HM Schooner Ballahoo by The Lazy Saint - FINISHED - Caldercraft - Scale 1:64 - First wooden ship
Hi all,
As promised, a little bit of colour and l think it makes the deck stand out quite nicely. I did, however, have a mishap today. I lost the capping piece to one of the deck pumps, hence the reason for their absence. I will make a duplicate out of wood, it's a bit of a pain but its my own fault, l must be more careful.
Best wishes as always.
The Lazy Saint.
Link to comment
Share on other sites
Hi all,
Thank you Edward, for your kind words.
Today l added the white paint, put together the Carronades and painted them. I also fitted the Eyelets, Cleats and Belaying Pins, phew, that was a fiddly day.
I was just about to drill the first hole for eyelets around the formast when l noticed with horror l had fitted the Mast Bit Support Post the wrong side of the mast. I said "oh darn it" or words to that effect. At least l noticed and was able to rectify the problem.
The Lazy Saint.
Link to comment
Hi all,
This morning l am looking at the Channel's and the fitting of the Deadeye Strops (51) and Chainplate Straps (49)
The problem is that, as shown, it is not possible (imo) for them to fit into the cut out channels. l would have to cut off the two lugs on the Deadeye strop. Ok, that isn't a big problem, however l would still have to widen the channel. The alternative to widening the channel would be to close the gap in the strop to fit, however, by doing so would prevent me attaching the Chainplate Strap. All the above can be dealt with one way or another but the final problem is that the strop is too short and so to that end the Chainplate Strap won't stretch between the strop and the main wale.
Raising the main wale is not an option ha,ha.
I remember seeing on one build, l am unable to remember which, the use of wire to replace the kit parts. This may be the route l shall take but l would like to know what l am doing wrong, have l missed something.
The Lazy Saint.
Link to comment
Hi LS, I have same problem with my Sherbourne build and have gone down the making my own deadeye strops route, to which end I've ordered some 0.4 mm copper wire to make them. When the wire comes I will post some photos of my new homemade strops.
Hope you get yours sorted soon as you are flying with your build.
Looking good by the way.
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Hi all,
Thanks for letting me know you have the same problem Edward, at least l now know it's not something l am getting totally wrong.
I managed to get some 0.4mm brass wire from Hobby Craft today and made my own, it was fiddly but most of it is hidden within the Channel's. I am happy with the result, although l only managed 3 today, perhaps l will complete them over the next few sessions.
I also applied another colour.
The Lazy Saint.
Link to comment
Hi all,
I didn't get a great deal done today as l only had a couple of hours this evening. I thought l would spend the time looking at, and sanding, the masts. As l am shaping by hand it will take awhile but it seems to be ok so far.
The Lazy Saint.
Link to comment
Coming along nicely ...  Loving the deck colour btw.. (Don't forget the Rudder ☺️ wee bit of maneuvering to install it and u may need to turn the boat upside down, so watch those deck fittings etc)
All The Best
Eamonn
PS I should be returning to my own build soon enough, work on my attic conversion is going nicely !
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Link to comment
LS I'm glad to see you got your chain plate problem sorted😀
I also started my mast on Sherbourne by hand but then saw a simple jig in the mast and rigging forum where you use a cordless drill and I got it sanded much quicker.
Keep up the good work 😃😃
Sorry I don't have a photo of my jig
Edited by Edwardkenway
Current builds;
Completed:
Link to comment
Hi all,
A busy day today, it was far to hot to venture outside so l got plenty done in my den.
I completed my Deadeye Strops and Chainplate Straps, a very fiddly job but i managed it ok and, imo, to a reasonable standard. I also finished the shaping/sanding of my Masts, fitting of Cleats to those Masts and finally, painting.
The Lazy Saint
PS At no time ever will l discuss Rudders, Rudder hinge assemblies or copper eyes associated with hanging Rudders. 🤬
Link to comment
Looking good, you'll be rigging soon😃
Re rudder, I know you don't want to think of it but once you've done it you can go
"YESSSS" , it is fiddly but you get a sense of achievement.
Current builds;
Completed:
Link to comment
Ab Hoving pointed out in his card model tutorial that model rudders don't have to move.  I took his suggestion and made the strapping out of painted card for the rudder on my Prince de Neufchatel and pinned it to the hull.  It is good and secure, plus looks nice.
Edited by GrandpaPhil
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Hi all,
I Spent the rest of the day tying blocks.
Aft Mast Boom.
Aft Mast Gaff.
Fore Mast Gaff.
Very fiddly but very absorbing, no wonder ships like HMS Victory can take a year or more to complete.
My next task is more of the same but on the Fore Mast and Aft Mast, but not tomorrow, tomorrow l am going fishing with my Grandson. 🎣
Best wishes as always,
The Lazy Saint.
Link to comment
I am keeping an eye on this rigging job to get get some pointers for my own build.
Keep up the good work LS
Current builds;
Completed:
Link to comment
Hi all,
Thanks Edward, and l hope you won't be too disappointed in my rigging. To be honest, this is the most fiddly part of the project so far but easily the most absorbing, for me at least.
Fore and Aft Masts now fitted with their blocks.
The Lazy Saint.
Link to comment
Hi all,
It seems like l have been working on the Shrouds all day, (ha, ha, l have) the time just seems to fly by, l don't know where the day has gone, and it was the Devil's own job getting the Deadeyes exactly level. I have left the tag ends on as l would like to tweak the odd lanyard tomorrow.  Once l am happy l will apply a diluted wash of wood glue to seal the knots and then trim.
The Lazy Saint.
Link to comment
Hi LS
You've done a grand job on the shrouds and lanyards. I only hope mine turn out as good.
Current builds;
Completed:
Link to comment
Hi all,
Thank you very much for your kind words Edward, they are very encouraging. I have been busy on my next rigging tasks and have completed the Fore Mast Shrouds and Back Stays. I have also fitted the stays from fore to aft and applied diluted wood glue to all knots and trimmed.
My next task is to make up rope coils to hook over the belaying points for the Back Stays and to paint the brass rigging hooks black.
The Lazy Saint.
Link to comment
LS I've got to agree with Eamonn looking quite a saucy schooner.  And yes didn't that rudder just appear as like magic😏😏
Oh and thanks for the positive comments on my build👍👍
Current builds;
Completed:
Link to comment
Thanks guys,
A long session today, but l have completed the rigging. Its a proper cats cradle, l cant imagine what the victory would be like. Although the rigging has been the most challenging modeling task l have ever had to do, it has also been the most satisfying.
My next session should see the completion of the project.
The Lazy Saint.
PS Last image is the audio book l am listening to during the build, inspiring stuff and l am picking up some nautical phrases.
Link to comment
35 minutes ago, egkb said:
Looking Good T.L.S.  !!
Eamonn
Have to agree, she's looking very good.
Keep it going LS
Current builds;
Completed:
Link to comment
Hi all,
Thanks for the kind words, appreciated.
Earlier in the build you may remember me saying that l lost parts of the deck pump behind my radiator....... don't ask, please. I had planned to fashion somthing in wood to replace, however, I have taken a lead from Eamonn and his build and installed a pair of Elm Tree Pumps, they look quite smart, thanks Eamonn. They just need painting.
The Lazy Saint.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
