Prince de Neufchatel by GrandpaPhil - FINISHED - 1/72 - from Chapelle Plans - Card
My test fit:
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Share on other sites
2 hours ago, Wallace said:
Wow, I missed so much progress while I was away this week. You have done a great job Phil, really. You have a right to be proud sir.
Thank you, Mark!  Much appreciated!
Link to comment
I made the iron strapping for my cannons.
I have also traced out the parts for the anchors.
Link to comment
I have discovered some more scaling issues, which considering that I built from multiple sources, in hindsight,  is to be expected.  Oh well.  Pressing on.
Link to comment
The Prince de Neufchatel now has teeth.  The guns are glued in place.
 I also made the anchors (final painting is pending).  These are my second set due to those scaling issues that I mentioned earlier.  I had to reduce them in size to fit properly.
 I am going to install the anchors and have a gun rigging party.  Due to some more scaling issues, rigging blocks are not going to fit, but I can still put the rigging in place, oh well.
Link to comment
Anchors:
Link to comment
My next iteration of rigging blocks (for the anchors):
I was inspired to reshape them after seeing the work of others on this site.
Edited by GrandpaPhil
Link to comment
Breeching ropes installed:
Link to comment
Long guns rigged:
The rigging is simplified due to scale and room.
Link to comment
1 hour ago, Wallace said:
You are marching right along Phil, good for you. She is looking fine sir.
Thank you, Mark!
Link to comment
All guns are rigged:
Anchors are ready to install.
Link to comment
The anchors are installed.  I need to finish rigging them.  I already made the blocks for them.
Link to comment
Anchors are rigged and finished:
On to the boats.  I’m going to make male molds for the 3 different types of boats that the Prince de Neufchatel carried, and build the boat’s frames, keel and planking upside down.  The molds will be made bread and butter fashion.
I’m using the AOTS for the Victory, due to the time period and similarity between American and British Naval equipment, as my source.
Link to comment
It’s been a very educational evening.
I learned how to make a hull using the bread and butter technique.  I layered the hulls (the male molds anyways) for three ship’s boats.  I carved them to their final shapes before sanding them smooth and labeling them to put in my bits bins for later reuse, after I am done with them.
 I am confident that I could scratch build a ship’s hull with the bread and butter method.
I took pictures of the hull blanks in the positions of the ship’s boats, which I will begin tomorrow.  They will be made IAW Zu Monfeld (just out of card).
The stern boat will hang by davits, which I will also begin tomorrow.
Link to comment
Test fitting my boat davits:
Link to comment
I cut out and fitted my pin rails.  I double layered them, since they are card, and set them aside to dry.
Link to comment
As stated before, I am using Zu Monfeld’s method of building ship’s boats.  I have made the molds and the templates of the gunwales.  Next I need to make some frames and then the keels/rudders, before I plank the boats with 3mm (1/8”) wide strips of card.
Link to comment
Welcome!
Link to comment
I have the ribs in place for the ship’s boats.  I glued them to the templates.  Their keels and rudders are drying (pressed under heavy books).  After they dry I will fit them to the bottoms of their respective boats and install the cant frames of the launch (the biggest of the three).  After everything dries, I will plank them.
 I have included pictures of the pin rails and boat davits (neither of which are completed).
Re-added pictures
Link to comment
I have three ship’s boats planked.
The two smaller boats are clinker planked, the launch is carvel planked.  I believe that that would have been typical of the time period.
I cut out the shape of the wales and installed the rudder on one.
 I am going to let them dry overnight.
Link to comment
Davits are done and installed.
Ship’s boats are mostly done.  Still need to paint the two larger boats.
 I made four double blocks to hang the little cutter from the stern.
 I put some belaying pins in two of the pin rails.  They are made from sewing pins.
This is how I’m leaving the Prince de Neufchatel for the night.
Link to comment
I broke my boat davits.  I made new ones out of heavy gauge steel wire.
Link to comment
22 minutes ago, Wallace said:
Well they won't go breaking on you will they...
Lol, nope, they won’t break again.
Link to comment
I snuck away from a work project to hang the cutter off the stern and finish my stern pin rails:
Link to comment
54 minutes ago, Wallace said:
Over here they call that playing hooky Phil 😃
Lol!  Yep!
Link to comment
The ship’s boats are permanently installed now.  I also made the bowsprit and have it temp installed so I can make the bow platform and pin-rail.68DCE688-B2EE-422D-B47A-5E3D1054CF75.thumb.jpeg.ff83489ffc0a2f960194e13258a030bd.jpeg
I am working on the foremast pin-rails now, by which I mean that I’m waiting for the glue to dry so they can be painted.
Link to comment
At this point I only have a little more on the hull and then it’s masting, sail making and rigging time.
Link to comment
1 hour ago, CPDDET said:
Looking great!
Thank you very much!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
