USS Kidd DD-661 by tigerdvr - FINISHED - Trumpeter - 1/350 - PLASTIC - from USS The Sullivans kit
Progress--  I don't know what the pieces that run along the deck edge midships are called. Part of the rail system I guess. If anyone can identify them I would appreciate it. Anyway the bottom of these are off the deck so water could run overboard under them.
I mixed a color to paint the spaces between the uprights so it would appear that they were, in fact, off the deck.
005.jpg.fd4b268366c8e2f151da9fde12f57705.jpgThe actual color has more blue in it
The secondary conning station, 40mm quads, and life rafts are on board. The signal halyards are made of EZ Line.
001.jpg.d6836ec9fb196eda2e7a14db9d3f8105.jpg004.jpg.c713aaf8cb2dd4afba45024134db357d.jpg
002.jpg.c350499638e933b766a5bd22e2c1a6f9.jpg010.jpg.f9108282a150e5fdf0802ea8d963e99f.jpg
More details and the rigging still to come. The mast uses nothing from the kit. Brass rod, PE, and misc shapes from the parts box. USS Alaska
contributed a lot of items.
Edited by tigerdvr
Space
Cheers, Harley<p
Under Construction:       USS Curtis Wilbur DDG-54 1/200 by ILoveKit
Completed:                     F-35A 1/48 by Tamiya
                                        USS Atlanta CL-51 1/350 by Very Fire
                                    Liberty Ship John W. Brown 1/350 by Trumpeter
                                    HMS Spiraea K-08 1/350
                                    USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                  USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                  USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                  USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                  USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                          Brig Syren 1/64 Model Shipways, Wood
Started,On Hold:     Frigate Confederacy 1/64 Model Shipways, Wood
Link to comment
Share on other sites
Looks fantastic! Can't wait to see the final details! Your photo are excellent too, I will refer to them often.
Ziggy
Edited by SigEp Ziggy
Link to comment
hello Harley.......checking in to see your progress.  you've done quite a bit I see.....looks really good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks Popeye, I'm getting another chapter ready for the log. I keep on finding little details to try and add to the Kidd.
How do you learn or know when enough is enough?
Regards, Harley
Edited by tigerdvr
Unintended picture
Cheers, Harley<p
Link to comment
Work on small details continues. The Anti Kamikaze update replaces the seven single 20mm Orlikons with six twins. My twin mounts are from Black Cat Models and are quite good. They come in one piece so you can't realistically change the elevation. The muzzles were pointing at the gun tub walls. I glued the mounts to a strip of .27mm plastic and then trimmed the new base.
003.jpg.d2e488e77213fbe8eee74d6d39e2dd41.jpg004.jpg.9a055af3cf626020b1c00dd6465b4c4e.jpg
008.jpg.135593c1edd259c9bd84f4417de4a239.jpg014.jpg.c6274fad396e8d743bcb35993db97eae.jpg
023.jpg.f544b3c54d2060df094beea98df4f39e.jpg029.jpg.f8b35d03112cdc5b52dd594417b2959e.jpg
The railing installations on the deck house seem to vary a lot. I wasn't happy with the way the railings looked at first so I cut the top rail off some areas and painted the top rail black in other areas to simulate a line in place of a rail. This simulates a line instead of a metal rail. References show that the rail systems appear to be removable to clear the torpedo tubes and main battery mounts.
021.jpg.6b4c51b8680449a86fbb5a2444e56387.jpg032.jpg.bdfbbbf4440c53bca2dc7e70691780ee.jpg
022.jpg.ee0f5ea0790c0f7ed0ab2627d6cb4205.jpg018.jpg.a279c17dd675b76af38c5066f786e3d8.jpg
Next I'm working on the rigging, paint touch up (endless), and boat davits.
Cheers---
Cheers, Harley<p
Link to comment
Beautiful work on such tiny pieces. One slip of the tweezers and those parts can be lost in the void. She’s coming along nicely.
- Brian
Current Builds:        Completed Builds:
Mississippi River Towboat Caroline N.                                                    HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways
Link to comment
to know if you've added too much is a two sided question..........do you feel that your desire is satisfied,  or is there any more room on the deck? :ph34r:  she's look'in really sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
After the rails were installed in a conventional manner I wanted to make the rails look more like cable/destroyer like. Masked the hull for protection.002.jpg.73e924a27a462095af0c66f00477afe4.jpg004.jpg.bfd7ba3739606213a154a5ca057039de.jpg
The hawse pipe was configured to accept the anchors from Blackcat
002.jpg.0aff0457fa0334db12f0db6b4d41e036.jpg004.jpg.4d6c48d21ed84ac2163933dc8d35d057.jpg
Replacement torpedo crane was fashioned from brass, PE, & plastic
003.jpg.1b94a667b0b63fc7dff2c6142fcb4375.jpg004.jpg.1dedc70cc03a98b7a617138f95c52e03.jpg
New torpedo tubes from Shapeways painted and installed
013.jpg.d973bac1a07cb4ba038f3580c8c6b7c9.jpg014.jpg.f99f2be607bd2020231115692ef3a3fd.jpg
Capt. Kidd's caricature, authorized by the Navy, was actually painted on a metal plate which was attached to the forward stack.  I reduced a photo of the Captain to less then a quarter of an inch.
1556487605_Captphoto.jpg.a422b763adffc3577774964bc9164c82.jpg329953846_Capt2.jpg.cc524332cf173e379aa970bb9e02104f.jpg
The ship's boats and davits became a real challenge. The boats were OK but I needed to combine the kit and Shapeway davits to make it work.
Left is kit, right is Shapeways, middle is combination used                               Clay was used to position the boat while fitting the davits
015.jpg.c8f9dbcfe7f5360cafad20f58001700d.jpg008.jpg.b1f57a1b2ac5636b71b16f2edb355f4d.jpg
PE, different size wire, and plastic completed the boat installation
018.jpg.8d529b1ed18e6619fccbf42db2ad2205.jpg022.jpg.e92a28ed994c0d583dcd98650c72ad17.jpg026.jpg.1f3c6dbe8bfec8677c9a9643ec3cd4b4.jpg020.jpg.cb14985ee5f962ca6764d75a76a0838d.jpg
                                                          Water practice, more touch up, and final details and she should be ready to ship out
Standby to cast off!
Edited by tigerdvr
Sequence error
Cheers, Harley<p
Link to comment
look'in super! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks Popeye, I'm taking your advise regarding space left on the deck and desired results.
Working on a seascape for her then she will get the "Finish" tag.
Cheers, Harley<p
Link to comment
USS Kidd-FINISHED    Named in honor of Isaac C Kidd, Rear Admiral, USN, who died aboard his flagship, USS Arizona, December 7, 1941.
Started in June, 2019. The hull, deck, and main superstructures are from the Trumpeter kit. The rest is a combination of kit, aftermarket, photoetch, and scratch built details. Main reference is USS Kidd On Deck by
David Doyle. Paint is acrylic. The screws and rudder are removed as the model will be mounted on a seascape which is under construction and encased.
201.thumb.jpg.9c47687848d255d4bd062b623802cea1.jpg400.thumb.jpg.8d0dbdfb2cc9dd325b243b3dc4914e0d.jpg
401.thumb.jpg.387724b116ab71dbd48ebc26e3cd1358.jpg500.thumb.jpg.e582b5c3121353e66ff5223c89eaf4b1.jpg
600.thumb.jpg.c5b43589da667a468807e8fb14376455.jpg700.thumb.jpg.83fb63a5d239fb41b20c09585b3c2593.jpg
800.thumb.jpg.2f63b3eda88541a7aa8f2556aaaa1d78.jpg901.thumb.jpg.883b00d6cd573ba62f4ce136fbd1b1e0.jpg
902.thumb.jpg.70d66430d2d6b62d2a6c630db4dbbc56.jpg903.thumb.jpg.aae80d06deebcb05e6de662ddd79c333.jpg
Cheers, Harley<p
Link to comment
Very nice!  Congratulations on a fantastic build!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Very nice build.  Congratulations on completing this fine model.
Ryland
               - Nautical Research Guild
Link to comment
congratz Harley on a fine model.....she looks superb :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for the kind remarks gentlemen. I'll post a pic or two when she goes to sea.
Cheers, Harley
Cheers, Harley<p
Link to comment
Harley, job well done!  I hope I can measure up when I build my USS Kidd.
I can't remember if you're going to add sailors?
post script
Link to comment
  • 5 weeks later...
USS Kidd DD-661 put to sea. This my first water base of foil, ModPodge, and various gels. Case is from AcrylicJob.IMG_20191220_133446799.thumb.jpg.bfe022c738a7df0d5cbcd5f57d235df6.jpgIMG_20191220_133453126.thumb.jpg.0fbcd829a7b1d1adc633964eea275da0.jpgIMG_20191220_133510747.thumb.jpg.06b2ab209a5addeed0312f71c7382ef4.jpgIMG_20191220_195344505.thumb.jpg.dab3a9cb48eda4b5b87786ffb7f0e43d.jpg
Searching for the next project---
Cheers, Harley<p
Link to comment
That is a great build and one to be proud of Harley. I think ocean settings always bring a model ship alive.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thanks Ziggy, No visible sailors, the need to finish finally overpowered me.
Cheers, Harley<p
Link to comment
  • The title was changed to USS Kidd DD-661 by tigerdvr - FINISHED - Trumpeter - 1/350 - PLASTIC - from USS The Sullivans kit
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
