Tiger65
18th Century Armed Longboat by Tiger65 - Model Shipways - Scale 1:24 - Small
Hello all.  This is my first build log although I have built a few models previously.  I am in no way in the league of many of the craftsmen that I see in this forum, so any thoughts or suggestions will be most welcome.
This project is the 18th Century Armed Longboat by Model Shipways in 1:24 scale.  I assume this model is basically a scaled up version of the early Longboat designed by Chuck.  There are not many build logs for the armed version but the smaller version seems to be one of the most popular builds on the site.  Hopefully you can point out any differences and steer me away from any major faults.
Below is the typical photo of the box showing the build to be undertaken.  I’m using this photo primarily to check my ability to add photos properly.
Share this post
Link to post
Share on other sites
The first step is shaping the rabbit.  Hopefully I have gotten close to the correct angle.  The photo shows the keel and false keel being glued together.  Most blogs have mentioned the weight for flatness but I found that, in addition, I needed clamps to hold the pieces tightly together.  The pieces are placed on a glass desktop and weighted.IMG-0774.jpg
Next photo shows the keel assembly in a simple building jig similar to many others in the various logs.
Most of the builds I have seen have left the wood natural except for some wipe-on poly.  I decided I wanted to try to add a little more depth without changing the whole look.  I stained the frames and one side of the planking with Minwax Ipswich Pine.  We’ll see how it turns out.
Edited by Tiger65
Share this post
Link to post
I am new to building wooden ship models. I built a lot of plastic ones growing up but nothing recently. I purchased the Armed Longboat kit because I thought it would be a good model to cut my teeth on. I'll be following along with your build as I progress on mine. I also plan on starting a build log here the advice is great. Keep up the good work.
Share this post
Link to post
In the next photo I have begun gluing the bulkheads.  I have tried to square and level them, then clamp to the metal blocks.
This shows the completed bulkheads with the strongback in place for gluing.  The instructions indicated two 1/8 x ¼ pieces glued together but I used a single scrap piece of 1/8 x 3/8 that I had.  While the instructions called for using rubber bands to make the proper bend I soaked the strip first and then used the rubber bands for the bend and let it dry before gluing.
Edited by Tiger65
Share this post
Link to post
Bow fillers installed and first side faired (I think).  I used the 1 1/8 inch emery board from the local cosmetic shop shown in the picture for the fairing.  It spanned several frames at a time but was flexible enough to not put too much pressure on adjoining frame members.  It was also easy enough to hold.
The first apparent problem.  While fairing the second side of the hull frames, one frame seemed too high and was not impacting the test plank at all.  That frame had seemed ok on the first side but the other side was not where it should be.  I decided to try to adjust it.  That meant cutting the strongback and using alcohol on the glue.  After removing it I worked on lowering it but also had to square it with the adjoin frames.  After adjusting as best I could I re-glued and will hope for the best.
Edited by Tiger65
Share this post
Link to post
As usual my planking leaves a lot to be desired.  The three following pictures show the first three sets of planks from the keel.  I am not certain the curve on the bow end is correct and may lead to problems with the future planks.  The most troubling area is at the stern end where the planks require a double curve to lay flat on the keel and begin the curve to the hull.  I have not been able to get the planks to lay evenly against one another.  One side is marginally better than the other but neither is perfect.
I have removed and replaced these planks once and am reluctant to do again without a new approach.  Unless someone has a better suggestion I plan to correct the area at where the lower plank is not tight against its neighbor but then just use sanding and filling to even out these planks.
Edited by Tiger65
Share this post
Link to post
The edges of the planks need to be bevelled to fit perfectly against the previous plank, you also need to shape the plank slightly in places to get a good fit ie thinner in the centre getting wider slightly towards the stern, have you read the planking tutorial by David Antscherl ,(look  under tutorials in building, framing and planking) or chucks tutorial on planking in his cheerful log, this will help you enormously I getting your planks tight
Hope this helps
Regards
Paul
Edited by paulsutcliffe
Share this post
Link to post
I'm working on the same model and I'm at the same spot. I tried forming the planks using just heat and got the back half of the garboard and first strake in pretty well but I broke several strakes trying to form the aft half of 3rd strake. Last night I gave in to soaking a plank in very hot water for about 15 minutes. The wood was then very pliable and I was able to clamp it onto the model with smooth flowing lines, butted to the adjoining plank and tight against the bulkheads. This morning I unclamped it and it held the shape perfectly. I then proceeded to do the same for the other side before leaving for work and when I got home it too held it's shape perfectly.  I only soaked about 8 inches of the plank, standing it up in a drinking glass full of hot water because the planks that span bulkheads 1, 0 and A are straight (assuming your garboard is straight with the keel). The forward half of the second and third strake I used sheet basswood and spiled the planks instead of trying to form them with heat. I already knew where the butt joints were going to be so it's easier to work on planking half of one side at a time. You can get sheet basswood at Hobby Lobby, it's not any worse quality than what's in the kit.
I was not happy with my first strake and ripped it off so I understand how you aren't excited about doing that again. Alternatively I'm glad I did and corrected my first shoddy attempt because things would have gone from bad to worse.
After seeing Chucks masterful plank jobs on the Cheerful and Longboat I was determined to follow his expertise and only use heat for forming. Ultimately I don't believe it can be done with 1/16" thick basswood, maybe if it was 1/32 thick it would work, but at 1/16" thick it's way to stiff to not soak the planks. Hope that helps, don't be afraid to soak those planks you'll, be happily surprised by how easy they are to form that way. It does take patience letting them dry for 8 hours but it's well worth it in my opinion.
Share this post
Link to post
Paul and Arthur,  I appreciate your comments and you make good points.  What frustrates me is that I did bevel and I did soak and form, even used some heat. I did not spile or make planks from sheet stock because the instructions clearly indicated that edge bending of the supplied materal was all that was necessary.  Based on results I agree that they were wrong and you guys are correct.
I always tell tell my friends that these models would be quick if I only had to build them once.
Share this post
Link to post
Looking at your photos, the first photo it looks to me like your garboard is falling where it should, roughly up to bulkhead F. Your second photo looks to me like you have the issue I also had when I first starting clamping down the plank, I started in the middle and worked my way back and when I got to the stem I ended up with a wedge shape between it, and strake #2. As dumb as this may sound, starting at the stern post and clamping that little bit down so it lies against the rabbit and strake #2 first, and then working forward made all the difference in the world.
Looks like you are using yellow glue, you might want to try CA instead. I'm using Loctite Liquid Super Glue (the bottle is kind of shaped like a nail polish bottle). A drop or 2 on just the bulkheads, 2 or 3 at a time works great. You will only need a few extra drops where the planks lay flat on the rabbit near the stem. I only need to hold the plank for 5-10 seconds and it's set then I move on to the next couple.
I agree, we shouldn't need to buy sheet wood for a complete kit. I did it out of laziness and expediency. I just ripped out the front 2 strakes (not the garboard) and I'm going to try soaking and edge bending the planks just to see if I it can be done. To be honest, spiling planks from sheet takes a lot more time to do than it should and edge bending these would save time in the long run. Good luck, I'm watching your build and it's been helpful seeing someone else struggle along with the same project.
Share this post
Link to post
This kit was the first wooden model ship I attempted also...It was a good learning experience. I used the electrically heated plank bender and forms to do the complex hull planks. Worked pretty good for me. you're doing a great job so far!
Share this post
Link to post
Ok, I removed the two strakes above the garboard and reworked them,  Still not perfect but better.  I tried Arthur's technique with CA glue but I didn't have good results.  I use the Loctite Super Glue and held it in place for more than 30 seconds.  Unfortunately when I moved to the next portion and put some pressure on the stake the first glue area separated.  Probably my mistake but I went back to wood glue.  It is more forgiving with set up time and removes easily with Alcohol.
Anyway, I moving forward with the sheer.
Edited by Tiger65
Share this post
Link to post
I spent much time and frustration trying different bending techniques for the hull planking.  I also lost some time to getting a new desk and reorganizing my modeling work area.  However, after looking at Arthur Wayne’s build log on this kit I decided to follow his approach to planking and cut the planks from sheet wood.  I removed some of my old work and set to using the scotch tape patterning approach.  I have been using one additional step, transferring the tape a heavy card stock and cutting the pattern on that.  That has allowed me to check the pattern before cutting the wood.  This is probably an unnecessary step but it has allowed me to remake pieces I wasn’t satisfied with. Also I continued to soak the planks to get the proper bend at the bow.
I have finished one side and done some sanding on it.  It turned out much better than my original approach using the strip wood as called for in the kit instructions.  It still is not up to Arthur’s work, which appears to me to be the gold standard for planking this kit, especially if your name is not Chuck or Kurt. IMG-0817small.jpg.eeddfafb02ed0d12cb9e876e6e9deeb3.jpg
I have concluded that I will not stain the middle part of the hull as shown in the kit photos because I will still need filler in some of the joints and seams.  I will look around for other longboat paint schemes.  However, I have a long time to consider this issue.
I am working on the second side of the hull and hope to pick up speed with practice. A couple of these joints in the replaced areas are not as good as I had hoped but fill and sanding will have to do.IMG-0818small.jpg.340dfe36ea0a9a062e07625c1e1e1e71.jpg
Share this post
Link to post
I finished the second side of the hull.  The entire planking process is now complete and I have begun to add the tree nails using the pencil technique.  I am using a tape guide since I did not do this a plank at a time.
After much sanding and some filling I have used wipe-on poly on the exterior and moved to the interior.  Cutting out the center of the frames has been quicker and easier than I had anticipated.  I used the x-acto saw blade for the work.  Now much more sanding is ahead.
The interior sanded and poly applied.
I taped the frames for painting---with fairly disastrous result. Since I was using acrylic paint over the poly service, I was able to repair the damage to a large extent.
Here is the cleaned up interior.  At this point I have decided I am not satisfied with my whole planking exercise.  I have ordered and received a new set of the laser-cut sheets for the keel and frames from Model Shipways and I am going to start over on the framing and planking.  This will take a couple of months but in the end I will have two versions of the work to choose from.
A quick word in support of Model Shipways.  I emailed them on a Monday morning—using the email address on their website--asking for the four replacement sheets and offering to pay for the sheets and the shipping.  I received the sheets by mail on Thursday at no charge.  I think this is exceptional customer service and has certainly made me believer in Model Shipways/Model Expo.  I will choose them in the future for my modeling needs if they have the items I require.
I will pick up this log after I get back to this point with my new version of the planked hull.
Edited by Tiger65
Share this post
Link to post
Working very slowly on building this boat and wish to share a couple of things I have found which worked for me.
When fairing the bulkheads, I also found some bulkheads are too low.  Rather than replace them I carefully used something like Testors or other suitable Contour Putty to build up low areas. How this will look on the inside remains to be seen although I use it sparingly and keep it off the sides. Additionally, when bending strikes, I found that soaking the planks in near boiling water for a few minutes, clamping in place followed by judicious use of a heat gun on low, worked very well so far for me.
Share this post
Link to post
Looks pretty darned good Tiger65! I found a couple unusual issues you will run into during the next few steps. The instructions tell you to use 1/16 x 1/4" plank scraps to make the bow and stern platforms, and the photos in the manual show this. The inventory sheet in the kit however identifies ten 1/16" x 3/8" strips for the bow and stern platforms. I used the 1/4" strips per the instructions, but I think the 3/8" wide strips look more correct compared to photos of other longboats. I only discovered this when I inventoried what I had left in the box and couldn't figure where all those 3/8" wide planks were supposed to go.
I also found the laser cut cockpit seats are not long enough by at least 1/4". There's no way to bevel them to fit against the transom and but up against the last thwart.
Share this post
Link to post
Okay, I have recovered from the rebuild of my hull.  I must say, after watching Arthur Wayne and Paul Schulze I don’t know why I am continuing with a log.  They have provided tremendous guidance for building this kit and I am glad I’m far enough behind that I can follow their advice for each step of the process.
 I didn’t spend all of these months on this hull rebuild. I got distracted scratch building some pirogues from cypress.  Finding and having the wood cut to size was a major issue since I don’t have a table saw or thickness sander.  Also I had to devise several jigs and procedures for the assembly.  Just a few pieces of wood but tricky none the less.
The hull planking was certainly no easier the second time around.  I think it is marginally better than the first try but I still managed to make a couple of disastrous errors.  Not the same errors as on the first build, but still egregious enough to be frustrating.  I still plan to paint the outside of the hull because I used some filler in the areas that would normally be stained.
I have installed the floorboards, platforms and risers.  Arthur, I read your comment on the 3/8 planking for the platforms too late.  I had already made them up and glued them in.  The platforms gave me more trouble than I had anticipated since no one else mentioned any particular problems.  The forward platform was especially difficult for me to get level and tight around the edges.  I built the forward platform twice to get some semblance of fit.  Again, Arthur shows us very high standards with the fit on the sides of his platforms.  After much work and cussing I realized you can’t even see that fit on the rear platform on the finished model.
When making the trim line on the risers I tried Arthur’s scraper idea, Paul’s scoring jig and also a gunstock checkering tool borrowed from a friend.  Of the three Paul’s device was by far the easiest and most effective for me.  I reconfigured the tool for the thwarts, which have a similar groove.  My thanks to those two gentlemen for coming up with these ideas.
I have begun to work on the seats. The seat pieces supplied in the kit seem to be almost the proper length.  However, it points up a small frame alignment problem.  Rather than remake the seats I think I will fit the seats as is and adjust the thwart to take up the gap, using the shortest seat as the operable seat length. Does anyone have a better idea?seat fitting.jpg
I have made a first template for the frame cutouts so I will confirm as I move along.
Edited by Tiger65
Share this post
Link to post
The pirogue looks very cool Tiger65! A side project is always a cool thing to have going, sometimes it keeps the "other" projects interesting! Please do continue with your log, I think I read every Longboat build log start to finish before starting mine and always found something worth tucking away for use now, or later. Also if people keep seeing the same issues with the same boat, they will be able to better plan around it.
If you plan to use the kit parts, your idea seems like it's the easiest method. I wasn't thinking outside the box, if I was I might have gone this route myself. Add Paul's mod to the locker and you should be golden.
Share this post
Link to post
I think your pirogue is indeed very cool.  I find that as a possibility for me to try sometime.
Considering your cockpit seat problem, a possible work around might be to cut the fore part of the starboard side so that it is parallel to the thwart and also even with the port side. Then make the thwart notches deeper so that it can be moved aft and butt up against the starboard and port cockpit seats.
I agree with Arthur, keep up the log as everyone's build becomes helpful to someone else.
Share this post
Link to post
Thanks for the kind words on the pirogues.  I made several for friends and family.  Once I got the lumber dimensioned and jigs made, the assembly was pretty straight forward.  Lots of sanding to smooth everything out.
Here is where I came out on the seats.  I cut the thwart around the frame to fill the space to the shortest seat and adjusted the other seat accordingly.  There is a small gap at the rear of the center seat where I have a trim piece in place now.  Nothing is glued yet so I may put a trim piece across the entire rear of the seat area or I may leave the gap as a hinge area.  Somewhat depends on if I decide to paint the seats instead of just staining them.  I have some gaps around the frames that I would like to fill, so that may help make the decision.
I'm moving forward on the rest of the thwarts.  Is there any rhyme or reason the how the thwarts fit to the frames.  I really can't see it.  It doesn't make even spacing, so I'm not sure why its done this way.  Mine is not to reason why....
Share this post
Link to post
Tiger, I don’t know if you read my solution (post entry  #74) to the center seat problem, but I simply cut the aft board off of it and replaced it with a wider one.
Edited by Dr PS - Paul Schulze
Share this post
Link to post
Paul, I did see your solution and I may do that.  I am remaking one of the side seats to get rid of some of the gaps at the frames.  If that goes well I may either remake the center seat or replace the board as you suggest.
Share this post
Link to post
Here is a photo of the seats in place but not glued.  I remade the far side seat and also the rear seat with the transom board wider.  As you can see from the photo I have installed the thwarts and the supports under them.  I took the easy way out and made the supports with the drill press as a lathe.
I also discovered the situation of the mast thwart cut out being larger than the mast.  I am trying a different way to solve the problem.  I had a piece of brass bar stock so I made a collar for the mast.  The collar fills the gap in the thwart and allows the mast support bracket to be tighter. Hopefully you can see it in the photo.  The mast still has to be shaped and is not glued in.  When the mast is complete I should be able to tighten up the remaining gaps that show up in the photo.
Edited by Tiger65
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
