Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
1 hour ago, Old Collingwood said:
Yep,   the other side is fine,   I  have just this moment  gone down stairs (as its night here now)  and put a coat of micro sol  over the affected  decal/s  I will check them in a couple of hours to see if  (by miracle)  the micro sol has  worked - not holding my breath though.
The problem is  that top coat of Tamiya Laquer  is key  as it will either stop me working on the decal, or  if I decided to try to remove the decal using tape to pull it off  - I think the laquer will stop it  or at worst pull a larger area of paint and laquer with it.
OC.
I agree the top coat is key, it was fine until that was laid... TBH, I have NEVER ever seen anything like that, all the other stuff wrinkles, popcorn ceiling effect, bubbles, orange peel I have all seen and fixed, this one has me stumped... that looks like hippopotamus/elephant skin......
Well let me know how the second application of Decal set/sol works.... I have a suspicion that it will not work through the overcoat......
This is one bird that doesn't want to be finished or likes the attention, it seems like it's taking on a personality..... We have all had them, your not alone...
Quote:
Link to comment
Share on other sites
17 minutes ago, Roger Pellett said:
Can’t hit the Like button on that one, OC.  Why is that some projects continually fight us?  Maybe turn it into an airplane half model?  Seriously, I hope that you find a solution that allows you to consider this model finished.
Roger
Thank you Roger   - yep  frustrating.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
My suspicion  is that I applied the top coat a bit too heavy on that side  or perhaps it hadn't shrunk down as well due to the ridge it had to sit over, especially  the end of the ridge  causing an akward lump in the middle, possibly a bit of trapped air - that mde it an esy target for the top coat to loosen  and craze the way it did.
OC.
Current builds
Completed works.
Link to comment
I don't think it was trapped air brother, that's what micro sol and a pin is for, and you would see it as soon as the decal is dry cause it wouldn't lay down, more like trapped water IMHO......
Quote:
Link to comment
Just been down  put another coat of micro sol  over the decals, will try to put a few layers  on leaving an hour or so between layers  - just to see if it does anything.
OC.
Current builds
Completed works.
Link to comment
OC.
This
Some decals don't like lacquer over top. But since it didn't give the other decals a problem, I suspect it's a matter of too heavy a coat. This is one of the limitations/difficulties of rattle can paint, a lack of flow control. Most of the time, decals will behave well to a light coat of clear lacquer, but a heavy coat will cause issues. It likely puddled here, which caused it.
Link to comment
3 minutes ago, CDW said:
This
I will  try my best  to see what the repair or part repair options are - wll see what micro sol does, then  (as I assume a barrier is on the model now)  I will try another flat coat over the top  to see if that might help hide the  wrinkles  (failing that its a  Good anti - wrinkle cream)😉
OC.
Current builds
Completed works.
Link to comment
Do like many model ship makers do.  If the other side is good, then the bad decal side is the "wall side".
Link to comment
Indeed  Mark, thats what I will have to do  as  despite several  attempts with Micro sol, the orange peel  aint going know where, the top coat has sealed them in.
OC.
Current builds
Completed works.
Link to comment
1 hour ago, CDW said:
This
I would agree, the decal floated in the lacquer.... there was a suggested way to kinda fix it on an online belog, but I've never had to do such... Hide it by gradually building up the clearcoat until most of it disappears.....
Never tried it but at this point the only resolution is to hide it, or remove it and do it over..... I know cost becomes a factor... And since it is already under the clear lacquer....
Quote:
Link to comment
So,   apply a couple more coats of flat  over the top?
OC.
Current builds
Completed works.
Link to comment
OC.
I was reading about this on another forum... it was a way someone dealt with a similar issue.. (his was excessive bubbling after a gloss coat) successive light wet coats to raise and smooth out the surface.... it's the only thing I've found after a lot of searching the net.... other than ripping it off again and redoing it...... it actually didn't come out too bad...
Quote:
Link to comment
Thanks mate,  Very much appreciate and am thankful  to you for  searching stuff  for my build, its help like this that makes this site so Special.
OC.
Current builds
Completed works.
Link to comment
OC.
did you use decal fixative, or only the softner?
Carl
Link to comment
I used both mate  - both micro set  then micro sol.
OC.
Current builds
Completed works.
Link to comment
Just a small update  fellow followers  following freely  forever figuring  forensic  feactures,     so  I played with the damaged decals, I decided to weather them to give them a worn look,  I did this by gently sanding with very fine watered  wet and dry, I did this both sides to keep a uniform look.
Pics later after I have done a few light top coats.
OC.
Current builds
Completed works.
Link to comment
OC.
good choice OC
Carl
Link to comment
34 minutes ago, cog said:
good choice OC
Thanks mate.
OC.
Current builds
Completed works.
Link to comment
Here are a couple of  pre  top coat pics  to show the affect after I have  wet and dried  over the decals  gentley  on both sides.
OC.
Current builds
Completed works.
Link to comment
OC.
I think that was your best option my friend... The world hands you lemons, make lemonade.... I think that bird wants more than a pretty paint job, it wants to depict itself as the workhorse it actually was.... You have a special bird my friend....
Quote:
Link to comment
Very nice recovery, OC! A flat coat and some weathering and no-ones the wiser.
Ken
Started: MS Bounty Longboat,
Link to comment
Thank you for those kind words.
OC.
Current builds
Completed works.
Link to comment
Thank you kindly Ken.
OC.
Current builds
Completed works.
Link to comment
I like what you’ve done, such strong perseverance. I enjoy watching everyone work through these issues because I don’t have anywhere near the experience to think of these solutions. A great learning experience for me!
Link to comment
Just me digging my teeth in  and refusing to let it beat me,   but thank you  kindly  for saying that.
OC.
Current builds
Completed works.
Link to comment
So after doing some internet bashing  on the subject  (not fly flishing🙃)    later I will do a bit of shading using my pencil  along some of the detail lines, then I will  go over picking up the high spots with either a dull alum or white  dry brush, as around the region where the dameged decals, there is a  fuselage locker  and the strenthening rib, the same needs to be done to the other stab where  had to give it a re - paint.
OC.
Current builds
Completed works.
Link to comment
Sounds like a good plan, OC.  The recovery so far is looking great.  Nothing like a few worn spots and some scars on a war bird.
Link to comment
Thanks mate,  just my logic   - cover up the blemishes with blemishes   - just intentional ones.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
