Arthur Wayne
18th Century Armed Longboat by Arthur Wayne - Model Shipways - Scale 1:24 - Small
I've been working on this kit for a little over a month now. I delayed posting a build log until now, I wanted to make enough progress to be certain I wouldn't be creating yet another unfinished build log. I'm in the military and will be changing duty stations later this year so I'm hoping to complete this build before move day arrives. This is my second model ship (I guess this is technically a boat). My first kit was the Artesania Latina Bluenose 2, which I built back in the mid 90's. I got to the 90% finished stage however I used several coats of very glossy polyurethane on the hull and deck and then realized I hated how it looked. I ended up giving it away to a friend. I'll get my build log caught up in a number of posts. First the obligatory box photo of the kit:
I read through the manual numerous times to ensure I understood each step of the build. The manual is somewhat lacking and a few extra photos of some critical areas would have been nice. Also there is some vague verbiage which I will cover in later posts. Unfortunately the plans are not to scale, they seem to be a 101-102% enlargement. So far from what I can see, they aren't actually needed for the build but I do find it odd that they aren't scaled to the kit. Aside from these issues, I think this a pretty good quality kit, neatly packed and nothing damaged or missing.
After shaping the rabbit and beard line, I installed the bulkheads. I did have to adjust several that sat too high or low so that they would meet the rabbit. I deviated from the kit by omitting the supplied strong back which is glued down the center. I chose to use 1/8 square basswood in segments so as not to pull the bulkheads out of plum. This also prevented all but 1 of the bulkheads from splitting during the build and kept everything plum while it was planked. If I could go back and do this over, I would have drawn a light pencil line connecting the bottom of the bulkhead cutouts on the sides of the false keel, this material is removed after the hull is planked. A pencil line would have made a handy guide when cutting the false keel down. If you build this kit, make sure the joint between each former and the side of false keel is securely glued, when the inside of each bulkhead is removed and the false keel is cutdown the resulting bulkheads are just a butt joint against the false keel.
Finally I did cheat and only tack glued the keel to the false keel with gel CA which is easy to break free without splintering the wood. This will allow the planking at the bow to be sanded easily giving a nice tight fit when the keel is glued back on.
Longboat2.thumb.JPG.2715fea4f7ad81552e5351736c386943.JPGLongboat3.thumb.JPG.e28cee01b7e859c894cff085bbb13ae2.JPG
I faired the bulkheads with 180 grit finishing with 220 grit sanding blocks I made for this build. I also made various length blocks for up to 400 grit sandpaper. Despite my best efforts, bulkhead 4 still ended up sitting a bit too proud (with the hull upside down). There is a small knot in the keel near the stern. Since I originally planned to paint the lower hull it didn't concern me but now I have decided not to paint the lower hull so that knot is going bug me till the end of my days.
Longboat5.thumb.JPG.d297a68f07cd3c0f1d33b003c863d3e7.JPGLongboat7.thumb.JPG.3f3968f334deb328fb9c72c46660aa27.JPGLongboat6.thumb.JPG.f043a12843f898191815d0e10aa5bf03.JPG
I also dowel pinned the transom to the keel because it seemed a likely candidate to be knocked off. Since the transom will be painted the dowels will never be seen. It was cheap insurance, the transom stayed put all the way through planking.
Share this post
Link to post
Share on other sites
With the bulkheads faired I was ready to start planking. I used medium CA to glue all of the planks. I did find that I had to pretreat the bulkhead edge with a drop of CA because the wood soaks it up so fast the planks will not bond. I let the pretreated bulkhead edges cure for about 1 minute before gluing the planks on. The garboard plank was easy enough to form. The second plank not so much. The curve in the garboard per the instructions requires the next plank to be edge bent to the point basswood will not bend. I tried hot water, boiling water, steam, even an ammonia water mix but that much bend and the wood just collapses. To make life easy, I spiled the forward half of the second plank from a sheet of basswood I had on hand (I ended up buying 3 more sheets at Hobby Lobby). The aft half of the second plank was soaked in hot water, clamped in place and allowed to dry before gluing per the instructions. Also prior to gluing any planks on, I sanded the interior side of the plank with 220 then 400 grit sandpaper and chamfered the mating edge. I also colored the unchamfered edge of each plank with a pure graphite pencil. After the 3rd plank was on I installed the top 2 planks. The instructions would have you install 4 planks first but the 4th plank has a lot of bending at the stern and I wanted the frame to be a bit more rigid before trying to fit this plank.
With the top 2 plank installed I added the 4 plank. I threw away my first attempt, clamps and wet wood equal dented wood. I realized that if I let the plank run long, I would use a scrap of plank and a binder clamp to hold the plank in place while it dried without denting the wood that will be on the model. I also spiled the forward half of this plank run from my sheet wood stash. I became very familiar with the forward half of the 3rd and 4th planks because later in the build I tore them out and remade them, a couple of times! LOL
Longboat9.thumb.JPG.8e5c5933a8c0bebd28bb51940170d00d.JPGLongtoboat10.thumb.JPG.a1abe9b813f8ba253157c7f399ed3254.JPGLongboat11.thumb.JPG.f7bb968d9484aa9c56701498f48257c3.JPG
Share this post
Link to post
The instructions say that the 4th plank (from the keel) is the "hardest" to form and I dreaded how many attempts I would make. Turns out I learned enough from the first 3 that it wasn't so hard to form. I then started planking down from the top. I think I spiled all of the forward half of this boat's planks, I just can't get the wood to edge bend the way it needs to for this model. I ended up spiling about half of the aft half of the planks as well. For me, it's the path of least resistance. This spiled plank I hope demonstrates how much of an edge bend a straight plank would need, and then it needs to bend in a plane 45 degrees off axis from the edge.
I borrowed Chuck Passaro's technique to spile planks using tape. For this model frosted scotch tape was laid on the mating plank as flat as possible in short pieces. Some planks required many short pieces of tape to ensure they laid flat while others could use longer pieces. The goal is for the tape to lay perfectly flat on the mating plank. Halfway through the build I realized I could put a few witness marks on the installed plank, and transpose those to the tape. This really helped when shaping the ends of the plank at the bow. I then ran a pencil on the edge of the mating plank.
The tape was carefully pulled off the model and laid on sheet wood. My technique was to fix the end of the tape and then lower the tape so that it laid flat. I would then press the tape down being careful not to smudge the pencil line.
With the top edge of the plank cut I used a simple compass I made from scrap wood so that I could draw a line 1/4" parallel with the cut edge. As you can see I waste a lot of wood, but 2 sheets is enough to plank this entire boat and they sell for $3.59 a sheet so for a few bucks I'm all for making my past time pleasant. Maybe I should build a miniature wood burning stove, I have enough scrap wood to heat a 1/24 scale house in Alaska all winter long!
Finally this photo shows the spiled plank laying on the model with no glue. The slight bend needed at the stern requires minimal pressure to get it to lay flat on the bulkhead.
Share this post
Link to post
Looks like you are off to a great start. The increase in plan size seems to be a common problem with plans being printed, I have run across this even having CAD drawings reproduced locally. I now add a one inch reference square to all my CAD drawings and check when I pick up the drawings and have had some off by 5% and had them reprinted to the correct size. They are suppose to calibrate machines every 10 days which I am sure most printing operations are not doing.
Keep up the great job!
Share this post
Link to post
Thanks guys! xken, luckily the plans are for reference as far as I can see so the size issue isn't stopping the build. I only find it odd because I have built dozens of RC planes over the years and never ran into plans that weren't to the scale of the model. Anyway the show goes on!
After the last plank went down I removed the keel and sanded the hull to close to where it needed to be. Once satisfied I reinstalled the keel. I've been using Titebond 2 for everything aside from the planks and that's what I used to permanently attach the keeI. I did add a couple of short lengths 1/8" x 1/8" stock to register the keel at the bow, those will be removed later.
With the majority of the sanding done I decided not to paint the lower hull. I wasn't 100% confident that the planking in the stern area wouldn't require some filler, since it didn't I moved forward with tree nails on the entire hull. It was actually seeing all the models on this forum with tree nails that got me reinterested in building some boats.
Longboat18.thumb.JPG.d2858b975b974948e0a8752808ae8ec2.JPGLongboat19.thumb.JPG.94bb829785ffabcd86d79b0343d38118.JPGLongboat20.thumb.JPG.724578ff9809e04207854efd15a9713c.JPGDSCN7714.thumb.JPG.1176f99cdbc65bd60456b5047b7ab919.JPGLongboat21.thumb.JPG.1c5bc19b600a18a79dfa6f48ac73b62f.JPG
Share this post
Link to post
Prior to starting the tree nails I final sanded the hull down to 400 grit. Again copying Chuck Passaro I used black monofilament for nails. I bought 10 and 20 pound test, the 20 pound test is .4mm diameter and chose to go with this. I've never seen black monofilament, this stuff may be of dubious quality because it ran from black to a translucent smoke. I threw a lot of it out as I went, if it was translucent in went into the bin. I started out holding the hull up to the light and using chart tape to demark the left and right side of the bulkheads. When I started drilling I realized that with over 1,000 holes to drill it would be a miracle if I didn't miss a bulkhead and spoilt the planks on the interior with a hole.
When I started on the port side, I chose to mark where the bulkhead was using a pencil on each plank. Then I ran the chart tape over the pencil lines erring on the side of caution. This worked out pretty well and I'm happy to say I didn't "hole" a single plank.
Longboat24.thumb.JPG.5310ef74791f9dc849ceae00fbde5cb1.JPGLongboat25.thumb.JPG.927b3d22dddf7ab7fdcbc9dbb66f4e92.JPG
Initially I was trying to slice the monofilament off flush with a brand new straight edge razor but this was tedious and didn't work that well for me. I switched over to sprue cutters and they worked great, I could lop those whiskers off on a whole run in the time it took to slice through 2 or 3 with a razor and it required less sanding to get them flush. I used medium CA dispensed on a plastic bag to glue the mono. Just a dip in the CA and insert. I also found flat jaw needle nose indispensable for inserting the mono in the tiny holes, tweezers of all makes and models were tried to no avail. It took a total of about 6 work hours to get all the nails in, working 15-30 minutes at a time. What a weird way to spend free time!!
Share this post
Link to post
With the treenails installed I final sanded the hull, again down to 400 grit. Then I went on to remove the center section of the bulkheads and my temporary brace at the bow for the keel. Although not seen in this photo I also sanded the glue residue off the interior side of the transom, where my strong back bracing had been attached.
Next I brushed on a coat of wipe on poly to the exterior. I planked a 6"x6" x 1/4" thick basswood to experiment with various stains and finishes. I settled on just brushing on a coat of clear satin wipe on poly. Sometimes the simplest solution really is the best! Basswood isn't the prettiest wood on the planet but the wipe on poly improved the appearance.
Longboat28.thumb.jpg.4bd56f8bdae12d6458adb76cedaae843.jpgLongboat29.thumb.jpg.29baa3dc15f29fa0f9324d1fd496a790.jpgLongboat27.thumb.jpg.cf5210db79c7287c542f83f8fc00ec76.jpg
Share this post
Link to post
Great job on the planking and tree nailing! Just FYI look at the second row from the bow at 5th and 6th plank up from the bottom. I marked mine as I planked using a .5mm mechanical pencil while I could see the bulkheads and just pressed the lead straight down. This left a pencil lead mark even after sanding.
Share this post
Link to post
Thanks xken, and what a sharp eye!! I think missing those 2 nails is the model ship builder's version of being snow blind. LOL I just realized, aren't you the same Ken that built the prototype and did the instructions?
Share this post
Link to post
Guilty as charged! I will look forward to your progress and feedback. Just a note again on the plans they were 100% size when sent to Model Expo so the size increase is due to what I mentioned above about reproduction.
When designing kits the challenge is always the instructions. M.E. wants short and sweet and as few pages as possible while some builders need ever nut and bolt explained. I always try to put myself in the builder's head while writing the instructions and strike a happy compromise between novice and experienced.
Keep up the great build you have going. :cheers:
Share this post
Link to post
I am so glad to see another log on this model.  I have been completely stymied for several weeks trying to do an adequate job of planking using the 1/16x1/4 strips.  I struggled though the lower planks  and thought the uppers would be easier.  The bow double curve was impossible for me to accomplish.  I tried heat, water, ammonia and all combinations of them and could not get the bends to form properly.  The instructions make this look so easy and completely ignore the problem of getting the planks to lay flat on the bulkheads.
I have made one practice bow strip following your approach.  It's not there yet but it shows that spiling is by far the best way to get a good result.  I will be removing much of what I have already done in order to get a much better end product.
Thanks for the detailed views and I look forward to following the rest of your build.
Share this post
Link to post
Thank you Nils!
Tiger65 I was in the same exact boat, pardon the pun. So far I've made parts for 2 boats, one set you see, the other set is in the bin! For me spiling planks from a sheet saved a lot of time and frustration. Since the sheet bass wood is so cheap I wasn't shy about throwing away a plank if it didn't fit right. About halfway through I started getting repeatable acceptable results. Also I was able to sand the interior side of the planks before installing, since they would be visible later and impossible to sand smother once attached. I dreaded the last plank, I figured it would take many attempts but it fit so snug glue wasn't needed to hold it in place.
Share this post
Link to post
With the exterior complete I started on the interior of the hull. I was worried about breaking off bits of the bulkheads that sat proud of the sheer plank and trimming them down level with the sheer plank was the next step. I started by creating a witness line on the bulkhead. I used a small machinist rule to span the hull at each bulkhead set with the edge of the ruler on the sheer plank. I then drew a light pencil "witness" line from below the ruler on both sides of each bulkhead. This is not a "cut to" line, it's to get me close enough while keeping the bulkhead tops level. This is pretty much per the instructions.
With all of the bulkheads marked I shaved them down with a single edge razor blade. I made thin slices, the grain of the bulkheads is horizontal and the wood wants to split if you try to take off too much at once. This was actually pretty quick and easy work. I left each bulkhead top just a smidgeon proud of the sheer plank and finished touching up with a manicure flexible file. The top sheer is curved so it is nearly impossible to shaved the bulkheads flush to the sheer without the razor blade digging into the sheer.
In this photo you can get an idea at how thin of slices I was taking.
With the bulkheads trimmed down I started chiseling out the false keel. This was quick and easy work using a chisel blade in the exacto knife. The grain of the false keel runs parallel with the false keel so some caution is needed to not split the wood. My advice, take thin slices at a time.
With false keel whittled down it was time to start fairing the bulkheads. This is ALOT of sanding!! Hours and hours of sanding..... I used 120 grit to do the majority of the work, then went back over everything with succeeding finer grits to 400. I used a piece of the manicure nail file (the kind that are foam with sandpaper on each side) that I cut in half length wise and about 2" long wrapped in sandpaper. This worked really well, the nail file had just enough flex to get the correct angle on the bulkhead while stiff enough to not just round off the bulkhead. I also used a 1/4" x 1/16" scrap of plank as a batten where the thwart risers will go (3/8" below the top of the sheer plank) to ensure the bulkheads were sanded so that the thwart riser would lay flat against the bulkheads. Since the bulkheads needed to be adjusted vertically to the rabbit when they were glued to the keel, on my model at least this resulted in some bulkheads being higher or lower than they should have been resulting in, more sanding.
Although the instructions do not address this, at the bow there is a block that is a lamination of the false keel and the bow block fillers. This sits proud in relation to the sheer plank and needs to be sanded down so that the cap rail will sit flush. Sanding against the end grain of a 1" square block of laminated wood is hard going!! I made witness marks on the back and sides of this component and used a tiny disc sander attachment in the Dremel to sand the majority down. I finished up with the chisel blade exacto and finally some light sanding with a sanding block. I don't think it needs to be perfectly sanded flat and flush, I don't think it will be visible in the finished model but I was just getting the hang of this sanding thing so I went for it!
I will apply a coat of poly and paint the inside of the sheer planks before installing the floor boards so I skipped ahead a little and installed the stern locker braces and stern locker wall. I made a jig from a piece of scrap plank that was long enough to span from sheer to sheer and then glued a 3/8" long piece of scrap plank perpendicular to it to mark the transom and bulkhead interior used for the stern locker wall. You can see this simple jig in the photo above, its between the pencil and the bow of the boat. Oddly enough the instructions tell you to save the inner portion of bulkhead #7 when you remove it for later use. On page 20 of the instructions they tell you to use the center area of bulkhead 6. I will confirm 6 does not fit, it is in fact #7 that's used. I did have to make a notch for the false keel but that was pretty easy.
Tomorrow I'll apply poly to the interior and then wait a few days to apply the paint and continue my build. Thanks for looking!
Share this post
Link to post
Arthur , I just noticed you used bracing between the bulkhead centers. Great idea as one of mine( #2 I think ) moved during planking and I didn't notice till I was installingthe thwarts. Had to fiddle those around to make them " look " parallel.
Share this post
Link to post
Work has been keeping me busy so my progress was slowed a bit. I added the floor boards which contrary to the instructions ended up not needing to be soaked in water for edge bending. The center board is tapered and due to the lay of the outer boards there's very little actual bend in the bow and stern areas. With the floorboards installed I added the supports for the cockpit and bow platforms. Essentially you create an L from the specified stock (I think it's 1/8" x 1/16") and then span the appropriate bulkheads.
Next the cockpit and bow platforms are made up from 1/4" x 1/16" plank "scraps". Trust, I had plenty on hand! Like the hull planking I used a graphite pencil to simulate caulking and later black monofilament to simulate iron nails. No clue if this is accurate or not but I really like the look Chuck's Medway Longboat so I copy catted.
These platforms were more work than I expected. My first attempts left too big of a gap between the platform and the hull sides and bulkheads. These are evolutionary rejects, and the templates I made. The rejects fitted in place allowed me to make a more accurate template. Since the edges of the platforms need to be chamfered to fit reasonably tight, the extra 1/16" height the scrap platforms provided made the difference needed. Also once the planks are glued together I recommend adding a couple of cross braces on the bottom. If they fit snug, you risk snapping them at the glue joint trying to remove them, ask me how I know.
With the platforms built and nails installed, I was finally able to apply wipe on poly to the floorboards, platform supports and platforms. Once those were dry I then painted the top two courses of planks and bulkheads. I used Vallejo Red applied with a brush. 2 coats seemed to do the trick. All I have left is to glue the platform in now. In the mean time, I've experimented with making a scraper to shape the thwart risers, hopefully they will be a short easy project. Thanks for looking!
Longboat42.thumb.JPG.8c5642f83d03c889e59c499045e7d3a0.JPGLongboat43.thumb.JPG.94241ebc678bbd100b0ae17a5f85c3c7.JPGLongboat44.thumb.JPG.60d1417bc8dfef7d3ce3b0b251e6a69d.JPG
Share this post
Link to post
It's surprising how much time it's taken me to install the thwart risers! Most of that time was spent deciding how to best ensure they were spaced correctly in relation to the top edge of the top plank and bulkheads. I chose to use masking tape to mark where the top of the thwart would go, this worked like a charm for me.
I also deviated from the instructions and rather than emboss the decorative line on the thwart risers I made a simple scraper from a razor blade. This worked pretty well however basswood is soft and splinters easy so I found light easy passes yielded the best results.
With the thwart risers shaped, I added monofilament nails and then glued them in place with medium CA, working a few frames at a time. I also deviated from the instructions and chose to place the thwart riser joint at bulkhead A rather than bulkhead 5. The joint would be hidden by the thwart and in my view it would be easier to place and glue the shorter pieces rather than a 12" piece with a  2 1/2" (I think) extension. I'll brush on some wipe on poly after I get the thwarts done and the cockpit seats worked out.
I made the thwarts but will get to those in my next post. In the mean time I discovered that the laser cut parts that make up the cockpit seating aren't going to work. As you can see from the photo, this part is short, by over a 1/4". The back edge needs to be beveled so that it buts up against the transom and this part isn't even close to long enough. Not the end of the world, I'll make a substitute but it is disappointing to have laser cut parts that don't work. I also figured out that I shouldn't have rounded off the thwart where it meets the cockpit seats since these parts would have been butt jointed, well at least I have a template to remake this thwart!
Here are the cockpit seat parts together. With the decorative lines matched up the part that makes up the stern locker lid is, yet another 1/8" too short to match the other parts. This is just an odd mistake to see in a kit like this. Again not the end of the world, just a little frustrating.
Also for anyone building this kit, in hindsight I would lower the floor in the cockpit/stern area (way too late now). I think the cockpit floor is way too high, the seat tops once complete will be barely 12" scale inches higher than the floor. I know people were shorter back then but they weren't short enough to sit on 12" high seats!
Edited by Arthur Wayne
Poorly worded
Share this post
Link to post
Hello Arthur,
I am building this boat for my first plank on bulkhead build.  I am very impressed by your good work.  I only hope I can live with mine after I get through as I am really struggling along.  I have almost taken the position that makers of the original prototypes probably make mistakes and lived with the workarounds and so will I.
I will be following your work with anticipation as I move along and I may have some questions for you from time to time if you don't mind.
Paul Schulze
Share this post
Link to post
Thanks for the compliments SandyBay and Dr PS!
Dr PS feel free to ask any questions you may have at any time. I am definitely no expert and I'm sure some of my work arounds could be accomplished in a better way. All I'm hoping to achieve is to help others avoid some of the pitfalls I've run into.
Share this post
Link to post
Arthur, did you use the taping method when spiking from the second strake on or did you cut the second and third strakes by trial and error and error?
Share this post
Link to post
Dr PS, For the top (actual top of the boat) 2 strakes I used the kit supplied 1/4" wide stock. The garboard plank was also kit supplied stock. The next 3 strakes going up from the garboard I only used kit supplied 1/4" wide planks for the aft half of the run, the forward half were spiled. I did mark each bulkhead where there was going to be strake joint so they were staggered in the locations identified in the plans. After that I don't think I used hardly any of the kit supplied planks, maybe a few for the aft half of the run but only a couple. In hind sight for me, I think the curve the instructions have you create on the forward end of the garboard is too tight of a radius. On page 12 it states to mark the plank 1-3/4" down from the end. I would recommend marking it at 2-1/4" instead. I also recommend trying your best to get the end (pointy bit) of each of the strakes to fall where they do in the top right photo on page 15. I freely admit I threw away a number of spiled planks but the cost of the wood sheets is so low I was only wasting my time. I wish I could have gotten these planks to bend for me but they just wouldn't and for those that did, it was near impossible to not have them dented beyond redemption by clamps.
The difficulty in this kit for me has been that you have to worry about how the planks look on the inside as well as outside. Hope that helps, if not I feel free to let me know. By the way I'm just south of you at Fort Hood, hope the twister near Waco missed you up there.
Share this post
Link to post
Thanks Arthur - No bad weather here -never know in the springtime. I think you’re right about the curve of the garboard.  Looking at the top right picture on p 15 it would seem that the curve goes from bulkhead E to bulkhead C rather than a bit past bulkhead D. I have the garboards cut to the suggested 1 3/4” and I am also experiencing some wood collapsing.   Before putting on the second strake, I may try filing or sanding the garboard into a gentler curve as removing the garboard may cause some bulkhead and/or keel damage.
Share this post
Link to post
I've been slowly chipping away at this boat, can't say I'm in the home stretch yet because the Army has a way of surprising me with trips that aren't on the calendar.
As previously posted, the supplied laser cut cockpit seat parts are undersized and unusable for me. I made replacements from basswood sheet. I think this boat is 50% MS wood and 50% Hobby Lobby basswood. I made a number of attempts to scribe the decorative line around the inner perimeter of the seats but basswood is not amendable to my methods. I elected for a simpler version for the sake of a decent finished piece.
For comparison, this photo shows how the kit supplied part just wasn't going to fit. I'll be interested to see if anyone else encounters this same issue.
I made the thwarts with the kit supplied wood and scribed the decorative line with my homemade scraper. The kit supplied laser cut thwart/mast brace didn't work for me. For starters the semi circle cutout for the mast is 1/16" diameter larger than the mast. Because of that, the supplied casting can't be shaped to follow the contour of the mast. I also think the 4 holes for the belaying pins are too large to be scale, and are definitely so large the supplied brass belaying pins slip right through. At this point I doubt anyone will be surprised I made a replacement which you can see in a later photo.
With the thwarts installed my next step was the cap rail. This proved easier than I expected. I made templates from 80 pound card stock as detailed in the instructions. I made the cutout for the stem, and traced the outline of the top strake with the model flipped upside down. I then made certain to split the template down the center. I made the cap rail from a single piece for each side, versus 2 shorter pieces per side as show in the instructions. The kit part uses 2 pieces per side I suspect, so that they can keep all of the wood 12" in length or less to fit in the box. Anyway this was a pretty easy step.
Once the cap rails were in place I added the cannon mounts and breast hook. The kit supplied breast hook was no usable for me, perhaps due to the way I shaped the cap rail in the stem area. I made a replacement easy enough.
Longboat56.thumb.JPG.ddd5f4c8a8fc9a4f036d65bf87e8bf92.JPGLongboat57.thumb.JPG.adc7f53dd3cbf501cd5e845de6d1353d.JPG
This photo shows the replacement thwart for the mast mount. You can also see the holes for the belaying pins were made a more scale diameter. Now the metal mast mount fits around the mast like a glove.
I also added the thwart knees doing my best to make sure they were parallel with the nearest bulkhead. Painted the thwart knees multiple coats before gluing in place, in these photos are just friction fit. An oddity is the round cannon mount. There's not mention of the 4 laser cut holes in the instructions. I surmise someone at MS thought they were a good idea for some reason? Perhaps they are for simulated bolts, alas there are just enough nails in the kit for other uses and not even a spare. Eventually I filled these holes in with spots of wood putty.
Another error with the laser cut parts via the thwart knees. If the cap rail was 1/8" thick they would work, but it's only 1/16" thick so these are cut 1/16" too deep. I used scrap 1/16" thick wood to bring the depth up to 1/16". This is pretty easy to do, but an odd mistake for the kit to have. Luckily these parts will be painted.
Another deviation to the kit I decided to make was to paint the thwarts red. I noticed photos of the museum models Chuck has posted in his Medway Longboat kit post had red thwarts and liked the look. Since the majority of the interior is unpainted and the hull is unpainted I think the extra color is complimentary. In the photos I have only applied 2 light coats, I have since painted several more coats and I like the look.
Share this post
Link to post
Very nice work and useful information Arthur.   I will let everyone know about the kit supplied materials when I get there.   Still working at a sub-snail pace.
Paul
Share this post
Link to post
Great work! thanks for the heads-up on the probable head-aches. I just received this kit yesterday so I will surely use your log to adjust the course. At first, I couldn't believe there was so many problems! But you pointed them out very well. I'll just go very carefully and take nothing for granted.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
