Revenue Cutter by sjanicki - FINISHED - BlueJacket Shipcrafters - Scale 1/48
Thanks to everyone who responded earlier to my query.  Your posts were very helpful in getting me to where I am at present on my building the Blue Jacket Revenue Cutter.  I am now up to putting in the masts and the rigging.  Does anyone have large, detailed  pictures, showing the standing and running rigging?
Link to comment
Share on other sites
A busy end of summer meant I am just now getting back into the build.
I also took a quick break from the Revenue Cutter to put together a card stock aircraft model. My first card stock model so fairly happy with the result.
7D728B54-0E51-4396-9494-213A465B7647.thumb.jpeg.83c84af2a6ba3955252af4925e32a198.jpegBBEE9E66-119F-4CC5-87E7-218543CC1653.thumb.jpeg.c972f2df785884d33207509337e77fa5.jpeg
I finished copper plating the rudder and then installed the pintles and gudgeons. They were a little difficult to make fit since after adding the copper plating the rudder was ever so slightly thicker.
After mounting the rudder to the hull it actually looks pretty good! I also went and installed the deadeye chain plates as well as the wales.
The entire hull and various fittings needed a bit of touch up paint before moving on.
0FEE49CB-48C2-454B-8426-FEF456584B6C.thumb.jpeg.bf8b0dce05be175f5c88153d4fb2866e.jpegD5DD55C5-FE4A-494F-9813-24539EB5FB02.thumb.jpeg.08241668092933642295ee5bf3a3adfa.jpeg
I also got a start on the aft cabin. Gluing it together and getting a first coat of primer.
Super happy to be back working on the model and making progress!
Link to comment
Made a little more progress tonight!
Mounted and pinned the rigging attachment points to the deadeye chain plates. After mounting I added another coat of touch up paint.
The #75 drill worked great in the drill and was much faster than a pin vice.
Next I painted the rudder plate cover and rear cabin assembly as well as the skylight cover. I glued the rudder plate cover in place and dry fit the remaining pieces. I need to cut the clear plate next to shape before gluing the cabin down.
Compared to carving and coppering the hull these features go very fast
Link to comment
You said you had "Chapelle's book." He has four that discuss revenue cutters and Baltimore clippers, but only the "History of American Sailing Ships" has many plans for revenue cutters.
The Bluejacket kit seems to be for the 31 ton design by William Doughty. The "History of the American Sailing Navy" (1985) has drawings of this ship on pages 184, 191 and 196. The drawing on page 191 has the sail plan and spar dimensions. This is the largest drawing of this type I have seen. I suspect the Bluejacket plans are larger than this.
Take these sail plans with a grain of salt. There were significant variations from ship to ship, and no one is really sure if any ships were built to Doughty's 31 ton design. Chapelle's "The Baltimore Clipper" is a wealth of information about the general design of the schooners and revenue cutters, but it is a small book with small drawings (and lots of them). It has detailed descriptions of the spars for many of these ships.
Note: the original editions of some of Chapelle's books have larger drawings, including many fold out double page size plans. The more recent reprints reduce these plans to a single page. You can find the older editions on Amazon.
Link to comment
Made some more progress tonight on the Deadeyes and cleats.  I used the drill again to drill the various holes in the pre-marked locations on the deck as well as the transom. I elected to leave the various brass fittings in their natural color
Made some progress on the toe rails as well. First time having to boil a pot of water for this hobby (though I suspect it won’t be the last!) The instructions do a great job on explaining what to do.
Link to comment
Made some more progress tonight on the toe rails, hatches, carronade, and various deck fittings.
Cleaned up the carronade and it’s carriage. It’s really an intricate casting and quite cool. I had to drill out the lug mounts as well as various pulls attachment points. Next I painted the carronade black and carriage brown.
I also prepped and painted the forward and main hatches, carronade track, bilge pumps, and galley stack.
After gluing down these various components I realized I needed a darker stain on the toe rails so I wasn’t able to glue them down yet.
Link to comment
Made some more progress this weekend on the various deck fittings.
Mounted the various blocks as well as the knight heads, bites, tiller, and cabin companion hatch hinges. I also rigged the carronade but didn’t get glue it down.
Also, made great progress on the stanchions. Cut them all to length, flattened the ends, and drilled a couple till I broke off my drill bit. Ordered another drill bit (actually 12) and should be finished with them later this week.
Aside from the stanchions, I am done with the deck fittings and will move on to the masts next!
Edited by sjanicki
Link to comment
I have this same kit as well as a few other of Bluejackets kits.  You have done a wonderful job on this little beauty.  Do not know what your next project might be after this one.  But after your slam dunk job plating the hull, give the Pilot Boat a look.  Look forward to the finish.
Rick
Neophyte Shipwright
Wisdom:  When all else fails, read the instructions!
Link to comment
@RickyGene thank you so much for the kind words! I am still a total novice with this model ship building so I appreciate the kind words! Especially as it relates to the coppering as I had no idea what I was doing. I think I'll have some time this weekend to make some progress on the masts - looking forward to it.
I actually just ordered the USS Perry from BlueJacket.  I was told it is really the perfect jump in required skill level and will also allow me to continue with coppering hulls. I ordered it before I was done with the Revenue Cutter so that I would be motivated to make fast progress 😂
Link to comment
Made some progress tonight on the masts.
I don’t have a lathe so I needed to improvise on how to evenly taper the masts. I chucked them in a normal carpenters drill and utilized sandpaper as well as my rotary tool perpendicular to the mast to easily taper. Once the masts were tapered I used a combination of the rotary tool, razor blade, and sandpaper to square off the ends as the plans say. I then mounted the various laser cut parts per the instructions and stained and painted.
Next up is just continued progress on the masts and rigging. Some extra drill bits showed up so I’ll be hopefully drilling the rest of the stanchions soon.
Link to comment
Made some progress tonight on the top masts, spiders, boom jaw rest, yards and mast hoops.
My improvised carpenters drill lathe continues to work great. Tapered the top masts without issue and drilled the appropriate holes per the plans. After a quick stain they were installed as well as the fid (evidently the fid is a small piece of brass that is inserted perpendicular to the top mast to keep it in place. I had never heard this term before this).
I also installed the mast hoops and held them in place with some masking tape. Unfortunately I broke a few while cutting them from the sheet so hopefully nobody notices on the final build. After the hoops I installed the spiders and boom jaw rest and bracket without issue per the plans.
Next I cut and tapered the lower and upper yards. For the small step on the ends of the yards (I’ll bet there is a name for this but unfortunately I don’t know it) I used a small saw to cut a little bit into the yard and then utilized a file and sand paper while rotating the yard to trim it down. Overall happy with the result!
My first time rigging so excited to be making progress!
Link to comment
Hey credit is due, where credit is due.  Your hull has turned out nice for a novice (your word).  We all started somewhere and my 1st sure did not turn out like yours did.  So you are going with the USS Perry.  Quite a jump, but glad to see you are willing to stretch your skills for something a bit more involved.  Solid hulls are a great way to build ships.  I have many un-built and shelfed f/future builds.  One of my most ambitious builds was a Bluejacket 310' Destroyer.  I horse traded w/a local then Hobby Shop because kit was a  very expensive purchase back then.  After I built it, took a couple years, the same guy who owned the shop bought it back and as far as I know, still has.  I have been eyeballing one of their (Bluejacket) CSS Alabama's and or Portland.  But being I am retired, I have to really want it bad before I buy now.  I no longer buy to shelve, but too build.  Looking forward to you completion of this project my friend.
Rick😎
Neophyte Shipwright
Link to comment
Thanks so much @RickyGene! The Perry showed up this last Friday and it looks like an awesome kit! Once I finish the revenue cutter I’ll be sure to start a build log.  Being a bit more complex of a model I am sure I’ll ask for advice here.
Anyways, made a little bit of progress today on the boom and gaffs.
Link to comment
Again, a fine build so far.  I have read several builds over the years about this little vessel.  Some gave up because of issues with the hull and how machined.  But you have shown it is a beauty if one persist.  The addition of the copper plating has really made this a eye catcher.  I have followed and will return I am sure many times when I break down and build the one I have.  Looking forward to the finish.
Rick😎
Neophyte Shipwright
Link to comment
@RickyGene thank you so much!  I really had no idea what I was doing on most of this build so I am glad people think it’s turning out so nice. I think the addition of a power tool and plenty of time made the hull go well. The copper plates I am most proud of and, considering my inexperience, actually look pretty good! Looking forward to your build log when you start.
Made some progress tonight on boom, gaffs, deadeyes, and boom traveler. The combination of very clear plans and and detailed instructions make it a fairly straight forward task. It’s my first time rigging so I am glad that there haven’t been any surprises.
Link to comment
@AndyXO sorry I missed your posts! I don’t have any photos beyond just what I have so far.  I’ll be sure to post as I make it through though.  Also, the other build logs may perhaps have photos that are further along.
Link to comment
Look closely and you can spot the intrepid builder in the photo. 😎
Neophyte Shipwright
Link to comment
Might be awhile before I get to her, in the docks now......OcCer HMS Terror, Aeropiccola French Chebec Indescret and last but not least Billing Boats Esmeralda.  The French Chebec seems to be getting all the attention right now.  The Billing Boats Esmeralda is just in the keel laying phase.  The poor HMS Terror, just sett'in on a shelf.  I have always had a hard time staying on just one project.  Albeit, some time does pass before one is completed.  But I have found that I seem to complete more this way than if I try to stay on one and lose all interest.  I am cursed with the most dreaded affliction….perfectionist.  Oh for the days of just building for the fun of it.  I hope you never have to deal with that curse, but sadly if you stay at it long enough, she will ever so slightly creep in!
Rick8)
Neophyte Shipwright
Link to comment
Congratulations!  Well done!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
