US Brig Syren 1803 by Overworked724 – Model Shipways – Scale 1:64
Just to reiterate, this is my first framed model, and I swear...I will plank this beast!  (Planking always scared me)  The mast holes were a question in my mind until I saw some other modelers precut the mast hole in their bulkhead former.  So I followed suit, since it will save time and effort a bit later (much later).  By cutting out the holes for the masts at this stage, the rake (mast angle) is easier to ensure.  I just went with the plans...an voila...a scroll saw visit later, and I had my mast holes cut out.
DBE7439E-2857-4E16-A61C-B227747C35FF-63304-00001730E1538901.thumb.jpg.0151d873bb3afd2e8a02e05957f092d8.jpg
I decided to 'box' each mast hole - since a circle can be bordered exactly within a square.  😃 So...I made some measurements and boxed in the new holes I made for the masts.  The 'holes' are now boxes which perfectly fit the masts (taken from the plans they are 5/16" dowels).
7C6DCDFD-0246-47E3-BCCE-A498DB4B06D0-63304-00001730E31945A1.thumb.JPG.c878cc940df25ac68915f2eb43e59222.JPG
2691EABF-73AF-4B0B-90C6-C47B12939FC2-63304-00001730E2595CB9.jpg.1ca39e0b562ae59b8d131d6d8246c873.jpg
AFD92EA2-EB66-467E-993A-690B1A0D3184-63304-00001730E1F85878.thumb.JPG.ad5b55d799a680f48f71f5b9d10ef7d5.JPG
The plus to doing this now is that I don't need to fret about drilling the holes later (and at the correct angle)....what a mess.  I did that with the Sultana and it was 'heart attack city'.  The drawback to this, however, is that you will get a perfectly aligned mast which is perfectly parallel to the bulk head former (center frame).  So, you will see immediately if there is a twist or lateral bend in the center frame...since looking head on, the masts will appear cockeyed (askew) to each other rather than parallel.  And, like most kits, mine is not perfect.  There is a slight twist towards the stem which I did not see until I inserted my faux masts to ensure fit.  This means I will need to take even more time in putting in the filler blocks and trusting my measurements.  But hey....it's progress.
On a more somber note...I'm suffering from some serious anxiety.  As we are all living in the dawning of what will be some extremely difficult times, I pray, hope, and work.  I try to connect with those I love, and keep in my mind what's most important.  Modeling takes my mind off for the moment.  I put a monitor on my hobby desk in my den that doubles as a second screen which I use during my stay at home working hours.  When I model, I switch it to a Youtube channel with pleasant scenes, and soft music.  This and a glass of wine or scotch certainly takes the edge off!
Stay well, shipmates. 🙏
D97994CD-9917-4559-A3BE-67CB3479E282-63304-00001730E366219B.JPG.8ced5b8426cef45e28f6ce628e9ab300.JPG
Edited by Overworked724
“Work like a Captain....Play like a Pirate!” — Every Ship Modeler...everywhere.
Link to comment
Share on other sites
Hey Patrick, how deep did you cut the slots to? I was looking over Chapter 12 of the instructions and Chuck mentioned to drill them to 1/2 inch so that is what I did on mine. Looking at it now, it might be a bit shallow, so I am thinking of increasing the depth.
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Link to comment
I drilled mine to about 1”. A shallow hole give you more room to play. I personally like a solid mast. You can always sand down the base or the mast (dowel) to give you more ‘play’ to adjust the angle. Another nice thing about a deeper hole is you can (if your masts are well aligned and the hole a snug fit) forego glue altogether.
I think it’s a personal choice. But your holes look great. I’m sure it will turn out beautiful regardless. 😃
Link to comment
This is a very nice kit and it looks like you are off to a great start.  Will be following along to see your progress.  Nice work on that punch
Link to comment
Patrick, she looks great! I like your approach to copper plating. And yes, it’s always better to be able to not glue the masts, especially if anything unforeseen happens.
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
Decided to take a side road and start the body of the ship’s long boat.  In truth, I was kind of intimidated by the long boat on the Sultana kit.  The other build logs do such a beautiful job of making the ship’s boat, and I could not imagine how I could get a good boat shape without brutalizing the wood.
So....many hours later...I’ve got a decent start on my ship’s boat. Not a bad result. I used all hand sanding.  Took my time and many breaks.
And to top it off...I figured out how to make a perfectly triangular 1mm dowel from square one!!
Moving on!!!
Link to comment
Slow day today. I decided I would pre-fit the figurehead and found the stem was still a bit too wide. Sanded it down to fit and it looks OK. The figurehead itself is actually in really good shape and it will be fun painting it at that stage much much later.
I decided to try the copper plate jig a couple of times and found I was leaving too many fingerprints on the tape.  In order to reduce my fingerprints, I decided to make a little jig to push/pull the tape through the tracks. It was simple enough to make using a section of quarter inch square dowel and gluing a cutoff off section of rubber band to the bottom. The rubber band ‘grabs’ the tape really well by applying only minimal downward pressure.  There was no marring or bruising of the tape and it works as either a puller or pusher.  I added an additional section of wood on top to act as a handle and make it easier to manipulate. It works like a charm!
Moving on!!!
Link to comment
Not sure if this would be of any help with your figurehead but the Smithsonian recently published and article on recovered 19th century figureheads:
https://www.smithsonianmag.com/smart-news/rescued-rot-19th-century-naval-figureheads-feature-new-exhibit-180974396/?utm_source=facebook.com&utm_medium=socialmedia&fbclid=IwAR3Xwdz4XWr6EiFYfQAbAG6Rm6OlvDjYvA6suzChH6Dx3u4xaK76Cs-H0pg
Current build: NRG Half Hull
Previous build: MS Bluenose
Link to comment
Thank you for the reference, CPDDET!  I’ll take a look. Also, I have a reference I acquired a couple months ago which has some excellent history on details from stem to stern!  But sadly, I’m not a very good sculptor or carver.
Link to comment
22 hours ago, CPDDET said:
The Smithsonian article has smaller pictures but may be of assistance in paint colors.
Keep up the great job you're doing.
Nice article!  The close ups of those figureheads do give some good perspective on how I might paint the mermaid figurehead.  It’s interesting how the paint colors were equally stark and garish.  Perhaps way back when the palette to choose from was limited.
Link to comment
Decided to err on the side of caution. Put in some pins to support the keel and stem.
Nervous but moving on. The bulkhead former has that slight twist. Moving on...
Link to comment
If it were me, I'd do anything I could to eliminate the twist in the bulkhead former before proceeding, or it will cause substantive headaches later in the build.
Alan
Link to comment
Too late.  🤣 I spoke with a club mate and he agrees with Chuck that the misalignment will hopefully work it’s way out upon adding fillers. My twist is not too bad, almost imperceptible. But I can see it when looking down the long axis of the bulkhead former.
Sigh. My impatience is a reflection of my frustration with this blasted quarantine.  😤
Link to comment
Pat, I was too worried about the warping but the fillers mostly solved the issue. I wish I had also solved the warping issue fully before installing the bulkheads but I think it's manageable in my case.
Current:
Complete:
On the shelf:
Link to comment
Thanks. I am watching your build as well. I think we had roughly the same minor twist. Hard to get rid of it...and I’m sick of staring at it without making progress. So...onward. The other issue was some warped frames but I think the blocks can address this as well. Fingers crossed.
Link to comment
Spent time on the frames and filler blocks. You’ll note that I made one board for ‘holding’ the ship and one for use in adding the frames.
The white board just has sections of wood to center and hold the keel straight but I’m always worried I’ll hit the ship and snap the keel off. 😆 The holder with the cherry wood base has holders with a much higher profile and reinforces the bulkhead former. Feels really solid and I’ll use this now for building.
But it all worked out...and I was able to get the frames (even the slightly warped ones) trued up.
Buddy of mine had some spare 1/2”x2” sections of basswood. Since I did not have enough balsa, I improvised and used the basswood layered blocks. I can add the balsa to the bow and stern sections where the curvature is a bit tricky.
I did a fairly good job trueing up the spine of the bulkhead former. Very little skew left and what there is is not perceptible.
I also added a couple of smaller blocks between the top of the frames which bracket the false deck. I wanted stability and they shouldn’t show once the main deck is on. I cut a piece of 1mm basswood which I can use to lay down the deck planks for the false deck.  When I’m ready to plank the main deck, I can slip the false deck in and secure it without an issue.
Spent some time continuing to sand/refine the hull of the ship's boat, as well as plinking away at making some brass plates. (What an onerous chore). Ended the day making some of my own sanding files.
Moving on!!!
:dancetl6:
Link to comment
Okay...so I putzed around with the ship’s boat a bit more.  Some wood filler and a few watery coats of white (Tamiya) paint and the exterior looks pretty decent.  The interior may need a darker shade of some earthier color.  Beige might be a bit historically off.  This is where I’ll stop on the initial work on the ship’s boat.  Will take this up a bit later in the build, but I’m pretty satisfied with the result for my lack of experience.
Now speaking of lack of experience...I decided to do something ridiculous.
I’m awful at sanding....takes me forever!  The transom kind of scared me after reading the practicum and watching some of the other build logs.  So, I decided to do something a bit out of the box...and build the transom in a way I might be able to manage the sanding a bit easier without going crazy.
I decided to build the transom off the ship as separate piece to be added later.  Was not as hard as I had thought it might be...I made a little jig to align the separate sections correctly and ensure the gun ports were at the right height.  Having it as a separate section gives me a bit of artistic freedom in how I can add and shape the supporting sections for the stern. Maybe not be the best way of building and adding the transom, but it’s a hobby!  🤣 Sometimes you just have to do it your own way!
You’ll note that in the pics above I am using a spare stern frame I had available to temporarily ‘attach’ (using some double sided tape) the transom piece to the frame...the earlier frames were warped, so after Model Shipways provided some replacements, I had a spare stern frame to use as a tool to help me prep the transom off the ship.
Below are pics of the sanded down transom piece (before trimming the sides...that comes later) dry fit on the ship.  Good fit...
And.....moving on!
:cheers:
Link to comment
Smart thinking for the transform! Looks very good!
Current:
Complete:
On the shelf:
Link to comment
Finally got some time to work in the shipyard!
I had already decided to prep the false deck off the ship and then slide it in when I was ready.  Took a piece of 1/32" balsa, cut my planks, used a pencil on one facing edge of the planks where they meet (I don't like heavy line between planks), glued in and stained with Minwax Golden Oak.  I might redo the false deck since the basswood strip I used had some serious graining...it's most overwhelming...but I put it on the ship and it looks fine.  I might leave it depending on my mood.  As it is only viewed briefly peering down the ladder, it may be just fine.  Here are some pics.
8087A451-0BDA-42E3-908C-A7D3346F0AE3-2741-000001B95FE7B0EB.JPG.4d2b4dabc51eb5e8eb7dffc152c1381c.JPG
7CE6840D-EF1F-4074-860F-6A5346E4932D-2741-000001B960427BC4.JPG.4fbe3d7c3f5cb6896e9fb7cf8b2b58ab.JPG
3196159A-F2FD-41CF-A22B-1C0B034142F9-2741-000001B96094C1C9.JPG.7e62db82905183d9ac1a4b82481bad2b.JPG
5E1837D3-26DB-4131-B321-75A8A6C7EFEE-2741-000001B960E8EA97.JPG.e03a227859a755e516517e43c56513e2.JPG
A1E3CD04-3E58-4C1E-A312-E8169341108C-2741-000001B9613CC84E.JPG.6b455209fd47579a6558472c0a963fef.JPG
72B5A97C-1C47-4A8C-AA45-2B75B9621ABD-2741-000001B9618CC705.JPG.ee715a55180401a76a97388294253d81.JPG
I also shaped and added my bow fillers.
49A15D84-1829-4AFC-8908-94D35B1E4942-2741-000001B961E8D20D.JPG.b9156084c35de07fc0130789cce5dd72.JPG
E38CE432-D24E-4F5E-B98B-B2C00ECB47C2-2741-000001B9623A0AF7.JPG.faf6c3fdc7743f33df3fc5401695a3ee.JPG
BE07109D-A9E8-4AC5-9D46-62F362D27457-2741-000001B96288B55F.JPG.e8d93c3cf8b95feef4c36729ffc2c229.JPG
13A3BB79-F88F-4CC1-BCD1-BB095A77352C-2741-000001B962D990EB.JPG.e77feacf04a35b4b56cd548b42d4fa19.JPG
It's minor progress - but it is progress!!!
:cheers:
Link to comment
So, I've been putzing with the transom.  I know the gun and sweep ports are on the agenda, but I really wanted to have the tail end of the ship addressed before I started futzing with setting up the sills.  If you recall, I diverged from Chuck's awesome practicum in that I made the transom off the ship as a separate piece.  This was actually not as hard as I had thought.  (See below - attached to spare frame using double sided tape)
Attaching the transom now will be simple - but since I absolutely suck at sanding, I knew if I attached the transom, then added the filler blocks, I'd probably wreck the transom in the process of sanding/shaping them.  So, made a couple of solid wood stern fillers which I roughly shaped.
Once I got them glued in place, I attached the deck mounting block and mounted the ship upside down.  (I use an Amati keel clamp which I have attached to a rectangular piece of 3/4" plywood - it's solid as a rock)
The mount allows me to get solid purchase on the ship without worrying about snapping off little bits.  I'm not very good at holding things very steady, so this process gave me confidence in shaping/sanding the solid piece stern fillers.
I am not entirely certain the shaping is perfect - I'm not a sculptor.  But, it 'feels' about right and it's a good start - at least sufficient for me to visualize what I will need to do with the transom.  After I did a quick dry fit, I could easily see that I would be best served to add a small bit of wood at the edges of the transom to help hold the lower planks, as well as see where I will need to shave down the sides of the transom.  The only question I have is....how in the hell do people cut away sections of the transom??  I have no idea...but I have a feeling I'll be sanding it away a bit at a time with my Dremel.
Again - I'm sure this is not the normal way it's done.  But I like the idea of being able to slowly chip away at the stern section without committing fully to attaching the transom.  I guess I'm just not that confident, and I'd prefer go slow.  The planking scares me...maybe I'm procrastinating to delay the inevitable!!  :dancetl6:
One other thing which I've decided is how to close the gaps between the bulkheads (where the deck planks will be placed).  I believe adding a false deck would be best and provide the best support.  A while back, I invested in some birch (I think) sheets that are 1/50" thick.  Perfect for the purpose without adding too much to the height of the deck...so I'll take the 0.020" of additional thickness when setting up the sill runs.
That's it....moving on (in my own, meandering, and certainly novice kind of way!!)
:cheers:
Link to comment
Beautiful work Patrick, I wish mine was as clean and precise.
Are you kidding me!!!  The work on your Bluenose is awesome.  I'm not even close to your level!  😃
Link to comment
2 hours ago, NovaStorm said:
What you have done so far looks great and you are right with your stern filler below the counter. You can't have enough there.
Thanks, Novastorm.  Actually, watching your and Walrus' Syren builds gives me a lot of background and inspiration.  Good to have folks on the board doing the same kit....it truly helps as I've only completed one ship...and that one took me a while!  😃
Link to comment
Well, been an exciting day. Glued to TV watching the SpaceX launch. Amazing stuff. Made me feel like a kid again!
Afterwards, retired to the shipyard (actually sent to Shipyard by a grumpy Admiral!) to see if I couldn’t get the battens affixed on both sides to start my gunport sills.
My mistake was thinking it would be easy. I had a hard time getting both sides aligned and giving me a good sweep from stem to stern. My other mistake was assuming it would be easy to get the battens in!  But I’m the end I did...I think I’m close...so I’ll call it good and move on...
Here are some pics.  I figure it was worth the additional time in the long run.
Moving on...
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
