Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
A tiny bit of progress  today -  I have decided to build her  on a little modification  -  during the Bomber Mosquito's missions  it had a secondary role  where by  it  operated as as  towing escort  for  damaged  planes  from spits  to mosquito's, during the war  there was a surplus of giant paint brushes that came in perfectly  for use as  towing  handles.................
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
a Mosquito on a stick............great! :piratetongueor4:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Bet you dont  know whats its for?
OC.
Current builds
Completed works.
Link to comment
They are considered a delicacy in some places Denis.:D
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
So  -a brief  spell  with no rain  this gave me the chance to  spray the Tamiya Surface Primer  - seemed to go ok.
The stick  was for me to hold it by the way......
OC.
Current builds
Completed works.
Link to comment
After spraying the primer  - its made it obvious  that I made a mess  of the nose, so tomorrow I will take the tape off the nose glazing then I will  put a  fresh couple of  straight  line  masking tape  runs around the circumference of the  glazing  where the  frame ends,   then I will  gently sand around the area to get a smooth transition from the glazing back onto the forward fuselage.
OC.
Current builds
Completed works.
Link to comment
Hi all,    with the Spit  no resigned to the spares department - its given me more time to work on the Mossie,   firstly  I attacked that nose detailing that I had done before  -  I took the masking of the nose  and carefully  re taped it  level with  start of the frame nearest the fuselage,  then I used a very narrow piece of  light sanding stick  - and sanded the strip  I had put on,   this went quite well  with the sanding stick piece being only very narrow  - I was able to control where I was sanding,    after I tacked  it with tape to get rid of any dust  - then I went out side and sprayed a couple of coats of  surface primer just over the front area  - job done.
OC.
Current builds
Completed works.
Link to comment
While the fuselage is drying  I checked the instructions  - they call for the main undercarriage units to be made  -  they are made up from  two side units  and a few other smaller  sections  - its a case of gluing  then supporting  while they  glue,   then  when complete again  support and put on one side.
OC.
Current builds
Completed works.
Link to comment
More added to the undercarriage units  including the mud guards  and oil tanks.
OC.
Current builds
Completed works.
Link to comment
A little trick I  found out for myself  - to stiffen the  spindle parts of the  leg assemblies, I  work  some CA along them with a fine  stick/fuse wire  then heat it  fast with a hair dryer  to set the glue quicker, this really seems to make the thin plastic parts a lot stronger.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
Hi all, a good day today   I did the kind of work  where you feel  your not getting very far - but in fairness  a fair bit was actually done,   starting with the undercarriage units  I painted therm  flat alum  then I put them aside to dry  -  then I  added a couple of coats of paint to the wheels,  after drying with a hairdryer  I then highlighted them to bring out the tread details  - after I painted the hubs  flat alum.
I then studied my idea for extending the front units as the Revell ones  sit to low,   I dry fitted the two engine cowl units  and worked out  how the undercarriage  sits in place, its is a tight space in there  and the legs needed to go in at an angle to fit,  I then worked out if I used a  1-2mm strip  glued it it  and bored a couple of holes  - it  kind of did the trick.   They are not fitted yet  just dry fitted   as there is a system  where the whole wing needs assembling first  - but the flaps also need  assembling and fitting as they are movable surfaces,  this all needs doing before the  engine cowl/undercarriage units can be fitted together.
I also  worked on the inside section of the wing  that will be in view  - like the inner groves when the flaps are dropped  - also  the rads  in the wings were painted then fitted  inside the one section of the wing.
OC.
Current builds
Completed works.
Link to comment
6 minutes ago, SigEp Ziggy said:
Looking good, OC
Thank you ziggy.
OC.
Current builds
Completed works.
Link to comment
looks good OC :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
6 minutes ago, popeye the sailor said:
looks good OC :)
Thank you denis.
OC.
Current builds
Completed works.
Link to comment
Nicely done, OC.  I'm glad you got the height right as I was wondering how you were going to solve that.
Link to comment
I have attacked it on three fronts  - lower the height of the  tail wheel   - put a weight flat spot on the  same tail wheel - and   do what I did with the main legs.
OC.
Current builds
Completed works.
Link to comment
I have worked out what scheme I am going for  - it will be the pathfinders  night version  -
Like this one i found on the net.
OC.
Current builds
Completed works.
Link to comment
You are pulling me leg!
Will you be weathering? Bit a rust, bit a exhaust particles ... you know ... the RGL look for your plane
By the way, very nice progress.Slow is good OC. Don't rush yourself.
Edited by cog
Carl
Link to comment
Nicely done OC!  That paint scheme is going to look really sharp.  Looking forward to seeing this come together.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
10 hours ago, cog said:
Bit a rust,
That would look a little out of place on a Mosquito Carl as they were mostly canvas covered plywood with a little aluminum thrown in here and there.:unsure::D
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thank you, Carl   - I thought I had pulled off  the towing device 😉     What I might do  is to add  a tiny amount of exhaust staining  - hoe that is carefully applied to black  I dont know.
OC.
Current builds
Completed works.
Link to comment
Thank you mike  - will do my best.
OC.
Current builds
Completed works.
Link to comment
Right then   -  I masked  her  according to the Black scheme I have gone for, then  outdoors   I  got  my Semi-Glass  Black  Tamiya rattle can out  - did what  the Pros  suggested  (sat the can in some hot - not boiling water in a cup)   this is supposed to improve the flow from the can.
Dear  I show you .............
OC.
Current builds
Completed works.
Link to comment
Question  -  I sprayed her  about an hour a go  - should I remove the tap now  or wait a bit?
OC.
Current builds
Completed works.
Link to comment
Here is a few pics  - the spray job  and a dry fit of the engine nacelle assembly  just having to do some fettling to get it to fit  - needs a bit of work on a join or two.
OC.
IMG_0192.thumb.JPG.29ab816f5746a75ef5a8caebd4752901.JPGIMG_0191.thumb.JPG.acf8dc4c0d1c8b0000cb175135a36d2e.JPG
Current builds
Completed works.
Link to comment
Just thought  - I sprayed the Black first,  should have  sprayed the two colour camo on the top of the fuselage  first,   then masked slightly over that for the Black, guess when I take the tape off  I will have to gently fine sand the hard edge from the tape, then slightly over-lap the tape on the black  for the camo.
OC.
Current builds
Completed works.
Link to comment
OC.
Looking good, OC.    As for the exhaust and rust.... dry brush some on over the black.  Just make sure the black is dry first.
Link to comment
Thanks mark.
OC.
Current builds
Completed works.
Link to comment
I have to say  - this is the very first  proper 1/48 kit I have built  and the  first go at spray painting, even if it is just Rattle cans, so my routine might be a bit shaky  as I am learning as I go a long   with the aid of lots and lots and lots of reading up and looking at other build logs for aircraft all over the net.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
