Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
1 minute ago, cog said:
Nearly there ... quite a turbulent build
Yep,   certainly has mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Nice recovery Brother.... now just a little decal action and the recovery will be full...
Quote:
Link to comment
Thank you kindly,   yep  I have been able to rescue that decal situation🙂
OC.
Current builds
Completed works.
Link to comment
OC.
A good lesson for not giving up, I hate to see great work go to waste, thank you for not giving up on it...
Quote:
Link to comment
Thank You for taking an interest, it so builds one's confidence  you know.
OC.
Current builds
Completed works.
Link to comment
57 minutes ago, CDW said:
She's a beauty, a very worthy tribute to your Dad.
Thank you kindly.
OC.
Current builds
Completed works.
Link to comment
22 minutes ago, Javlin said:
Nice save all the way around :imNotWorthy:
Thanks mate,    took a bit of fiddling and masking and masking  oh  and masking,   but I'm quite pleased with the finish.
OC.
Current builds
Completed works.
Link to comment
Great rescue OC. Looking damn good. NICE painting 😁
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you edward,  some way to go yet, but atleast it  shows the general finish,    she still has to be  re - decaled  and to have  her flat coat over her, then a few  small bits and pieces  like the  bomb bay doors - 500lb  bombs,  entrance  hatch door and ladder, and a radio  wire.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
OC.
what do you use for the radio wire, EZ line?
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
I have some fine fuse wire 3amp I think  might try that,  it attaches to the leading edge of the tail, what I might do is to drill a pilot hole in the edge of the tail then push the wire into it with a dab of ca, then attache the other end to the pe wireless pole on the fuselage.
OC.
Current builds
Completed works.
Link to comment
Hi all,    right  the decaling process has begun  -  I started on the tail again with the two tail flashes,  then I moved onto the two fuselage roundels, all these went down fine, next it was the side code letters, again these were placed  but on the one side where there is a strengthening bar  I am having to have a play around using a few coates of micro sol  to get it to settle over the bar shape.
It is currently sitting waiting for the decs to set.
OC.
Current builds
Completed works.
Link to comment
Evening all,    spent a good day  working on the  remaining decals,   great getting them placed,    will  leave than a good few days  before  applying the flat top coat  (again its  the Tamiya brand lacquer)   just hope it doesn't react with the decals.
Again  pic show the wing just dry fitted.
OC.
Current builds
Completed works.
Link to comment
633 squadron flies again!!! looking good OC.
Current builds;
Completed:
Link to comment
Bloody OUTSTANDING!!!!
Nice job, Great Recovery my friend...
Quote:
Link to comment
Thank you kindly Edward,    the only thing  that is scaring the living daylights out of me is  spraying the Tamiya TS80  Clear top coat  rattle can, I have no choice  it has to be dulled  and the rattle can is the only  smooth way I can do it,  so yep  it is worrying me.
OC.
Current builds
Completed works.
Link to comment
Thank you so much EG,     thought I would mention  - the sqn code on the side  is meant to be sloping like that.
OC.
Current builds
Completed works.
Link to comment
I know that my friend, it follows the line of the reinforcing... Beautiful job with those decals...
Quote:
Link to comment
Yep  pleasure  to work with this time around😉
OC.
Current builds
Completed works.
Link to comment
3 minutes ago, Canute said:
Nicely done, mate. What a recovery. 👍
Thank you Ken.
OC.
Current builds
Completed works.
Link to comment
very nice recovery OC....  the decaling puts you back to square one again!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Denis,    yep  just a few detailing jobs to do  - Bombs,  bomb bay doors, entrance hatch, ladder, radio pole, comms wire,   and the Biggy  - top coat  to dull it all down.
OC.
Current builds
Completed works.
Link to comment
Found an interesting pic on the net  of the exact  plane I am building  -
OC.
Current builds
Completed works.
Link to comment
5 minutes ago, Fright said:
To quote a movie line, "You can't kill a squadron"... not with you around. This fighter looks FaNTaSTiC !!!
Thank you so much Robert, that was so nice.
OC.
Current builds
Completed works.
Link to comment
Excellent recovery, OC.  Looking perfect.
Link to comment
Thank you Mark,   was close  I have to admit it  (had to get the Whitewash out to paint the air I made Blue)   bit my tounge  a bit also  a few times.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
