Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
Looking forward to it, OC.
Link to comment
Share on other sites
Thanks mark.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
As well as the Mosi  I  won this on ebay  for next to nothing  - it was an opened box  but all the parts are still in their bags  I have been told  - waiting for it to arrive, it is fitting as its another plane my father  worked on.
OC.
Current builds
Completed works.
Link to comment
1 minute ago, CDW said:
I thing the Spitfire Mk IX was their best looking Spitfire of all. Should be a real nice kit.
I was told  by my farther  they struggled to fit the beafed up engine in the same frame  - they could have done with extending the frontal area.
oc.
Current builds
Completed works.
Link to comment
So!   - It begins,     I couldn't help it  "I had to",
I got the box out  - checked the instructions and found  the first build section (Bomb bay),   so I cut away the first sections needed  then put them in a tub and with the aid of washing up liquid/hot water and a tooth brush, I gave the parts a clean to remove the release agent.
Then when dry  I assembled the main bomb bay floor containing the fuel tanks, and the two bulkheads, this was set aside to dry.
Here are the first two pics  showing the stage so far  and the instructions stage.
OC.
Current builds
Completed works.
Link to comment
Done a bit more  -  I decided to fit some pipework -  for this I used electrical fuse wire,   I  put a small  smear of ca down  then  layed  some  wire, with a hairdryer to set  It set in place - I then did the same to a run underneath.
I then painted both fuel tanks the brick Red colour  - for this I used Red Ocre,   after drying this I added a few coats of  dark wash  - very watery  then dried  in between each layer, the main green shade still needs to be applied.
OC.
Current builds
Completed works.
Link to comment
3 minutes ago, Javlin said:
I like the way that came out OC  looks like a  natural state. ;) Kevin
Thank you kevin,
OC.
Current builds
Completed works.
Link to comment
3 minutes ago, Canute said:
Nice start, OC. The wash makes those tanks "pop".
Thanks mate,  trying to keep them natural  still need to chase the interior green around  then add more  washes.
OC.
Current builds
Completed works.
Link to comment
Off to a great start, OC.  Looking good.
Link to comment
Thanks mark,   its interior green paint time next  followed up with some more washes and a bit of  hightlighting   then some more additions to add, going to build  things in stages like that  - painting and weathering them  as I go  instead of assembling the whole  sub sections and trying to paint/weather.
OC.
Current builds
Completed works.
Link to comment
That sounds like a good plan, OC.
Link to comment
Hi all,   some good work  today  -  I  put  some  interior green down  then ran some washes  over it,   after I worked on the three sub frames - painted and washed, then when dry (quickly with a hairdryer)  I then did some highlighting   - lots more to do yet as it still needs the bomb rails and brackets.
OC.
Current builds
Completed works.
Link to comment
look'in good OC! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
44 minutes ago, popeye the sailor said:
look'in good OC! :)
Thanks denis.
OC.
Current builds
Completed works.
Link to comment
I know of a certain Huey that is in need of a qualified painter such as yourself! Are you certain that you won't stop on over to my place and do some yeoman work?
Great job, and yes I'm jealous!:(:D
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thank you lou,  but save your compliments till I have done the  rattle can painting  - that will be a success  or  fail  operation.
OC.
Current builds
Completed works.
Link to comment
With what I am seeing that will go just fine as well!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thanks mate.👍
OC.
Current builds
Completed works.
Link to comment
You're doing a great job with your washes, OC. The bay walls look perfect.
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks ken,   first time I have done  it with planes  -  first time I tried it was  on my  Warspite Build  then Pearl.
OC.
Current builds
Completed works.
Link to comment
More progress  in the bomb bay  - I assembled and weathered the four bomb racks, these were painted flat alum  then I ran a wash over them.
Oh  and look at what arrived  in the post  -
OC.
Current builds
Completed works.
Link to comment
8 minutes ago, CDW said:
Very nice progress OC, and I like that Spitfire. Excellent detail. Your attention to detail on the bomb bay is paying off.
Thanks craig.
OC.
Current builds
Completed works.
Link to comment
OC
What color are you going to use for the cockpit area. Do all British WW2 aircraft share the same cockpit color?
For US aircraft, it's almost universally zinc chromate green. You can get that color by mixing Tamiya's green and lemon yellow, but they (Tamiya) don't sell a premixed color for zinc chromate. For my current project, I've been using Vallejo Model Air zinc chromate, but recently found out I had bought the only bottle of it in town. If I had known it was that scarce, I would have mixed my own with Tamiya paints. I had to order some Vallejo from another state and am waiting for it to arrive.
Link to comment
54 minutes ago, CDW said:
OC
I understand its the same green interior throughout  (the same  interior green as I used in the bomb bay),
Here is a  pic  showing the green shade       (internet pic   courtesy  of the owner)
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
It is almost the same color they used for the interior of the mosquito here in Everett. The Mosquito starts at about 13:25
There may be some views that can help in your build as well OC.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Here are a few more walk arounds:
This is Kermit Week's unrestored plane not the restored flying plane here in Everett.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
