Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
57 minutes ago, Kevin said:
looking very nice indeed considering the limitations you have with the hobby, very well done OC
Thank you so much,    I'm trying my best.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Not much to report  -  I  just did some tidy up work on the paintwork with fine wet and dry, then I masked up the right side of the fuselage  ready for  Black brush painting same as the left side.
OC.
Current builds
Completed works.
Link to comment
Anyone used this putty -  I have just brought a tube from flee bay,  I hope to use it around the canopy to try to hide an un-even seam  that cant be sanded.
OC.
Current builds
Completed works.
Link to comment
I have used something similar made by Vallejo paints on my Huey deck. Seemed to work OK. What I liked about it was that I could put it on and then wipe off the excess with a cotton tip dipped in water. It filled very evenly with no excess mess and didn't need to be sanded afterward. YMMV
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thanks lou,    this is what I need to fix   -
OC.
Current builds
Completed works.
Link to comment
It should do the job. Just apply it along the seam between the canopy and fuselage then take a damp Q-Tip and clean off the excess leaving a bead along the seam. Let it dry and paint.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
I use it too, OC.  Works easily, minimum cleanup and no smell for the Admiral to squawk about. I think it's marble dust in an acrylic medium.
Ken
Started: MS Bounty Longboat,
Link to comment
O C the model is coming along great, it will be a real tribute to your Dad, I would not worry about a few flaws in the paint, I think they will be hardly noticeable when done and I'm sure after a few missions she would have had a few scratches and dents. Keep up the good work,
Best,
Ed
Link to comment
Thanks Lou.👍
OC.
Current builds
Completed works.
Link to comment
8 hours ago, Javlin said:
I have the same putty like it over toothpaste tube products a bit hard to squeeze out.The Mitchell was the first plane I have used it on spreads easy and clean up is easy. ;) Kevin
Thanks Kevin.👍
OC.
Current builds
Completed works.
Link to comment
Thanks Ken.👍
OC.
Current builds
Completed works.
Link to comment
Best,
Ed
Thank you for the kind words Ed.
OC.
Current builds
Completed works.
Link to comment
More progress  today  while listening to my Aircraft scanner  at all the aircraft  going over the pond to the US  (not)   been so quiet.
Anyway on with mossie,   where were we  -  oh yes masking ready to paint the Black on the right side fuselage, same procedure  wide soft brush and gentle steady  brush strokes, then dried with the dryer between coats, I put about four layers down  then moved on to the next masked section, then when it was dry I removed the tape,   it was leaving a small ridge (cant be helped even with burnishing the edge  - till I get some Tamiya tape)  so it was a case of a light wet sand - that tended to remove a little too much Black  - so back on again.
I took about three attempts till I was happy with the finish  - then I buffed the whole paintwork to get a shiny surface ready for the decals.
Next I decided to do the bottom of the  first wing  freehand with my wide brush  (its about  3/4 Inch)  I started  with the section closest to the fuselage  - it needed no masks as I was controlling the flow of paint  - four or five coats and it was looking quite good, next I masked the top part of the engine cowling  and started to apply some Black all over the nacelle  - again about Four or Five layers, and I left it there for the night.
Here's the pics  as stands at the mo.
OC.
Current builds
Completed works.
Link to comment
Just brought a roll of Tamiya Tape online  will be here thur  (I hope)
OC.
Current builds
Completed works.
Link to comment
The Mossie is looking the right proper intruder, OC. Well done.
Ken
Link to comment
Thanks Ken,   I think I decided right  by doing the night bomber  - just  like the contrast with the camo.
OC.
Current builds
Completed works.
Link to comment
Thought this was interesting  - Mosquito production line.
Off the net.
OC.
Current builds
Completed works.
Link to comment
Bit late, but my two pennies on the putty: Works quite nice, quite a smooth finish, dries fairly quickly in the tube's nozzle though. Had it blocked a couple of times, all the way down to the tube's opening
Carl
Link to comment
Best,
Ed
OC,  I couldn’t agree more with Ed.  Having such a connection makes this a really special model.  You’ve actually inspired me to think about a model for my dad - he drove muscle cars before having my two siblings (a Mercury i think in the 60s and a Dodge Challenger in the 70s that I distinctly remember).  I just need to find the years and models that would be appropriate.
Edited by Landlubber Mike
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you carl,  perhaps keeping a pin in it to keep the tube opening clear.
OC.
Current builds
Completed works.
Link to comment
8 minutes ago, Landlubber Mike said:
Lou, I couldn’t agree more with Ed.  Having such a connection makes this a really special model.  You’ve actually inspired me to think about a model for my dad - he drove muscle cars before having my two siblings (a Mercury i think in the 60s and a Dodge Challenger in the 70s that I distinctly remember).  I just need to find the years and models that would be appropriate.
That would be great mike  - please build it on here as Im sure many will look forward to seeing what ever you decide to build.
OC.
Current builds
Completed works.
Link to comment
coming along in leaps and bounds, very nice, love the mossie factory photo
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Thank you kindly Kevin,
OC.
Current builds
Completed works.
Link to comment
The one wing painted and touch ups done - ready to do the same to the other.
Pics also show a dry fit.
OC.
Current builds
Completed works.
Link to comment
The mossie looks great, the paint looks fine to me OC👍😁
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Looking sharp OC!  This paint scheme is going to look fantastic.
Mike
Link to comment
Thank you so much.
OC.
Current builds
Completed works.
Link to comment
Thanks  mike,    not too bad for brush painting the Black  (thought it would save masking everything)   not forgetting it will look better with a flat spray top coat to knock the sheen off it and even it all out,   don't forget back in the days  paint was brushed on using Tekaloid  paints.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
