HMS Pickle by mugje - FINISHED - Caldercraft - 1:64 - first build
Your deck looks great! Doing a nice job of it all...
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Link to comment
Share on other sites
Excellent work!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Does anyone has some tips about how to install the capping rails? It's a tricky situation.
I tried with wood glue and nails, but it's not really accurate. The nails are splitting the bulwarks.
I only drilled holes in the capping rails (a bit smaller then the nails itself). Maybe also in the bulwarks?
It's to difficult to clamp it somehow.
Link to comment
Hi Mugje I held my capping rails on Sherbourne down with elastic  bands as you can put quite a bit of tension on with them.
Hope this helps
BTW  very nice job
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Great tips! Thank you both!
I have now first soaked the capping rails and dry fitted them with nails really careful, drilled the rails and the bulwarks. I'm letting this set for two days (going on a trip tommorow😁)
Then i hope the rails have the nice bend already in them when i'm gonna glue them with the elastic bands👍.
Sounds like great tips guys. I tried the bands but they pusht them inside the bulwarks, but the trick with the pieces of scrapwood sounds really clever👍
Edited by mugje
Link to comment
Okay...tested the method with the elastic bands, but couldn't get it just right. But the scrap pieces did help! I used the scrap pieces with clamps against the bulwarks, so it was easier to align the capping rails. But still used pins to nail the rails at the bulwarks. This worked pretty okay. Still needs lot's of touching up afterwards 😁😉
I found that the montage of the capping rails one of the most difficult parts of the build was for now, but really satisfying when it's done 😊👍
Link to comment
Ah tnx! It's a lot clearer now! That with the elastic bands does sound a lot easier now. I just misunderstood it wrong in the first place. Well, that's useful in a lot of ways indeed. Thanks for al the help👍
That lego seems also very handy, so i need some of that :D
Edited by mugje
Link to comment
Finished al the painting of the hull! That's a nice milestone for now :)
Especially the bottom of the yellow strip was difficult for me. I didn't get it perfect in my eyes with just the hand.
So i used masking tape and that made a lot of difference. Now it's okay to me.
The flashy spots on the copper plates are from the dremel. I have to clean the plates once more so everything can age simultaneously.
Edited by mugje
Link to comment
I used some steel wol and sandpaper to rough the paint a bit up. I don't like the clean look of a freshly painted ship.
It's needs to be a bit old and scruffy ;). The pictures don't capture it just right. In real life it looks much better.
I need to borrow the camera of a friend of mine so i can photograph the details better.
Link to comment
I enjoy the build a lot! In the past i was a person that gave up on things pretty fast because i encountered to many problems, but this hobby
is teaching me patience and selfesteem. Wonderful! 🎇
I'm so happy that i rediscovered the hobby again. I think that i wasn't ready for it a few years ago. Now it's time to move on with it, and to enjoy
the process it's given me.
Little personal sidenote ;)
Link to comment
It's needing some paintwork when it's finished but it looks already good now. It's really small! Almost to small for my trembling fingers haha.
And i find it a bit weird that Caldercraft didn't use solid pieces of walnut, but a kind of plywood idea with two small layers of walnut and something cheaper in between.
A bit of a compromise.
Link to comment
Hi mugje,
I expect solid walnut at that sort of size would have been too fragile as it would split along the grain... plywood walnut is a better material for the task, but it does bring with it the challenge of tidying it.up to look neat. The alternative would be a harder finer grained wood such as european boxwood, but it's very expensive compared to walnut.
Well done with those carronades! They look fantastic... much neater than my effort... Pickle was my first wooden model too. Keep up the great work.
Rob
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
