AVOS by Peta_V - FINISHED - Master Korabel - scale 1/72 (exclusive kit) - Russian tender
1 hour ago, DPK said:
2 possibilities: The latrine doors are not 90 degrees to the keel frame or the details did not set completely into each others' slots.
I think it is solved. It both (doors and timber) needed a small alignment. Thanks a lot pointing it out before it was late! 👍
Link to comment
Share on other sites
I see what you mean, loks like I glued the last timber little bit lower. But that should not be a big issue I hope. I can put there piece of plywood in case it will be necessary. Thanks for the note!
Progressing with the stern. This one was tricky to fix the correct bended shape. I love how the pear wood works together with Black wood.
Link to comment
On 6/22/2019 at 1:44 AM, etsinko said:
Really great build! Very inspiring. Can't wait to start mine..
Hi Etsinko,
Thanks fot the comment. I'm sure you will enjoy the build same as I do! And I'm looking forward to your building log! 🧐
Here I made a comparison with my Royal Caroline. It is different scale of course but it shows how small "cute" AVOS going to be.
Still it will be impresive model (if I do not mess it up)
Link to comment
Just now, DPK said:
I strongly hope that the taffrel piece is not glued to the hull yet :)
Hi, No it is not! 😮 I'm following the instructions step by step. It just fits so well without any glue or any fixing jig. Great work from designers really!!
btw are you one of them? Or did you already build AVOS? Just asking that you know the process............
thanks
PetaV
Link to comment
Well, I took part in the design, so I know the process. Btw, if there is anything that is unclear in the instruction, you are very welcome to tell. This kit's instruction worked out to be much clearer than the previous one's, but there is always a room for improvement.
Then huge respect and big thank for your work. You guys created truly master piece.
I agree, the instructions are OK and easy to follow so far. The only thing I found so far is wrong numbering in one paragraph in text instructions.
I believe instead of A29 should be A59 as A29 is different part used during stern construction. It is OK in photo book as well as in list of parts but one can easily figure this out. I have the text version from May 2019 so I believe up to date?
PetaV
Link to comment
Thank you very much, you are quite right. It is a misprint: should be A59.
Yes, the text is up to date. The photo instruction is better to be used downloaded from the site (it has more explanations and several small numbers corrections, although nothing critical if being careful).
Link to comment
Deck preparation. The deck is made from one piece with laser engraved planking. The base of the deck is some lower quality wood on which is pear veneer. Several reinforcements has to be glued in to shape the correct curvature of the deck and support the deck furniture.
Link to comment
During the night I have complete left side of the bow. I do not have an experience with the POF scratch build but from the builds I see here the Construction is somehow similar (much more simple but some elements are close I think) So a good practice to move level up :)
IMG_20190626_010708.thumb.jpg.a9a5e5f6f4b17c80886abd37739bbf1f.jpgIMG_20190626_010720.thumb.jpg.1ea560f8800050304579a4c958584011.jpg
I Just dry fited few pairs of the next ribs and the shape is awesome....
IMG_20190626_013128.thumb.jpg.49e593b20286d3f674b1d33c66347f49.jpgIMG_20190626_013100.thumb.jpg.c9016ab86c93b8c956bbc1cf80f5d20b.jpgIMG_20190626_013044.thumb.jpg.bb42d038cb1bf30e4cb94e4f4009c637.jpg
And of course I could not resist and have to dry put all the prepared parts together
IMG_20190626_013459.thumb.jpg.c79eaab83cf9a01571646bc3b5a2ad75.jpgIMG_20190626_013444.thumb.jpg.b56455f429f9ac6a70d921a6e745fba4.jpgIMG_20190626_013428.thumb.jpg.f3f45e2b5bb0f037a348d7259e545629.jpgIMG_20190626_013516.thumb.jpg.00b613e123fd19808da343412ef2d155.jpg
Link to comment
Hi Peta,
the design/construction of the Avos kit model looks realy professional thought through, great work, this is a wonderful basis for a super model...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils, thanks a lot. And also for all others likes
All frames in place. Few pairs only dry fited. IMG_20190628_001300.thumb.jpg.da91dd24b0a2a278bb1b6d22671794b0.jpgIMG_20190628_001245.thumb.jpg.3699639de92248d83946583007d62707.jpg
With a deck
And this is...... My worry right now
Link to comment
good work Peta,
nice, neat assembly so far...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Nils, thank you.
I started with planking. Deck is glued and also inner planking. The pear looks gorgeous and it is pleasure to work with.
Link to comment
I have a feeling that the whole inner planking went a little too high. Could you please check the size of the gap between the planking and the deck? It should be completely covered by the waterways (1.5 mm thick).
If the gap is too large (hope it is ok), I think the easiest way is to raise the edges of the deck in proper places a little.
Link to comment
Today more framing work. I have finished the inner structure of gun ports and oar ports. The visible parts will be sanded so char will not be present.
Link to comment
Preparing the hull for final planking. One side is ready. Also creating the rabbet. On the left side you can see the marks. Once sanded down to this line it will form the rabbet.
Link to comment
Hi Peta,
excellent work !
its a real beauty, and the progress is lovely to follow, what a nice pricise planking !...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
