AVOS by Peta_V - FINISHED - Master Korabel - scale 1/72 (exclusive kit) - Russian tender
Thanks a lot guys!
Adding the gun tackles. Supricingly after you got the rythm it goes quite well!
Link to comment
Share on other sites
Finaly all guns secured in place. I'm So glad There are only 8 of them. Can't imagine doing 40 of those!
Link to comment
11 minutes ago, Dubz said:
Great progress, love that kit!
Unfortunately the rigging for the ruder is not going to work! It should follow the green lines.
Dirk
Hi Dirk,
thanks for your comment. Looking at your picture it is clear that the tiller has to move around the circle which the setup from the kit will not allow! I had this section in mind for a long time. I plan to re-do it anyways. Use iron hooks instead of strap on the tiller (so the tackle can be easily removed) and also I will look at the possibility to move the bulwark block more aft.
Link to comment
Adjustments of tiller tackles.
According to the scheme from Dirk I draw the lines to AVOS plans to see how much I need to move the bulwark double blocks. It turned out that not much which is great as it will not be in the way of latrine doors. I have take the tiller out of the model and made Iron belt with 2 eyes for tackle hooks
And the result (the coil will be replaced later)
IMG_20191016_230120.thumb.jpg.3e741f33a596b89b08ad77c027d878bd.jpgIMG_20191016_230138.thumb.jpg.2d9098b75a356c44479844afff46ba26.jpg
It looks much cleaner then before.. IMG_20191015_160714.thumb.jpg.4c818f2f4409460584e9ddb0a69be2fd.jpgIMG_20191015_160744.thumb.jpg.ef27b85319e568a725105f0ab7db8684.jpg
Link to comment
Please pay attention, that the first variant was done in a way, mirrored from the one, presented in the drawings. You fastened the standing end not very close to the hilt. So obviously the fastening points on the bulwark have to be moved in this case. If done according to the drawings, no moving is required. Especially because the rudder rotation angle is not that great.
Link to comment
Hi, yes you are right. I did the mistake that the blocks on the tiller were fastened further from the end (that was the first version). I have corrected it and this is the final result (with hooks).
Link to comment
Thank you very much for all reactions!
Preparation of the mast. It is carved from 6mm dovel. Not sure what kind of wood that is. Top mast, yards, boom, gaff are all in pear again. First  I was sad that the main mast is not also in pear but now I like the light color. It will look good with contrast of other pear items.
Link to comment
10 minutes ago, greenstone said:
It`s russian birch
And in Russian Navy at that time, the masts were white
Thanks for the update! Good to know 👌🍻
Link to comment
Top mast ready and full height reached! She is quite tall. Mast cap with Iron belt. There will be also 2 Iron belts on the mast head but I want place stays and shrouds first.
Comparision with RC 1:48 (she is waiting for the rest of the rigging in the dock)
IMG_20191022_183451.thumb.jpg.ce515d0dd37fe45c49b423911aa9440b.jpgIMG_20191022_183600.thumb.jpg.43f47b3d6b80b7d4a257558eaf5f8de0.jpgIMG_20191022_183411.thumb.jpg.82baed5302290d924837284250185a72.jpg
Link to comment
You are certainly moving right along with what is going to be a beautiful build Peta. I always look forward to your postings.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thank you guys!!
Some more additions. I have finished footropes for spreadsail yard.
IMG_20191104_165805.thumb.jpg.73ecc196340f30460fb8c487a3bc86c5.jpgIMG_20191104_165841.thumb.jpg.c1646adf3fecba271f11b280e2d41d9d.jpg
And start to adding ropes to the mast. Already There are backstays, 4 pairs of shrouds and spreadsail jackstay. I have also added the iron belts with eyes for blocks. Ropes are served in areas where interfere with mast.
IMG_20191104_165730.thumb.jpg.07fc6d8662dfdab6bb22a25f7861aca0.jpgIMG_20191104_165653.thumb.jpg.f60f140f23f9f42b09b09c063c2bd458.jpgIMG_20191104_165620.thumb.jpg.9b646870f5c83568e72f3745833e48b5.jpg
Link to comment
On 6/10/2019 at 11:00 PM, Peta_V said:
Now it can be taken off the jig
Hi Peta,
Please can you or someone explain or preferably show how to remove this little boat from the jig.
Every build I have followed where one of these small Master Korabel boats are being built says exactly the same thing.
"Remove from jig", but nobody shows or explains how to do this.
I have built the MK0102 and almost destroyed my build trying to remove it from the jig.
I am about to build this one, and do not want to go through the same heart stopping procedure again.
Many thanks,
Tony
Link to comment
@Galley Slave
As you can see the jig is covered with foil and hull is not glued to the jig. Only the tops of the frames are glued to the jig. Once the hull is planked the tops of the frames are cut (I used razor saw) and the hull can be removed.
Link to comment
Gentleman, to the sewing machines! My premiere with the sails (luckily the sails are pre-sawn in the kit with the Bolt rope in place and they are very nice). I just wanted bolt rope to correspond with other running rigging so I cut the original off and replaced it with my own rope. I also did not like the eyes on the original. I think I made it more real, I hope.
Reef points: first row in place (I still need tu cut it to the lenght and shape it) but I have to say that I found something to be as annoying as ratlines! 🧐
I guess the only way to get it done is sit down and work! 2 more rows are waiting.
IMG_20191109_095913.thumb.jpg.71d8313f85279b5878ddfd2873119968.jpgIMG_20191109_095944.thumb.jpg.f923b307b824e79c16d1c4d13e686d6b.jpg
On the right is sail with kit bolt rope and eyes.
Link to comment
Small progress for the eye but huge for me! :D
Reefs in place. I just need to cut it to correct lenght and finaly hang the sail to the gaff........ Can't wait!
Link to comment
Cutting the reef points. This is a method I come up with.
1.I copied the sail template several times
2. I cut the shape of the "reef line" out of the paper.
3. I insert the template between sail and reef ropes so I can see the lenght and direction
4. I fix the reef ropes straight in correct direction with the tape.
5. Cover the ropes with diluted PVA glue and let it dry
6. Cut the ropes with exacto knife according to the template
It is little bit time consuming but accurate. Works quite well!
IMG_20191115_100322_1.thumb.jpg.a98ccfc5e797d3e0549f04e778936afb.jpgIMG_20191115_102748.thumb.jpg.24a38028cfe51033c7ac89d44d92a19c.jpgIMG_20191115_150026.thumb.jpg.bb2d611778c1be7c019620ed7c922cc4.jpg
Link to comment
Nice work! One sometimes sees models with reef points pointing every which-way; folks either forget or don't realize that lengths of rope have weight -- they will tend to hang vertically.
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
All ropes for main sail are in place (what a mess)
IMG_20191119_005849.thumb.jpg.5e23f66f1307655948f101feb755a776.jpgIMG_20191119_005938.thumb.jpg.0084a158afc836d198e2abb778ff1a4c.jpg
Now I could secure the mast in position and slowly start to solving that "hairy" puzzle. I must say it is a Joy to go through all the tackles!
IMG_20191119_005129.thumb.jpg.0a84b7e906a861367a15892f1175ee50.jpgIMG_20191119_010122.thumb.jpg.dd0bb28b31078f8bdf704519d6e68972.jpgIMG_20191119_010258.thumb.jpg.187d58d1ae58b8aa6d1f63d8ec6f2a36.jpgIMG_20191119_010031.thumb.jpg.ab92b36acd96b810ae049b3de6a4895c.jpg
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
