Fokker DR1
Hi All,
I'm after some "Learned" advice....
The Control Column/Rudder Bar are linked to the Control Surfaces, Aileron/Rudder/Elevator. (Working surfaces.)
My question, should I go with Thread for these moving things or maybe go with Multi Stranded thin wire? (Stripped insulation, of course.)
I'm leaming to the wire as it's not going to fray and I can easily solder the terminations whilst retaining the tension required.
Any advice/opinion wold be very welcome.
Cheers....HOF.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Link to comment
Share on other sites
Lovely work Hof,
looking at the fuselage construction, the real plane must have looked somehow the same. One can imagine that unfreindly bullits went through it like through butter...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
With wire, you'll some how have to stretch it to get to look right.  I'd go for the thread.
Link to comment
Thanks All!!
Yup, the Frames have Thread Rigging, Fore/Aft/Across every frame, up to the Pilots Seat, but, my question is more centered around the actual Control Cables for the Flying Surfaces.
I was leaning to "Multi Strand" wire?
Mark: If Multi Stranded, would it not be already "Pre-tensioned?" to some extent? (Yup, I hear your advice.)
I guess I'll have to experiment.... 🙂
With the continued issues with this, I'm looking forward to getting back to the Sanson. (At least I can correct "Irregularities."
Small update: Have finished the various Instruments/Cluster but I'm having trouble getting the Instrument Cluster Support bar to fit across the Cockpit Frames.... I have words of frustration which I will not utter here!!
Simulated Glass of the Instruments with clear Nail Varnish.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
