U-552 Type VIIc Submersible by yvesvidal - FINISHED - Trumpeter - 1/48 - Plastic
Looking great.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
The part of being very lethal.   Well done.
Link to comment
the hull looks great!  great coverage too :) .......at one time I used to use Humbrol as well as Pactra.   very good selection of colors and didn't go by a number system at the time.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
There won't be much in terms of updates. I am waiting for parts and paints.
Can you believe that Trumpeter omitted to provide the Waterline markings on their (otherwise nice) decals sheet?
I realized that yesterday and was really surprised by this mishap. Fortunately, I found a British company Accurate Model Parts that do sell the Waterline markings as well as a few other things for the Trumpeter kit.
I also have on order some Tamiya paints and clear coats and do not know how long it will take to come here. Tamiya products are starting to be very rare if you want a color other than the Fluo and Neon Orange and Green.
Yves
Link to comment
Still a few small updates, working on details that make a difference:
1) The anodes on the diving planes, provided by the RCSubs PE set:
2) The menacing teeth, used to cut nets and underwater cables (again pimped up by RCSubs PE set):
3) The rings to attach the crew/sailors when working on untangling the propellers or doing the maintenance of the rear diving planes (Intermountain parts in 1/48th):
4) And finally the net/cables cutter on the top of the bow (again pimped up with RCSubs PE set):
Little details, very fragile, but which are slowly turning this kit into a realistic Type VIIc model.
Yves
Link to comment
coming along quite nicely........the paint and the detailing looks super!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
what....you can't just sling it over your shoulder?!?!?!  :D   just kidding :rolleyes:  now for the bit and pieces......really nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I have been trying to finish the deck, before painting it. Lots of small details and PE parts went on it:
Then it is masking time:
And a coat of automotive primer to harmonize the whole:
Once, the Primer is dry, I will be in a position to start painting the deck. Some pictures:
Yves
Link to comment
Very nice work - looks so lifelike.
OC.
Current builds
Completed works.
Link to comment
Deck has been painted:
The bow and stern platforms are painted with Tamiya Dark Grey XF-24. The rest of the deck is Tamiya XF-64 to simulate the German tar that was spread on metallic deck to prevent sailors from slipping at sea.
That tar, originally darker was fading very rapidly with the sun light and the salt. Once the hull has been clear coated, I will try to add some shadings and washes in different locations.
That PE deck from RCsubs really stands out. I have been watching some pictures on the web, of the same model where the Trumpeter plastic deck is painted.... and there is absolutely no comparison. It was a lot of work but worth every dollar and drop of sweat. The entire hull is now ready for the waterline decals (just received them from England) and a final mat clear coat to seal everything before the big challenge of weathering.
The decals from AMP:
Once set on the dark hull, they will be more visible.
Yves
Edited by yvesvidal
Link to comment
Beautiful work yvesvidal!!  :imNotWorthy:
In the coming month I assume your going to put her under glass? Also what are you going to use for a mounting base?
Current build project:
CSS Alabama 1/96
https://modelshipworld.com/topic/20148-css-alabama-by-jonathan11-revell-196-scale-kit-bash-90-historical-accuracy/
Finished build projects 2018:
H.L Hunley 1/24
CSS Arkansas 1/96
Link to comment
Jonathan,
To be honest, I have not thought about all these details yet. The Mounting base will be very similar to what you are seeing ow, but with longer Brass tubes. I also have to design a base that can include some electronics and switches, for the lights and motors.
We will see. This is still far away.
Yves
Link to comment
Just as carl says  - looks so real.
OC.
Current builds
Completed works.
Link to comment
It already looks extremely deadly.... a ship killer.
Link to comment
Yves - I have been following your build for quite a while now and I must say, it's a very impressive build. This model is not for the faint of heart, even if built straight from the box. Your details and crew interaction is great (the battery room comes to mind).
I am also building this kit as U-371 in the Med. The kit is almost a blank canvas for anyone that enjoys superdetailing. However, on such a large model, as you well know, it can get overwhelming depending on your desired level of detail. I've never been a rivet counter but I'm finding myself careening in that direction. I think I need to jerk the wheel back straight again!
I wish I had your level of ambition. I'm amazed at your progress on a weekly basis. Keep up the good work!
Modeling U-371 on 16.10.43 at 1800 off of the Algerian coast in CJ7722 during their 15th patrol.
Link to comment
Thank you Katuna for all the praises and compliments.
As a matter of fact, I have also been following your build log on the AMP web site and find your attention to details absolutely incredible. I am actually planning to use some of your research and Tore's publications to increase the level of detailing of this model and make it closer to the prototype. Tore, Prince, you and a couple of other guys are an incredible source of information that makes the building of this model, so much more entertaining. Keep up the good work and let's finish that Engine compartment.
Yves
Link to comment
Wow, thanks the compliment. I'm just getting back into modeling after about 40 years. Things have changed just a tad. The bar has been raised to the stratosphere! I'm just playing catch up.
Glad you're getting some use out of my posts. However, Tore and Don are the true masters. I just translate information.
Ah, the Engine compartment. Unfortunately I only get an hour here and there to work on my boat so it's taking a lot longer than I would like. Let me ask you, which compartment was the easiest to get through? After I complete the Engine room, I'm going to need something to bring me back down. 🥴
Link to comment
For me, the front Torpedoes room was the easiest.
Then the Officers Quarters was a lot more tricky because I have been trying to replicate the fuel tank and batteries, underneath. Plus the additional bunks.
Finally, the rear torpedoes compartment has been the most delicate because I have two electric motors and the capability to spin the propellers.
I have not done anything else. I am focusing right now on the main hull and learning how to weather a model. Like you, I have been away of plastic models for the past 40 years, pretty much.
Yves
Link to comment
Folks,
I am at a cross-roads and a little bit overwhelmed by the extent of what needs to take place. I would like to realize a hull that has seen some actions, but I doubt I can be up to the task.
I could go with three different approaches:
1) Perfectly immaculate hull, freshly painted and somewhat un-realistic. Pretty model, quickly done and politically correct.
2) Slightly weathered, mostly saline corrosion and tiny spots of rust here and there. Some algae and salt deposits along the water line.
3) Really beat-up, full of corrosion and salt deposits. There are quite a few models on the web like these and they are outstanding and absolutely mesmerizing of realism and perfection. But these are made by artists and take an enormous amount of work and skills that I do not have.
I have been toying and trying some practices on the removable hull (starboard). I am basically trying to stay with the second approach and these are some of my results. If it is not good enough, I am going back to Option #1 and repainting that section of hull.
Saline traces coming out of the flood vents. The algae is rather missed..... :-(
More saline deposits on the bottom of the hull.
Some attempts at playing with rust and paint scaling.
What do you guys think? I have not touched the other side of the hull yet. Just practicing...
Yves
Link to comment
Yves,
Follow your heart and see where it leads.  You may try #3 and realize you're way over your head.  You many do #1 and then be mad later because it's too pristine.  I'd say use #2 as your baseline.  If you feel comfortable and up to doing more, go for it.
I do like the rust by the way and other aging things you've done.
Which raises a question... how often were the subs pulled out and put in drydock?
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
