Mi24D Hind by Dan Vadas - FINISHED - Halinski - 1:33 scale - CARD - Russian Attack Helicopter
Looks a bit lightweight but I think it might be a midair refueling boom but I could be wrong.  Great work
Link to comment
Share on other sites
Last things to complete were to glue the rotor blades into the central control :
The blades could be a problem as time goes by. I'm not very happy with the way they are fitted - the control arms seem too weak for the weight of the blades, so I wiped CA glue over virtually all the control arms to try to stiffen them up a bit. It worked to a certain degree but time will tell.
Danny
Cheers, Danny
Link to comment
I think the 'probe' is actually a pitot tube.  This is used to measure the airspeed - must stay in undisturbed air as much as possible.
The way it works is as follows:  the pitot tube takes the total pressure (dynamic + static), while at the side of the aircraft/helicopter will be static ports that measure static air pressure only.  The speed dial detracts the static pressure from the total pressure, giving you an accurate indication of air speed.  In order to get accurate readings the total pressure in the pitot tube must be clear of any disturbances in air generated by features along the fuselage.
Please feel free to correct me if I am interpreting this wrong.
Heghlu'meH QaQ jajvam
Slainte gu mhath
L.H.
Link to comment
Do they actually refuel helos in midair? A scary thought with the blades whirring overhead :o.
EDIT - it seems they do :
They can have that to themselves :D .
Danny
Cheers, Danny
Link to comment
I'd go along with LH as I too doubt that's a refueling probe with all the fins on it and it's location.  I'm thinking its a pitot tube for airspeed or something else to get inlet out of the prop wash.
Link to comment
Danny
The USAF CH-53's have in-air refueling capability.  The tube is a lot larger (proportionatly to yours and is low on the fuselage.
Link to comment
Wonderful work Danny,
I`m totally amazed of the lot of technical parts, their function and how this was designed into the card model, let alone your skilled performance on the assembly, sehr gut gemacht !!   :)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Forgot about the airspeed thingy.  There is a pretty cool video somewhere on YouTube of a 53 chopping its own refueling probe off😳
Link to comment
Think its the Pitot tube?
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
MH53's  would often team up with C-130s  and do budy up refueling.
OC.
Current builds
Completed works.
Link to comment
OC.
As seen HERE in this video. I know it's not a Hind in the video but the principle is the same.
Danny
Cheers, Danny
Link to comment
Found it (click HERE).
Danny
Cheers, Danny
Link to comment
I have a friend in the air force who is a refueler on a C-130...........a lot of skill shown there ;)
the model is looking very good Danny.  odd that they didn't have you reinforcing the entire assembly.......the blades are reinforced.   has to be a lot of weight...........not of paper,  but the length doesn't do it any favors.  do you think a coat of flat lacquer would help?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
4 hours ago, popeye the sailor said:
Odd that they didn't have you reinforcing the entire assembly.......the blades are reinforced.   has to be a lot of weight...........not of paper,  but the length doesn't do it any favors.  do you think a coat of flat lacquer would help?
The wires go most of the way into the central part. In hindsight I probably should have painted the reinforcing piece with CA before skinning it. I think the card itself probably has a bit of flex in it - it wouldn't take much over that short distance to make a much bigger difference over the length of the blades. I think the only difference a coat or two of lacquer will make is to add more weight to the blades - I've already coated all the relevant control parts with CA, which improved the amount of "droop" in the blades. I'm reasonably happy with the result :) .
If I were to build another helicopter I'd design my own system for attaching the blades. Nothing drastic, maybe just replace the card control reinforcing part with some brass tube silver-soldered together, which would then be covered with the kit skins.
I'm currently giving the model a coat of Model Master Semi-Gloss clear, pics of the completed model will be posted shortly.
Danny
Cheers, Danny
Link to comment
Rotors do sage when they aren't spinning.  Compared to the weight they haul, they're actually pretty light all things considered.  When they're spinning, they go nice and straight and can actually bend a bit upwards.
There's this video showing how not to do aerial refueling:
Link to comment
That probe sticking out front does several functions. It is part of the pitot static system for airspeed. The fins are for angle of attack (AOA) and I suspect sideslip for the helo. Looking at Soviet/Russian jets, they all appear to have similar probes to the one on the Hind. A simple yet reliable system.
We had a small cone shaped protrusion on the left side of the Phantom's nose, which was the AOA probe. The AOA gave us an audio signal as we approached stall condition. If the audio didn't get our attention, the frontseater got a foot massage as additional reinforcement. The right rudder pedal shook to get his attention.
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks for this information, inquiring mind has been satisfied
... for now...
Slainte gu mhath
L.H.
Link to comment
On the CH-53, that is a refueling tube only.
Link to comment
even on plastic kits I've built in the past,  blade sag has always been a problem.   the long blade seems to amplify the weight.   I'd go back to my model weeks later,  to find that they have sagged to the shelf!  I have my fingers crossed that you have a good remedy for this Danny :)   this is one fabulous model you've built........I'm in awe of how it's coming out........you've mastered card with ease  ;)   here's a good question for you all :
  we all know that the pilot tube is an integral part of the craft.........much like the MAP sensor in an automobile.   is the refueling tube an integral part of the craft.......where is it stored when not in use, ........or...........is it fitted when the mission at hand is determined...........the duration of the mission,  and will it need to be refueled in mid flight?  {just play'in the devil's advocate here  ;) }
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
https://en.wikipedia.org/wiki/Aerial_refueling
that is the one thing I cannot find........I wonder if Al still works at the garage?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Denis, most modern fixed wing a/c have retractable refueling equipment. USAF favors doors to receptacles in the body, most other airforces (including naval forces) favor a probe on the receiver and a drogue (basket) on the tanker. Same for helos. I think the USAF version stems from the 50s and Gen Curtis LeMay. Control and use of tanker assets.
Blades better droop, means they are flexible. It's like wings flexing; they better or the wings break off.
Ken
Link to comment
Dan, another incredible build you have here. can't believe I didn't check shore leave section sooner. and, as Druxey said, very beautiful model of an extremely ugly (yet impressive) bird. well done!
Denis
cheers!
Denis
Current Build: HMS Pandora 3D modeling
                    Swan Class HMS Pegasus for Admiralty Models 3D Build
My other 3D work: Artstation
Link to comment
Thank you to all who have followed, Liked and commented on this build. It's much appreciated :) .
Here are the final pics :
Cheers, Danny
Cheers, Danny
Link to comment
That looks Superb Dan  you should feel rightly proud of what you have achieved  - congratulations mate.:cheers:
OC.
Current builds
Completed works.
Link to comment
Very impressive paperwork. Congrats on completing what was obviously a very challenging model, Dan.
So, what's next?
Link to comment
Excellent!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
So, what's next?
He should find a kit of a Hughes OH-6 Cayuse for comparison!
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
