oneslim
Medway Longboat by oneslim - 1:24 scale - Bob W
Hello Everyone,
I would to join this build group of fellow Medway Longboat builders.  I have put my 1:48 scale Longboat on hold so as to better understand the spiling process since the strakes are pre-cut.  I had some difficulty with small gaps with light showing through.
Following are photos of my build.
The build board and keel parts laid out.  I have marked the slots in the build board because I got tired of counting them.
Had to use tape to hold the guides in,  they were loose and would fall out.
Keel and stern post ready to join.
Stem and Keel.
False Keel parts had 1/32" scrape added when attaching to the keel to center them for the rabbit.
The long piece glued to the keel.
Attaching the Floors to the Top Timbers.
Test fitting the frames and Keel.
Head on view.
Over all as she now stands.
More to come.
Bob W
Share this post
Link to post
Share on other sites
Looking real good so far.  Well done.  Happy you joined the group.
Share this post
Link to post
Welcome to the group. Just curious, how did you attach the 1/32 scrap to the keel parts?
Share this post
Link to post
Thanks Chuck.
Jeff,  I used a fresh bottle of Elmer's Rubber Cement,  just the smallest amount with a tooth pick.  They just about fall off.  Any residue is erased with off with a white eraser.  Sorry to hear about Your longboat.  Hope You get back on track soon.
Bob W
Share this post
Link to post
Part 2
The keel has been coated with Wipe On Poly and glued to the frames.  Then it was protected with blue painters tape.
The stern was stabilized with a clamp and two guides glued to the base.  The transom dose not move while fairing.  Getting close,  still more work to do on fairing.
Almost there,  a little more on the transom.
View of the bow.
More Latter
Bob W
Edited by oneslim
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
