DKM Graf Zeppelin by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC
You do not seem to have a problem aligning it. Rust colour over the primer, and chipping fluid on top of that, I presume.
platforms look rather spiffy ... but for the final top coat, straight from the factory I might say
Carl
Link to comment
Share on other sites
I’ve been dry fitting the deck over and over and to get it to sit correctly and flush will take it being put down in sections. Then it has to be glued. That will be probably the hardest part of the build apart from the air wings.
As for the primer, if you put a clear coat over the red primer I’m hoping it will weather better.
Edited by RGL
Greg
Link to comment
A lot of detail under the deck (for the catapult) mate; how much will be visible?
Good lock with laying the deck in sections; hope all goes without drama.
cheers
Pat
Link to comment
The lid is on, hardest part of the build now needs a full day of touch ups and the rear support struts under the flight deck. I’ll have to pull off half of the support gussets and glue them flush to the hull.
Everything above the flight deck line can be done after everything below it is finished. Armaments will be done second last to the aircraft.
The massive holes cut cut in the front of the flight deck will house the catapults. 75E33689-2D00-434F-A53B-AAE5E37B593D.thumb.jpeg.10757b17deecb192c1d1bddec51c4e7b.jpeg
Edited by RGL
Greg
Link to comment
did you need to cut those channels........must have been nerve wracking :Whew: I'd be worried about knocking gussets off!  looks really good though.....she's coming along really nice ;)   as usual,  your weathering is extraordinary.......so freak'in good!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I cut them before the metal was attached.
The rear flight deck, supports added plus a few stabilisation struts made from offcuts, paint, rust, rudders now it can stay on the stand. Notice the angle of the rudders which is more like the real thing.
Edited by RGL
Greg
Link to comment
It’s dried rust, as it’s a dark colour it comes up very bright. I might work some scratches into it with a lighter primer colour on panel lines yet. There is a really big flagpole and a quad cannon in the stern that does distract a bit.
Once  I get the deck on I need to paint on nazi flags, landing lines and the weather it. Yes, there will be nazi flags as it’s still historically accurate regardless of it being repugnant.
There will then be every bit as much as detail as Yamato or Ise.
Greg
Link to comment
Finally, I hand painted all the features that are supposed to be metal. There was a tiny bit of over run but after weathering and parking airplanes on top it want stick out.
Next is to paint a big yellow line down the centre and the flags. The wind barriers don’t need to go on yet permanently. Coming along OK.
Greg
Link to comment
Supprised to see a wooden deck on a carrier,     really nice work there greg.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
US and Japanese carriers used wood decking. RN went armored pretty early. The kamikaze attacks off Okinawa disabused the USN of wood decks.
Ken
Started: MS Bounty Longboat,
Link to comment
very nice work
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Very cool!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
I got bleed-thru on my USS Essex carrier deck when I masked and painted the ship numbers on fore and aft ends of the deck. In retrospect, I could have first spraying a coat of flat clear, let it dry, then applied the black numbers. I think this would have prevented any bleed-thru that could be seen. Secondly, maybe should have reduced the paint a little less.
In any case, the wooden deck acts as a wick to pull the paint under the masking.
Link to comment
Link to comment
superb progress Greg!  the deck looks awesome!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Nice work Greg.  Are you going to distress the deck and add tyre marks at the landing area etc?
cheers
Pat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
