DKM Graf Zeppelin by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC
I need new CA. Maybe it’s the turning of the season but it has turned to sludge. I managed to add the gantries and a lot of door that are on the original blueprints but not the model or the upgrade. I’m awaiting new glue before I add 100 or so gussets.
Greg
Link to comment
Share on other sites
15 cm gun housings. I had to cut the barrels off at the stem and drilled holes into the stem to place the aftermarket barrels. I then had to file the tops so they can actually move / rotate inside the hull. The colour photo shows one of the ship’s real guns in Norway.
Greg
Link to comment
I see what you mean but I won't bother as the camouflage on the starboard side will be a very dark blue over this section and not really noticeable. More importantly they completely left out the anchor on the bow (Which I only just noticed today). Simple fix to drill a hole though.
Greg
Link to comment
look'in awesome Greg! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
can't argue with that job Greg..........looks great!  is the outer hull the same color as the lower decks?  plug the openings perhaps?
common Carl....that doesn't look so bad....look at all the nice detail you got there  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
New pupser, eh? Gonna be fun for the whole family. :)
Ken
Started: MS Bounty Longboat,
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
