SMS Scharnhorst by Borus279 - FINISHED - 1/100
Lovely work and a pleasure to see.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Share on other sites
Gentlemen thanks for the thumbs up.
Finished the first part of the planking of the decks, quite a puzzle, but i am happy with the result,I'll Do not know exactly if the pattern used for the planking is correct, looked at a lot of pictures from other models of the Scharnhorst and not 1 is the same, So i decided to choose for this pattern, not the easiest way to go, But the easiest way is not my way :)
Link to comment
Thanks for the thumbs up and kind words.
Update:
Finished the other 2 decks of the gun citadel. And made some of the windows
Also made the coal hatches in the decks.
And did some work on the front deck.
Below a few pictures, telling more than words..
Edited by boris279
Link to comment
All looking very smart Boris.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Gerard,
Thanks for respond, I saw it today too, great that they finally found her,
hopefully in the future they will leave her in peace, and respect the fallen,
Remarkable to see how good was the condition of the wood on her frond deck.
speaking about deck, still working on the last part of her deck, quite a puzzle too go.
below a few pictures.
Link to comment
Deck looks great Boris. I also like your beautifully organised work area.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
1 hour ago, yvesvidal said:
This deck reminds me of 18th century "marquetterie". It truly is a piece of art.
What technique did you use between the planks, to simulate the caulking?
Yves
first I tried it with pvc electrical tape, stuck to one side of the wood and then saw boards of it
so I had cut a stock to work from.
but discovered that the glue from the tape will come loose for a while.
had tried several types of PVC tape from cheap to expensive, all more or less the same result
This is mainly due to the warmth that we have here in the Caribbean.
That's how I came up with the idea of painting the wood on both sides in black and then saw boards of it
the two sides laid together, give me the perfect caulking seam.
Edited by boris279
Link to comment
That is a new one on me but it seems an excellent idea Boris - I must try it some time.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Because it’s still Christmas time and decoration time, I decided to decorate my lady too 😀
Made the decoration for the bow
some of the stairs and the spare anchor.
below a few pictures .
Would like to wish all of you over here, happy days to come, and a good and prosperous 2020.
Link to comment
Boris - not quite sure how you did the decoration but it looks mighty fine. I would be interested to know a bit more detail of your technique.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Keith,
The idea came more or less, because i did not have a choice, so sometimes you have to be inventive.
i went out to the "local hobby shop" to buy fimo polymer clay, to make the decorations and to make a kind of copy of the bow section to work from.
but due to the fact that i live on a island and modeling is something that i absolutely not alive on this island, i came out empty handed,
so i went to the building market, and found wood repair epoxy putty and a plastic repair epoxy putty, so i bought 2 types, the wood epoxy has to be hard dense and fine structure  for the copy of the bow section, to make a negative copy and a positive copy, but with a medium till fast reaction/cure time
and the plastic epoxy with a medium/ long reaction/cure time, and super fine structure
i protected my bow with some tape, and added the wood epoxy on the bow section(negative), after that it is almost set I removed the epoxy from the bow section, let it cure completely 1 hour, than i treated the inside with some light grease, applied the wood epoxy on the inside(positive), and removed it when it was completely cured.
than i treated the positive very very lightly with some white grease. builded up my decoration from the plastic epoxy, on the copy of the bow section, shaped it with micro carving and clay tools.
let the epoxy almost cure completely, than i used a sewing line to remove the decoration from the bow section, let it cure completely 3 hours.
some primer, paint and ready !!
hope it helps you.
The brand of the epoxy putty i used is J-B Weld.
Edited by boris279
Link to comment
Thank you very much for all the thumbs up.
started to work on the first gun tower. As it is a partly kit, I decided to remake the tower again, did not like the one that came with the hull.
after studying old pictures and looking for some existing models I came to the following result.
(Still work in progress)
Edited by boris279
Link to comment
It's difficult to view your craftsmanship without just grinning. Very well done is an extreme understatement.
Cheers, Harley<p
Under Construction:       USS Curtis Wilbur DDG-54 1/200 by ILoveKit
Completed:                     F-35A 1/48 by Tamiya
                                        USS Atlanta CL-51 1/350 by Very Fire
                                    Liberty Ship John W. Brown 1/350 by Trumpeter
                                    HMS Spiraea K-08 1/350
                                    USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                  USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                  USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                  USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                  USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                          Brig Syren 1/64 Model Shipways, Wood
Started,On Hold:     Frigate Confederacy 1/64 Model Shipways, Wood
Link to comment
From modeling to fixing a leak in your engine oil pan - J-B Weld has a solution.  Very nice bow decoration Boris - excellent delicate work.  The ship is beautiful and progressing nicely.  Thanks for sharing it with us.
Gary
Completed Scratch Builds
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
