Peta_V
Tender AVOS by Peta_V - Master Korabel - scale 1/72 (exclusive kit)
Thanks Jim!
Thanks also for all the comments and likes. It keeps me motivated.
It starts to look really great, I love the shape of the ship and all the wooden and brass details. Truly enjoyable built. I'm little bit afraid what I will do after AVOS and RC. Hope MK will release some new gem!
Share this post
Link to post
Share on other sites
My only struggle so far was the three-piece black veneer cap over the transom area. Thee veneer was so thin, that even with soaking and nipping, it kept splitting. Those short lengths have to do acrobatics by bending in different directions.
Share this post
Link to post
Yep, that wasn't easy step. But still somehow doable.
Share this post
Link to post
8 hours ago, Peta_V said:
Thanks Jim!
Master Korabel has a few other kits such as Brigantine Phoenix or Schooner Polotsk. Both of them are great kits and should be no problem to you!
Share this post
Link to post
Rudder. You start from the photoetched part that needs to be bent to create a "hook". I have then silversolder the edges and smooth it with file. Blackening and the irons are ready.
IMG_20190808_111530.thumb.jpg.a11555d67533c023f9cfcc68db60173a.jpgIMG_20190808_132048.thumb.jpg.dd3c2e6bf358a3ad8ac32990fe14db20.jpgIMG_20190808_132306.thumb.jpg.8d1fc7c7d68ca58b166960649e6d66e9.jpg
I have added the eyebolts and decoration of the transom
IMG_20190808_171823.thumb.jpg.827aefa91274934ab855c5117f77f811.jpgIMG_20190808_171834.thumb.jpg.e6f7551454c8a0184fce68282692da2e.jpg
And starting preparations of the deck furniture
IMG_20190808_171845.thumb.jpg.19c186e7c95402b20d6d707b7d5addd8.jpgIMG_20190808_171859.thumb.jpg.0b3e62c4349978120bf9fec9bb35bdf1.jpg
Share this post
Link to post
Windlas part2. Everything went fine to this stage. Time consuming as there are lot of pieces but smooth process.
Until this small detail came. It is so tiny and will be made from 10pieces. Nice test for the nerves :D
IMG_20190815_104756.thumb.jpg.0fe9016ab2727fb30e88b1cb01858d54.jpgIMG_20190815_104707.thumb.jpg.36f8a804760382f789c80bfc70edb54b.jpgIMG_20190815_104716.thumb.jpg.b13b0035d02ec3a57c7dd5a724433136.jpg
Share this post
Link to post
4 hours ago, greenstone said:
Very good. Assemble the model very quickly!
But why is bell black?
Thank you Greenstone.
It is my personal choice.I found it distracting leave it in brass when all other irons are black. I do not like colourfull models so that is the reason. Not sure what I do with belaying pins🤔
Share this post
Link to post
Preparation of the route for anchor cable.
IMG_20190816_130619.thumb.jpg.24c79e32bbc49351d4a92294ae1a3588.jpgIMG_20190816_134046_BURST001_COVER.thumb.jpg.407042d794a9fb06d9def62692e78034.jpgIMG_20190816_134119.thumb.jpg.537a1b7c99b02b5ada1c847c576399aa.jpg
@DPK @greenstone can I ask you guys for advice? There are two pre-drilled holes in the deck forward to the bow from the bell in the same line with other rings for securing the cable. I guess There should be another pair of rings? But it is not in instructions so I do not know if I can use 2 more photo etched parts #18 (are there some spare or the count is exactly for the model?) or should I produce my own? Thanks a lot!
IMG_20190816_135922.thumb.jpg.69f5abb38c324f56bdd069d498f6d0dc.jpgIMG_20190816_135338.thumb.jpg.1d9b5c5a1ea912875802f0d14b7e2e28.jpg
Share this post
Link to post
Thank you very much for pointing at these holes. Yes, they were previously designed for holding the anchor cable, but currently they are not used.
I think the best decision is to make the wooden plugs from the remains of the deck holding plate and shut these holes down.
Obviously you can use them as intended, but you will have to count the eyebols first - maybe you should make your own,
I cannot say now, there are different versions of photo etched plates, some of them contain spare eyebolts, some have just what needed.
Btw, the kit is out for about 8 months now, but noone has pointed us at this yet!
Edited by DPK
Share this post
Link to post
Thanks man, that is what I thought. Similar case would be with inner bulwarks planking.
Share this post
Link to post
After final consideration, here is the conclusion: the holes for the anchor rope holding eyebolts are OK, the photo instruction lacks the images of the eyebolts installed. I shall fix it soon.
The number of eyebolts 18 is more than enough (at least 4 spare), so just install the pair and use as intended.
Share this post
Link to post
@Peta_V , the cleats you are referring to are not used. Currently the inner ladder is intended to be installed in that place.
You can either install the cleats (there are ALWAYS some not-used fastening places on the ships, for situational use) and find another place
for the ladders, or just ignore them and place the ladders onto that spots.
Share this post
Link to post
Back in the workshop with some small progress.
I have added another pair of the secure rings @DPK's advice. Thanks again. I have finish few final touches on the windlass and secured it on the deck.
IMG_20190822_114818.thumb.jpg.8445bf0bbdf64c18069d3093d475b907.jpgIMG_20190822_114649.thumb.jpg.2c978073ba301ed7ef860624c1a589fa.jpg
I have experimented with the belaying pins. Luckily There are few spare so I could blacken one to se how it looks on the ship. Still not sure what I will use, if clean brass or black (leaning little bit more for black version). Here is the comparison. What do you think??
IMG_20190822_114806.thumb.jpg.767cee9fc2d3f2249d73e3f1065ea515.jpgIMG_20190822_114741.thumb.jpg.3071060379a80a714939a8651b5cebeb.jpg
Share this post
Link to post
You asked for opinions so here is one! I like the black much better and I imagine that you will too once you hang some rope coils around it. Perhaps if you had more brass fittings elsewhere the brass would look good but...
Share this post
Link to post
Thanks a lot for all likes and kind comments. Love it!
@Katoom and @Dubz thank you for your opinion, I share the same one as well. I took other 2 or 20 looks at it and black goes much better with other details. I try to avoid the brass fittings which is the next reason for black 👍
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
