Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
3 hours ago, Edwardkenway said:
Yes yes sorry bout the log hijack but we is all eyes again OC
3 hours ago, Egilman said:
WE are quick about yanking that jack handle aren't we.... {chuckle}
Just don't say that too loud in an airport ! ;)   [  hi !  jack !  ]
Link to comment
Share on other sites
Read them twice. Read Dudley Pope about Ramage, too. Authors Stockwin, Lambdin and Bond. Engrossing books. :D
But this log is about a vignette "somewhere in England" and a night-flying Mossie squadron. 👍
Ken
Started: MS Bounty Longboat,
Link to comment
Yes yes yes, good authors all.
And yes meanwhile on a sweltering summer afternoon in leafy SE England nothing is stirring??🍿🍿
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Need some lemonade or, dare I say, iced tea? With the Kink's "Lazing on a sunny afternoon" playing in the background.  ;)😁
Ken
Link to comment
I am coming  - just enjoying so sunshine at the moment - will be with you all  this eve  -  "dont dissapear"
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Hi all,   I.m  back   as I promised   - remember I told you all about that under size wheel columb  (suitable just for a child)   well  I  took it out   removed the wheel from the columb, then I drilled a fresh hole under the wheel,  and after finding the correct size piece of dowel (after sanding it down)  I then glued the two together, then I kept offering up the wheel combo to the jeep till I found the right size  - then it was glued in place.
I then went through my decal stash  and found the correct roundal  this was then placed and A few applications of micro sol  are being put over it.
So this is the status of the jeep as she stands now  - with a much better size wheel/columb hight.
OC.
Current builds
Completed works.
Link to comment
Also  next on the agenda  is a Tractor  - this is a multi section build  starting from the bottom up  with the one piece chasis, then the body  -  engine - engine cover - rad unit,   after giving the parts a light tidy up, I first gave the chasis  a few coats of Nato Black, then when dry  I brushed in some dark wash  and finished off with a flat alum  dry brush  - this was then sealed with a flat coat  (all brush painted  even the bodywork)
Then it was the bodywork  this was painted with a few coats  the RAF Grey  same as the jeep, so still two separate assemblies  waiting to be pu together.
OC.
Current builds
Completed works.
Link to comment
Jeep's looking good, OC. Looks good to go.
Ken
Link to comment
Thanks Ken,   just a bit of weathering  on the bonnet  then some flat coat to dull it down.
OC.
Current builds
Completed works.
Link to comment
9 hours ago, cog said:
Jeep looks good OC, but 'ardley used ... straight from th' fact'ry?
Hi mate,   yep  I have a bit more weathering to do to it yet  - but not too much   my dad used to tell me  "if its  still  - paint it  - if it moves still paint it".
OC.
Current builds
Completed works.
Link to comment
More progress this evening  - first I bashed up the Jeep  with washes and high lighting,  then I painted and added  "Red"   the setter,   she jumped up on the jeep  and is sitting on the rear seat  waging her tail, excited by all the activity.
Next  I continued with the tractor adding more washes  and building the engine  that was then fitted in place.
Pic shows the dry fitting of the engine cover.
OC.
Current builds
Completed works.
Link to comment
29 minutes ago, cog said:
Not to shabby mate. Is it the photograph, or my screen calibration, but the tires look almost the same colour as the hubs
There a faded grey/black  but deffinatley  more towards a black side  than the RAF Blue  - the light  (strong from above) probably didn't help.
OC.
Current builds
Completed works.
Link to comment
Thought I should mention that at 1/48 scale these things including the jeep are actually  quite small, the jeep is about 2 - 3 inches long, and my pics are quite close up showing more than 1/1 scale.
OC.
Current builds
Completed works.
Link to comment
Evening all,   I managed  to get a bit more work done on the tractor,  I am basically making it look quite bashed up  dirty  with lots of use, as I asume they would be.
OC.
Current builds
Completed works.
Link to comment
Afternoon all,    after more progress with the tractor  - now we have Two vehicles  finished.
OC.
Current builds
Completed works.
Link to comment
Evening all,     another item was made earlier  in the shape of a ground power unit  - basically a power transformer in a box  with a handle on wheels, I still have to come up with the power lead - this I will make from some 5amp  black wire.
Next up will be a oil tank.
OC.
Current builds
Completed works.
Link to comment
Evening all,    more progress this eve,   first  I found some thin grey-ish wire  I cut it into lengths that seemed about right, then I drilled a small hole in the end, then I pushed it over a plastic pole protruding from the front part of the starter, then I coiled it around the handle and added a touch of ca  to hold it in place.
Next I assembled the oil bowser tank, after painting  I did the same with the hose as I did the wiring earlier,  this time I coiled it round and looped it around the drum of the bowser  and connected it to the feed assembly.
So here is a family photo showing all the bits done so far.
OC.
Current builds
Completed works.
Link to comment
2 minutes ago, Jack12477 said:
Lookin good, mate !
Thanks Jack.
OC.
Current builds
Completed works.
Link to comment
Nice detail OC, it's coming together nicely 😁👍
Current builds;
Completed:
Link to comment
Thank you Edward.
OC.
Current builds
Completed works.
Link to comment
Looks like you'll a well-served flight line, OC.
Link to comment
Thanks Mark,   yep  it will be quite busy  - I have a few more bits and pieces to add  then the figures.
OC.
Current builds
Completed works.
Link to comment
Figure making time  - to be precise  the Pilot, after making him  and painting/weathering  he came to life  but wanted to play with the tractor first, then He stood up on it wanting his photo taken,    then  "play time over"   so he made his way to the Mossie ladder.
OC.
Current builds
Completed works.
Link to comment
Oh my, that's coming together very nicely. You really got the crew to look natural.
Respectfully
Link to comment
Thank you kindly, several more to build yet  inlcuding  me dad.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
