!!!
Please do not forget the prepare drillings for the adding of the (blank wooden) "wrong keel" under the right keel and copper plating. I have got no idea what the way of fixing was like in the USCG - but there must be some information at Chapelles THE AMERICAN SAILING NAVY or at AMERICAN SAILING SHIPS to this topic - together with the HISTORICAL MODELSHIP book of Wolfram zu Mondfeld three high recommended books (-> low price used ones at Ebay) to read to get some further information. So you will swim free from the Bluejacket instruction and enter the ocean of information to become a historical modelshipbuilder.
Perhaps Alexa can read this for you on your job's journey in the car ;) *
Nice to see you doing the right overlapping of the copper plates. Thanks for sharing and stay model building!
______
*Me personally you can distinguish on an international airport by a pile of books under the arm lashed together by some old worn out belt and some muleskin notebooks within; for secutity I have allways to open this pile and you allways have the chance to bring some friendly interruption into their dayly live - some of them took a smartphone shot of the titels. So modelshipbuilding is an epidemic!
Edited by Heinrich der Seefahrer
Books tip integrated
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
Link to comment
You may dinstiguish the singular planks from.each other by taking a pruch and paint with a veeeery light yellow-brown ("sepia" from Citardel or a ligther one?) ink. So you interrupt the monstructure of the grain an bit and the deck doesn't look like a lasered vaneer plywood. Try out on a rest pice first to apply one layer on the next plank a double and next 1/2 a layer (by adding water).
You are on a very good track with your kit!
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
Link to comment
Thanks @Heinrich der Seefahrer for all of the great advice! I was going to ask for what to do with the tarnished plates on the hull.  Do you have a link to the benzol wash you are thinking of? Maybe Amazon link? I think that would be super helpful in restoring the luster to the plates.
I have a copy of Chapelle's book (which I believe the plans for this kit originated from).  I'll read through it to see what I can find as it relates to the false keel. Thanks so much for the pro tip!
Thank you for the compliment and the advice! I'll try the recommendation for emphasizing each separate plank.
Also, everyone else, thanks for all of the likes!!
Link to comment
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
