Zeesboot by Mirabell61 - FINISHED - scale 1:24 - wooden fishing vessel c. 1876 - small
Thank you very much for your nice comment Mark,
the small parts of the engine are taking more time than I thought....., I wanted to do the dome nuts for the cylinderhead from  small brass hexagonal brass bar but it looks like I lost the remaining bit I still had.
In the meantime the housing was painted and I`m working on the cooling tubing with connection to the water pump. Generator and its terminal box are also painted, need to do a bit of wiring, and I`m looking for a suitable mini V-belt or two, perhaps  the thin sealing "O-ring" for wrist watch glasses can do for this. I`ll have to see the jewelery shop in town if he has some old ones in his scrap box...
Will post some more pics when I have all things together
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Share on other sites
thank you very much Peter for your appreciative words,
I`m pleased you like the engine...
Yesterday I received some brass etched fish for the catch together in scale 1:25, with two fish box kits (sides get folded and soldered together). For the fish there needs to be some uppadding, which will favorably will be done "Fimo clay" that can be baken for curing, before the fishes get painted. I decided also to produce some eels in appropriate scale made completely from Fimo clay. Trust that all together this will enhance the working boat character, when done...
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
Many thanks Slava, and for looking in,
have`nt heard from you quite some time now, nice to know that you`re watching this build.....
I`m still working on the engine, installed generator, water cooling pump and tubing and fly-wheel, more to come the next days...
Cheers,
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Wow...brass fish!!!!
Who would have thought of that!!!
And the mesh basket for them too.
Absolutely brilliant idea.
Reminds me of when I made brass etched model locomotives.
The motor is looking good.
I hope you will leave the brass pipes in brass?
Maybe varnish them to prevent them going dull and ugly in the passage of time.
When I made my model locomotives in G scale, I bought some sheets of plastic with hundreds of nut and bolt tops moulded on to them.
One simply slices them off and epoxy or super glue them where you want them.
This could be of interest to you and the engine build?
Keep it going please.
Love it.
Pete
Link to comment
I used to make such bolts and nuts in my pre-lathe days on the hand-held drill: take a piece of brass rod (I actually used small brass nails that turn better, due to being work-hardened from the stamping process) into the chuck, turn a step on the front with a small file, then (using the hex-nut of chuck as guide) I filed the six sides by counting the number of file strokes on each side, finally filed the short 'bolt' that will go into a pre-drilled hole and parted off. You won't produce them by hundreds this way, but it's quick enough for machinery, such as winches or the engine.
Today, of course, I use the lathe and the dividing head on my milling machine.
Link to comment
Thank you very much Pete, Geert and Eberhard,
your answers and input are very much appreciated....
Pete,
model locomotives and marine craft in G scale  often have details that can be adopted of another..
I went looking for polysterol screw head imitates (your pic...) but could`nt  find them in the web net, do you kindly perhaps have a source (link) ?
Geert,
As I could only model the engine from Photos I found on the web, this was my best effort to produce something alike in scale 1:24, am pleased you like it
Eberhard,
I remember , when doing the bolts with dome nuts, that connect the blades to the hubs ((KWdG model) I worked a bit like you described in your "pre lathe days".
Instead of nails as base material I used quite small hexogon brass bar.
Many thanks for your kind input here...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Slava,
a pitty it does`nt run, I would love the sound, tuck, tuck, tuck......
Nils
exhaust tubing, Muffler and tubing through aft bulwark above waterline
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thanks Slava,
yes, I`ve read that somewhere before, think its in combination with RC models on a pond or lake....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nils,
You might check here:  https://jimorrisco.com/
Link to comment
Hi Mark,
many thanks for that link, I`ll check it out...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
The muffler and exhaust looks great.
The nuts and bolts as mentioned are made by the firm Meng.
There are three different sets A ,B and C.
They are 1:35 scale but nuts and bolts are nuts and bolts.
I think you need set A whereas the nut is fastened on the bolt with a little of the bolt protruding.
I bought mine from a local model shop but I have just checked ebay and they can be purchased from there or Amazon.
Just type in
MENG NUTS AND BOLTS SET A
And you should get there.
Pete
Edited by Peter Cane
Mistake
Link to comment
Many thanks for the link Pete,
I found the set A straight away and ordered already... :)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Nils
Great.
You are an excellent modeller and will therefore realise that small details like this make the model.
I will continue to view your blog.
What will you call her?
I have a suggestion ....
Tuc Tuc???
Ha ha.
Pete
Link to comment
Thank you Pete,
I know sometimes I get lost in details, but if the time for completing is not pressing I can try and realise some of the thoughts I have saved in mind, and its a lot of fun. The tuc- engine is the little heart of the boat.
Your name suggestion is not bad, but I intended to call her "Lorbas" as this name was not yet registrated for heritage Zeesboots list, to my knowledge
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
not much progress this tme..
the engine is complete and the sockets for main- and aft mast set in place
Nils
the mesh fish boxes have been chemicaly blackened
the V-belts are from sealings for wrist watch covers
added an oil dipstick
upper right corner : day fuel tank ca. 20 Liter
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you very much Geert,
will start with the removable engine bonnet, that will have some outcuts so the engine remains visible.
Have also added silicone shock dampener pads for bolting the engine down, and with reference and  thanks to Pete`s suggestion I received the small panel with dummy screw heads, these are also installed already, as well as the prolonged exhaust tube that is now leading to the outside hull planking...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you Pete,
Yes there will be several cuts, also in the cabin area giving view to the whole interior. Thanks again for your link to the screw heads, great idea I think....
Nils
bolts holding the gear housing to the machine block, and silicone rubber dampening pads
slicing off the round heads with hexogonal sockets
exhaust to outside (well above waterline)
screws for exhaust tube flange to cylinder
Current builds
-Lightship Elbe 1
Completed
Link to comment
thank you very much Johann,
I had a look at your "La Creole French Corvette....., fantastic work, amazing shipwright handcraft..
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Yes. Any adjoining pipe work would have to have a flange.
I was going to suggest it but it t is your project and you need time to do these refinements.
So I kept quiet in anticipation.
I thing I am just as enthusiastic as you Nils about your model.
I must zip my mouth and keep watching.
Brilliant.
Pete
Link to comment
I keep expecting to see that engine work as it looks like it could.  Wonderful Nils.
Link to comment
Many thanks to Pete and Mark,
and to all who clicked the "like" Button...
today I made the hand-bilge pump, which discharges into the centerboard case, and the upper sill of the centerboard case
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Very resourceful Nils - that’s going into my notebook.  Wonderful engine detailing and so finely done.  Very nice.
Gary
Completed Scratch Builds
Link to comment
many thanks Gary,
your comment is much appreciated...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
