Schooner Germania (Nova) by KeithAug - FINISHED - Scale 1:36 - 1908 / 2011
Those rubber donut and springed sheet horses are quite common on larger top-end yachts of the "Golden Age," but I never really understood the point of them. I've never come across anything on them in the literature. Maybe they were a fad and wealthy owners commissioning their yachts came to expect them, so the architects satisfied their expectations. They are unquestionably impressive, but the springs I've seen have always been quite strong. You'd have a hard time compressing one by hand, and the rubber donuts were hard, like tire rubber, and no more "compressible" than the springs. (After a few decades in the weather, the old rubber was hard as a rock, too!) Maybe they served to remind helmsmen that in boats of that size an uncontrolled jibe was to be avoided at all costs, but in the event of one, those shock absorbers wouldn't have made much difference. Generally, the stretch in the sheets and the flexibility of the spars provide all the "shock absorbing" that's needed in regular operation. (The stresses aren't sharp shocks, like when tires hit potholes, but rather fluctuations in tension.) On the other hand, they may have been developed to compensate for the lack of stretch in more modern construction when wire cable standing rigging and better cordage with less stretch came into use (and certainly later, when synthetic cordage came along.) I do recall an old timer from the "Big Boat" ocean racing fraternity telling me how a lot of the large ocean racers suffered a lot of busted gear, broken frames, deck leaks, and such when everybody went to Dacron line and sailcloth and hydraulic backstay tensioners and big geared deck winches to squeeze a bit more speed out of their boats. They were then able to really crank down on the rigging far beyond what the boats had ever been engineered to handle. Those "buffered" sheet horses may have been some attempt to compensate for some of that. I don't know, but they are certainly an interesting and impressive fitting.
Link to comment
Share on other sites
10 hours ago, druxey said:
they are challenging you do the same with your blocks!
Druxey - I am pleased to say that Germania's owners like their blocks "au naturale" 432730666_ScreenShot2017-07-27at10_14_37.png.af7fb424b1096bbc2ee93de036f1b6aa.png
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Deleted duplicate
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Bob - I would agree that these shock absorbers are unlikely to be of a lot of use in and uncontrolled jibe. I once sailed on Simon Le Bons yacht "Drum" (fortunately not at the time she lost her keel). At the time she had huge plates welded on to either side of the main boom to repair the damage caused by an uncontrolled jibe. According to there skipper the jibe had bent the boom through about 45 degrees - remarkable given its very ample section. However it is my experience that even a controlled jibe in inclement weather can lead to boom whipping across until restricted by the main sheet. Under these circumstances both rubber and spring types of absorber will act to mitigate / reduce the instantaneous impact load. The loads on a big yacht can be many tons and ones inability to compress springs by hand is understandable. I agree with you that age hardened rubber wont work and my assumption is that the donuts have a recommended replacement cycle.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Back to the build after the shock absorber discussion. Thank you for all the comments and thumbs ups.
I realise I didn't post any images of the finished rails ( after 4 coats of poly).
Having completed the rail I decided to make and mount the brackets for the shrouds - 4 each side for the main and foremasts - 16 in total. Similar brackets also attach blocks to the rail - 4 for each mast - 8 in total. I therefore needed 24 brackets.
fullsizeoutput_1f87.jpeg.7181b969a704ba8e26be734b87c49b26.jpegfullsizeoutput_2009.jpeg.5045abfc2afa0e5585e6404f2ebaa95d.jpeg
I started with a sketch. The brackets are fairly simple affairs:-
I drilled a piece of brass to create the holes and then used these holes as a reference to mill the outer radius. A slitting saw was then used to divide each bracket.
The "comb" was then turned horizontal and a further slitting saw cut was used to separate the "fingers".
I then needed to attach a spigot ready for attachment to the rail. This involved drilling a .04" hole along the axis of the bracket. To do this i made a simple holding jig - basically a "U" shaped notch .05"  deep in a piece of scrap aluminium.
The jig allowed the brackets to be positioned accurately and repeatably in the mill to allow the .04" hole to be drilled.
With all the drilling done .04" wire was glued in the holes to create the spigot.
Finally another simple jig was used to part off the spigots to length.
I now have 24 ready to install.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Mate, you dodged a bullet on the leathered blocks!
Always a pleasure to watch your work.
Edited by Bedford
Link to comment
Hi Keith
the decks are looking superb, & in good scale as well. A question: do you think that glueing the rods in is stronger than solder, or is there another reason?
thanks
Link to comment
Thank you Bedford / Mark.
Mark. I find CA glue is very strong when gluing closely fitting shafts into bores. I even use it to glue parts on to shafts when I want to turn them and it invariably survives the turning operation. I don't think it is a strong as solder but it can be a bit more convenient and leave less of a clean up operation.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Nice work on those plinths Keith and the completed bollards look great.  I enjoy seeing your clever work methods and jigs to produce these small identical parts and the shroud brackets are another example of this.  Great stuff.
Gary
Completed Scratch Builds
Link to comment
Thank you Gary.
Progress seems to be slow at the moment, made more so by the sudden cold spell. Not much fun in the workshop over the last few days and hence limited time.
I applied tape to the rails in the areas of the shroud brackets and marked the centre line. While I was at it I started to glue in the winches.
I cross checked photos of the bracket positions against the plans and found them to be accurate.
I marked off the positions for the brackets and drilled the rails to take the bracket spigots. The brackets were then glued in using CA glue. DSC09837.thumb.JPG.fee5aa61f7165e5302569a8c12a7a3b1.JPG
And a few more shots of the installed winces:-
DSC09840.thumb.JPG.cbc5ecd9054ecf6b872ec712efb3aeb8.JPGDSC09841.thumb.JPG.c1532261ab7e1fd753fed5157fe5d18d.JPGDSC09842.thumb.JPG.f1c36ba06bc8efc9bc4ef709b2cffc2b.JPGfullsizeoutput_1fb0.thumb.jpeg.e8bbffb691bf3feb5261b62b04bfbfe7.jpegfullsizeoutput_1fb2.thumb.jpeg.4ec6a74f9f412fab6a747214a4519fa7.jpeg
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
The weather has been somewhat on the cool side and as a result the workshop has been declared out of bounds. I have consoled myself by sitting in my arm chair planning the next steps and making manufacturing sketches from my stock of photographs. I have been focusing on the foredeck and in particular the various features around the anchor chain.
In the next photograph you can see a pair of bollards and a couple of chain guides hiding under a plastic canoe.
Here are the same features with their location better defined albeit with a loss of detail.
The rear most pair appear to be fixed guides and scaling of the photographs enabled me to produce the following sketch.
The front pair are quite tall and slender. The lugs will make manufacture of these somewhat more than a simple turning job.
Finally I returned to the "chain locking device" that was the subject of a previous discussion.
I took the advice that this was some sort of pawl lock and I imagine that it operates something like the depiction in the following sketch.
Scaling from photographs produced the following sketch.
The weather is forecast to become more stormy and a little warmer so I hope to manufacture these items over the weekend.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
The workshop conditions over the weekend have been tolerable so I have done a bit more brass work.
The chain guide bollards were a straightforward turning job. The only complication was I needed rather small turning tools so a bit of grinding was necessary. In the photo they are temporarily placed on the deck minus their circular wooden plinth which will be made later.
Having scratched my head for as bit I decided that the lug on the slender bollards would be more easily created if I made the bollards in parts with a split at the lug position. I therefor turned the top portion and then cut a slot to take the lug. The lug itself was milled to shape and then parted off to thickness. A 1/16" central hole was drilled along the axis of all parts for location purposes.
The lower section of the bollard was then turned and its square based was milled. All parts were assembled on a central rod and glued with CA glue.
I then made a start on the chain lock. I decided that I could make the 2 pawl devices from a piece of brass bar of 1.0"x.55"x.25".
I needed a thickness of .2" so I reduced the thickness with a fly cutter. I then drilled the 2 off 1/16"holes for the pivot point of the pawl. fullsizeoutput_200f.thumb.jpeg.89891afb0c70f51d1c09ab6e130d7dbd.jpeg
I then cut off the waste material.........plus some that wasn't waste material..............the cutter slipped in the collet. So the plan changed to making 1 pawl device from the piece of brass.
I milled the circular profile by pivoting the brass in the vice around a central pin (actually a 1/16' drill) - taking a succession of horizontal cuts will the end mill.
fullsizeoutput_1fbf.thumb.jpeg.3cac6c3aecc000206c81c8ae29cd4bf8.jpegfullsizeoutput_1fc0.thumb.jpeg.8b88532c971dec50fdd2f4f234378c1f.jpeg
With a light filing I had the desired circular form.
I then slotted out the centre using a slitting saw.
I repeated the process to create a second pawl body.
The two parts were then aligned through the pivot hole and stuck together using double sided tape.
It was then back to the mill to cut the ramp angle on the in-feed side.fullsizeoutput_2013.thumb.jpeg.0fd82f0188225776cbbfd6e3eb35fa0d.jpeg
With the ramp cut the two parts were cut off to height with a slitting saw.
I hope to finish tomorrow.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Coming back to the lugs for the shrouds etc. (have been travelling last week and couldn't follow progress): how would they have been attach to the bulwark on the prototype ? Somehow, I would have expected some sort of chainplate to distribute the stress or the stanchions taking this function (albeit they are leaning the wrong way for this - or perhaps the right way in order to prevent the bulwark being pulled in by the shrouds).
No comments on the metal-work ;)
Link to comment
Eberhard. I don't have any decent photographs of the area as it is very congested - lots of blocks and halyards obscure the view. The plans show reinforcing steelwork between the lugs and the deck - although not in enough detail for modelling.  As it wont be visible I don't plan to reproduce.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
It is pretty miserable outside today but at least the workshop is sitting at a comfortable 9c (48f).
I made the pawl handle from a scrap bit of square section tube .250" outside and .025" wall. I cut a piece of mahogany .2" square and glued it in the tube to provide strength while I machined it. I then drilled a 1/16" hole towards one end to create the pivot point for the handle. I then drilled a second hole in the side furthest away from the pivot holes to take the eyebolt. I then parted off the handle to the required width (0.1") on the Byrnes saw fitted with a slitting saw blade.
I then hand filed the end with the hole to form the radius and remove the adjacent side. I then threw it away dissatisfied with the accuracy of my filing. I repeated this whole process a second time with the same result. I was taught many years ago how to file perfect radii but I had never tried it on such small parts (.05" radius). Anyway I made myself some filing bobbins from mild steel and did the job properly.
I did a test fit on the pawl body and then went on to make the eyebolts (.09" diameter) as per the method previously described.
The eyebolts were then soldered in place. While I was at it I soldered a location spigot on the base of the pawl body.
Finally I cut some 1/16" rod for the pivot and assembled the parts.
The small chain rollers were then made - not much explanation needed as the photos say it all.
fullsizeoutput_2019.jpeg.0bde0a5b79185f12b07f07d410984daf.jpegfullsizeoutput_201b.jpeg.751f519b1f2f208ae18354e090dc338e.jpegfullsizeoutput_201c.jpeg.18915b7759e6b2b5c81a482396bdeed5.jpegfullsizeoutput_1fd9.jpeg.2b20db9869f65e34149ee1179deea1e0.jpegfullsizeoutput_1fda.jpeg.8562d8a8649dd9c4f19870c293e80c4e.jpegfullsizeoutput_1fdc.thumb.jpeg.114ad813cf638a93332462214526e08a.jpeg
I then got on with fitting the various parts to the deck.
The wooden plinths were made and positioned using card templates.
The positions for the chain pawls were likewise located using a template.
The pawls and chain rollers were then glued in place.
Finally I found a bit of chain and tested the run.
The chain is a bit large really. It has 11 links per inch and I think I will try something smaller before I commit.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Lovely work on the pawl Keith filling it with mahogany is a great Idea. I will save that one for later.
Michael
Link to comment
9°C being 'comfortable' ? That's just above freezing ! You Brits are crazy (at least concerning temperatures) - but I knew this from my years in Nottingham (when I first moved up there and looked for a place to rent, I visited one that was advertised to have 'central heating' - well it hat a single gas-fire that was located centrally in the apartment ...).
Link to comment
Lovely work Keith, what's a file bobbin?
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
6 degrees in my garage this afternoon after work, managed 45 minutes, that was it!
Previous builds-
Among others 😁
Link to comment
Paul we call them filing buttons, it is usually a piece of steel like a smooth bobbin that is hard and acts as a guide for filing once you get to the bobbin you cannot file any further.
Michael
Link to comment
Paul - Michael is correct and bobbin and button both seem to be used. Ideally they should be left loose on the shaft so they can rotate. Once you have filed down to the bobbin / button it rotates and the file rolls over it without cutting - hence you stop cutting the metal being filed.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Yes Paul - its amazing what a few degrees can do. I too find 6 degrees pretty uncomfortable. The temperature seems to have been dropping throughout the day so tomorrow may be a workshop avoidance day.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thank you all for visiting and commenting. Much appreciated.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Stunning work on those 'gold plated' ground tackle fittings Keith ;) :)  Miniature working versions and they have cleaned up beautifully.  Do you give them a bath in 'pickle' or other solution to do this or simply polish with files and stone etc?
cheers
pat
Link to comment
9 degrees, cold. I laugh in your general direction!
I lived in the lovely little city of Orange for 30 odd years and as long as the sun was out and it wasn't windy I would happily wear shorts and T shirt at 9 degrees, luxury!!
Mind you anything over 26 and I'm ready to call it quits!
Link to comment
10 hours ago, BANYAN said:
or other solution
Pat:_
Tough you is Bedford.
10 hours ago, Jim Lad said:
If you're not liking your current cold spell you could send it over here
John - Cold is fine - its the overcast greyness that really depresses. Fortunately today its wall to wall sun - but very cold.
thankyou all for your feedback.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
For a while I have been thinking that the bowsprit foot would make an interesting project and so I decided to tackle it next.
fullsizeoutput_2064.jpeg.dd65d90f12e14a2c3434182cf55791c1.jpegfullsizeoutput_2066.jpeg.494b7a5e50b24ee724cae3292042f3ec.jpeg
I find that solving machining problems is a lot of fun and in this case the step in the profile of the foot (Item A) caused a bit of head scratching. The oblong boss (item B ) was a lesser problem to resolve.
The brass name plate at the back of the foot is quite nice but at scale size the larger letters are circa .05" high so I don't think I will be trying to reproduce them.
Through a combination of plans and photographs I was able to sketch and size the foot.
I decided the best way to produce the step was to make the foot from 3 parts labeled 1,2 and 3 in the sketch. The foot on Germania is made from a silver coloured metal which could be stainless steel but my guess is it may be aluminium. The colour makes it quite a pronounced feature so I decided to reproduce this by making the foot predominantly from aluminium.
I started the manufacture by cutting a 0.650" wide block from a 2" x 1" piece of aluminium bar. I just love hacksawing thick metal sections like this!!!!!! Having cut the block I reduced it to .55" wide by .775" high by 2" long.
DSC09926.thumb.JPG.1cf6ba7030546e11b52bbd8ad83dabbc.JPGDSC09927.thumb.JPG.0191412c9de3909cda7ca5e7bb8469ad.JPG
I then drilled and reamed a 6mm hole through the block .5" from the narrow edge. Apologies for the mixed units my reamers are all metric.
I then used the reamed hole as the location for milling the outer radius of the top.
The next step was to slice off and finish to thickness the central part of the foot - item 1 in the sketch. With this removed the surface of the remaining material was reduced by .025".
A further slice was then cut off and finished to size to create item 2.fullsizeoutput_1fe8.jpeg.f39f13520265d09c82883b1d4eae404a.jpeg
The next step was to start profiling the shape of item 3. To do this I needed a 1" diameter cutter. As I don't have one I used a fly-cutter instead. I set this up by positioning the centre line of the cutter spindle directly above the edge of the machine vice and then indexing across by .5". I then set the fly cutter blade against the side of the vice to give me a fly-cutter diameter of 1 inch.
fullsizeoutput_1fe9.thumb.jpeg.64cc4f1b2b4995b30be59b290d004a41.jpegfullsizeoutput_2020.thumb.jpeg.af2fd1b109c5a606df7df87d108f511b.jpeg
The kick up at the front was then removed on the mill before the curved face was finished by draw filing.
Part 3 was then glued to a 6mm steel rod and transferred to the lathe.
Here the face of the 6mm hole was cut back with a boring tool to form a flat seat of the bowsprit.
With this done I applied a little heat to break the glue bond and then hacksawed and milled part 3 to length. Finally I removed the centre of the foot to form 2 toes and drilled the holes for attaching the belaying pins.
The part finished foot was then assembled. I hope to finish it tomorrow.DSC09950.thumb.JPG.7d9183f299e5b403f9fa77cc38896aeb.JPG
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
