U-552 by yvesvidal - FINISHED - Trumpeter - 1/48 - PLASTIC - Type VIIC U-boat
Working with resin definitely takes some adjustment in assembly. We are so used to working with styrene which is forgiving and welds together well (some plastics better than others). Resin is brittle so you can't force it into fitting. It also requires considerable clean up and it has the added bonus of lung damage if you breath the dust. But, it also has the ability of having incredible levels of detail. It's really is a give and take proposition but once you get used to working with it, you can have some very accurate models.
Cleaning all those tiny parts can be nerve wracking for sure but the end result really is worth it. Hang in there buddy, it's looking great! Throw a coat of black primer on it to highlight the seams and flash and use you sharpest blades. It'll look fantastic.
Modeling U-371 on 16.10.43 at 1800 off of the Algerian coast in CJ7722 during their 15th patrol.
Link to comment
Share on other sites
Both look good, Yves.   From here, that's going to be tough call on which one to use.
Link to comment
Well, both guns are now complete and I still do not know for sure, which one to mount permanently on the U-Boot.....
Ideally, If I had known earlier that Eduard was offering this kit, I should have mixed parts of the Trumpeter, RCSubs and Eduard gun kits, to make the most realistic model possible.
The Eduard kit is definitely more precise in the casting and offers some details that the Trumpeter parts miss completely. On the other hand, the Trumpeter/RCSubs kit offers a gun which can pivot and swivel. It is also more solid because of the flexibility inherent to the polystyrene. By comparison, the Eduard resin parts are very brittle and are just asking to fall apart if poorly handled. It is also completely static which may not be a bad thing.
Maybe I should design the gun bases so that they can be interchangeable, based on my mood..... 😉
I think I am going to retain the Trumpeter/RCSubs version but it is truly a tough choice. I have agonized long enough and must keep moving if I ever want to finish this model.
To end that presentation, a couple of pictures for a 3D rendering of the gun and the real stuff:
Yves
Link to comment
I don't envy having to make that decision, Yves.   Both are masterful pieces of work.
Link to comment
Yves,
Difficult decision indeed. You could place one on the sub itself and the other as it’s own static display since they are both beautifully crafted.
-Brian
Current Builds:        Completed Builds:
Mississippi River Towboat Caroline N.                                                    HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways
Link to comment
That is really a close call. Both look great.
As you say: choice depends on the actual part you are looking at. I prefer the Eduards-version because of the breachlock does look a bot more detailed. But taking the handwheels as your main part, the other one is (marginally) better, at least in the pics. I guess that placed on the model both will be looking fantastic.....
Jan
Link to comment
checking in on your progress Yves........I must say that your armament looks stellar!   so much detail.......agreed that the one you don't use,  can easily stand as its own model!  you've built quite a model........large scale subs are definitely the way to go ! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Well, check this out.
Google translator working well for description.
Link to comment
Well, well, well.... We are coming very close to a closure, so to speak.
As previously mentioned, I have taken the difficult decision to use the Combo Trumpeter/RCSubs gun on my model. The Eduard is very nice and will probably find its way on another display with a couple of torpedoes and the infamous Enigma machine (at 1/48th).
All the rigging is complete and has been done in the following way:
- Around the conning tower, all the wires are extremely thin copper wires soldered to the PE parts provided by RCSubs. Let's not forget that Trumpeter completely gave up on the rigging and most details of the deck.
- The antennas are made with 0.5 mm diameter rubber wire. This prevents any dramatic accident if a hand or curious nose was to come in contact with the rigging.
- The ceramic insulators are simply replicated with Playdo putty, painted in rubber black.
The flag is made with real fabric and was procured through England. The Svastika may be disturbing to some, but that is the price to pay for realism:
It is a big and heavy model. More details to come....
Yves
Link to comment
5 hours ago, amateur said:
Looking good.
Is there a way to get the flag hanging somewhat more realistically? "Hanging" like this it does no justice to the realism of your model.
Jan
Jan,
Most definitely, I agree with you and I am not too happy with that flag, even though it is made of fabric and expensive. The fabric is definitely too stiff.
I will try to go back to aluminum foil and the decals provided by Trumpeter. It may look better.
Yves
Link to comment
Chuck explains it here. (In his log of Cheerful) Printing on very thin paper. Sounds easy. But I guess some trial and error is needed before it works.
On 4/25/2017 at 5:12 PM, Chuck said:
Thanks guys.
The flag was made from the tissue paper you use to pack a gift with.  Its white....you can buy this stuff anywhere but this particular stuff is very thin.   I dont have a brand because I literally went into some old boxes we use to wrap up Christmas presents and took some out of the box.  But you should experiment with different brands and thicknesses.
I basically use a jpg. image of the flag which has been sized in Microsoft word.  You could skew your flag ahead of time in the program to make it easier to shape but I didnt do that.  I just printed out the standard rectangle.
First you print out the flag on normal paper so you can see where on the paper the flag will print.  Then you carefully tape the tissue paper over that image on all four sides...the tissue paper being slightly larger than the flag.  Then print the flag again after placing the paper in your printer again.
Cut the flag free from the tissue paper after it dries.  Cut it right along the edges with no white space showing.   This next step is important.  The tissue paper is so thin that the ink will soak through to the other side but NOT entirely.  So the first thing you need to do is flip the flag over and spray the REVERSE side with some Krylon Matt fixative.  Dont be afraid to spray too much.   This will facilitate the ink soaking through to the back side further and it will look like it is literally printed on both sides.   Then after it dries flip it over and spray the front side.
Shape it to suit with various size dowels.  You can also spray the fixative more to really soak it because this makes it easier to shape...you can do this several times if need be.  Once dry it holds its shape.
Then I poke a hole with a sharp awl in the two corners so I can lash it to the flag halliard.  Done!!!:)
Hope that explains it well.
Link to comment
Yves, this is absolutely incredible work.  Just caught up on your log and I'm just completely astounded.  I would have given a thumbs up to every one of your posts, but I didn't want to blow up your notifications box :)  Nice job!
For flags, you can also see if you can find a cloth/vinyl flag.  They are easy to fold and add PVA to hold the creases in place.  I've seen some take aluminum foil and paint it but my guess is the flag is too complicated in design to do that.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Fantastic work Yves. Every time I get to look at your progress I am even more amazed than the time before.
I would think that the flags on submarines would remain in pretty good condition as I don't think submarines in any country flew them very often while on the surface. You normally only see them when they are entering or leaving the harbor to and from patrols. Of course when returning from patrol they would often also fly flags indicating number of "Kills" and sometimes a broom from the periscope. This also seemed to be the practice of a number of countries.
Have you decided where you are going to display this masterpiece?
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
11 hours ago, yvesvidal said:
Well, I followed the Chuck Passaro's recipe (thank you Amateur) and came out with something which is more realistic than the plain fabric flag. Not perfect, but a lot more palatable:
Slightly worn out by the harsh Atlantic weather....
Yves
Hi Yves,
the flag looks way better now - but it hangs on wrong side. The small cross must be near the pole. Here is an original.
happy modelling!
Miki
Link to comment
2 hours ago, Veszett Roka said:
Hi Yves,
happy modelling!
Miki
Miki,
That was my first impression.... but then I saw a picture where the little cross was away from the pole.... and that created the confusion. I will fix that mistake.
I am trying to find the picture that misled me....
Yves
Link to comment
I am trying to find a good place for all the spare parts I have. If anybody is interested,please drop me a Personal Message or take a look at this:
https://www.ebay.com/itm/Trumpeter-kit-U-552-1-48-Extra-and-Spare-parts-Interior/264894407130?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
I'd rather send these rare parts to someone who will do good use of them.
Thanks
Yves
Link to comment
I am waiting for a professional photographer friend to come over and do some nice quality pictures, but he is struggling with the software of his Sony cameras or too scared to come to my place.... Go figure. In the meantime, here are a few low quality pictures I took of the finished model.
I will try to add more pictures taken at night, as it is more dramatic.
Yves
Link to comment
Awesome build - super interesting log as well. Congrats!!
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
