Bluebell by Kevin - Revel - 1/72 - Flower-class corvette with GLS upgrade - restarted Jan 2022
11 hours ago, Kevin said:
i copied this idea and it never worked for me,
i have no idea what was supplied to me  as 60/40 solder
since then i have changed it and the flux, and getting much better results IMG_4798.thumb.JPG.15829a82db82fe8a11cd7a84b3776bd8.JPG
will post photo later  of what i am using
That looks really tidy mate  and also far stronger than any glue.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Re: the use of CA for photoetch, for bigger assemblies/longer joints, after bending and tacking the assembly together, I run a bead of thick CA along the inside (not visible) side of the joint and sprinkle the joint with baking powder before the CA cures.  The baking powder causes the CA to set quickly and form a filet, making a more solid structural bond.
Also, those GLS sets can be pretty challenging (IMHO), so don’t beat yourself up if you find them difficult.  Looks to me like you’re getting the hang of it.
Cheers,
Keith
Link to comment
good morning everyone thank you for the likes and comments
MAIN DECK
all the decks are brass and sit on top of the kit plastic ones (after all the surface detail has been removed
this is the main deck 18 inches long, to save metal, various parts have to be removed these areas are covered over later, by the forecastle and bridge
first all the rivets have to be knocked through from the other side (about 500 on this piece) marks are provided to show where they are and a centre punch is used to do the work
the sides are then folded upwards and soldered in place, im not sure ca would do this very well
IMG_4806.thumb.JPG.b5f4918779dde7a266f99849ed8c4f7e.JPGIMG_4805.thumb.JPG.657823d284774f88de80091362a86e56.JPG
and then two long strips as long as the whole piece are soldered against the folded piece to represent rivet lines i did use ca for this
IMG_4819.thumb.JPG.71c03d3f8d4727909b1939edcb83ecec.JPGIMG_4820.thumb.JPG.220df30fa244180031eac9a909d8457d.JPGIMG_4821.thumb.JPG.c7529908e983cddf64747812109e1a2f.JPG
Edited by Kevin
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Kevin, it's looking great.  I feel for your soldering frustration as I've had the same when trying to solder tiny bits.  Regarding heat transfer ruining made joints, when I was soldering plumbing pipe back in the day I would occasionally put a damp rag around the made joint while soldering something nearby.  I don't know if this technique transfers to PE world but a scaled down version might be worth trying on some scrap.
Thanks for sharing the build.
Steve
Link to comment
Good afternoon Steve
using a lower heat/melting point solder has taken most of the problem away, god knows what that solder was that was supplied by Ebat was, but for me it nearly destroyed my williness to even start the build, im much happier now, another update tonight or in the morning
the change of solder has eased a mysterious rash across my hands as well, no i dont wear gloves
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Nice work Kevin.  If I was handy with photoshop, I’d create a “Kevin the Riveter” picture like the old “Rosie the Riveter” pictures.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
lol - please dont,
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Loving the metal deck mate - its coming on a treat.
OC.
Current builds
Completed works.
Link to comment
Heat transfer to a broad area is best avoided by using a soldering iron that has a larger capacity to recover energy/heat. I learned this long ago by trial and error and watching guys that were very good with solder. A great soldering iron makes a HUGE difference. The longer that iron must stay in contact with the material being soldered, the more problems one will have with unwanted heat transfer. Secondly, there are specialized aluminum heat sink clips that are on the market of various shapes, size, and descriptions for solder work. Having some of those handy for soldering work is a game changer.
Like these: https://www.jpmsupply.com/Soldering-Heat-Sink-Elenco-ST-23-p/92135.htm?gclid=CjwKCAjw7uPqBRBlEiwAYDsr18OJC8B7Q5bj0cL5KCxt0xElwahf-xJoLbkK2w5Sn76s8OuJMQRawBoCNxYQAvD_BwE&click=2
Edited by CDW
Link to comment
good evening everyone
not much more i can do to the main deck for the time being, i will need to do some/lots of hull work before that will be put into position, at least for now it has something to sit on
so its back to the bridge
Bridge rework
not so much re-work, but i bought a new set, i had to as the last one was never going to be presentable, however the bits will be kept for another project i have in mind
although not perfect, i am much happier with the outcome,
the radar tower is at present from the old set, as the replacement has to be remade, all in all a recovery, for me anyway
IMG_4823.thumb.JPG.a468a1673f17bd4168256a8e0d89099b.JPGIMG_4824.thumb.JPG.3d3d9d771e2b770f9e865219138dced0.JPGIMG_4825.thumb.JPG.f80c0a64d82b54388c5bb9cfe550b984.JPGIMG_4829.thumb.JPG.325578abcf6dbeed4c37f4801c27bf24.JPGIMG_4830.thumb.JPG.6d6813c903adeef1cc7a0d74f6560de2.JPGIMG_4831.thumb.JPG.0f85c6e4c01a08fc1ad4a10816d83f23.JPGIMG_4832.thumb.JPG.2631df10a8c4499d084786962169ad61.JPGIMG_4833.thumb.JPG.e00a713ed960d6601e06bc6f405e7b84.JPGIMG_4834.thumb.JPG.789e21ffe13fd36322de55843ab373a7.JPGIMG_4835.thumb.JPG.60637623b1f60e16af2eed0869aa5f0c.JPGIMG_4836.thumb.JPG.31c8c14c9b270dcf8a53106c7b0cc71e.JPG
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
That looks excellent mate  those solder joints look spot on.
OC.
Current builds
Completed works.
Link to comment
OC.
thank you, they are better, they feel sturdier, but could be a better join all round, and some places could do with more tidying up,
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
look'in good Kevin.......mov'in right along now that the soldering problem is taken care of :)      real nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
im enjoying this build now its so nice to actually move the build out of the way rather then me have to move to do something
i compared the two Bluebell v St Nectam 1/72 v 1/30
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
After soldering pieces together, if there is too much solder remaining around the joint I sometimes use a hobby knife or a small dental tool with a chisel-shaped tip to carve away the unwanted solder. Be careful not to gouge into the brass and create a scratch.
Then to remove more of the remaining solder to produce a very smooth surface I use a fine wire brush in a motor tool (Dremel). The wire brush removes the soft solder quickly and just polishes the brass. However, it is very effective at removing the solder, so be careful that you don't remove too much! You can also use an ordinary steel wire brush, and even a brass wire brush for less aggressive polishing.
One thing to remember is that when the hot solder flows over the surface of the brass some of the tin actually dissolves into the brass forming a tin-brass alloy. In this way the solder "welds" itself to the brass surface. But it is the softer solder between the brass parts that "glues" the pieces together.
The wire brush will remove the soft solder build up on the brass but it will not remove solder that has dissolved into the brass - nothing will. Even after you have removed all the solder there will still be a tin "stain" on the brass surface. To avoid this you need to apply the solder and the soldering iron to inside surfaces where possible.
To control heat flow so you don't unsolder parts when adding new parts just wrap wet cotton balls around the parts you want to protect. Use alligator clips to hold the cotton in place. Water flows to contact the metal surfaces and absorbs a tremendous amount of heat as it evaporates. This makes water a much better heat sink than almost anything else, and it is easy to clean up.
Edited by Dr PR
Link to comment
rebuilt the tower last night
soldering is getting better
compared to the last one
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Beautiful work - looks like you got the hang of things.
Mike
Link to comment
No comment needed!  👍  You must be happy you restarted.
Cheers,
Jason
In the shipyard:
Link to comment
Really nice mate.
OC.
Current builds
Completed works.
Link to comment
Practice does make perfect.  Looks great, Kevin.
Link to comment
Sorry for the long time between posts, lol it takes ages to make something to show
my biggest concern is the phots im posting make the build look very messy,(the brass is showing the stains for being handled), im sure i will find something to clean it up closer to being painted
the bridge work continues
i dont actually know the name for these panels,  i quess it would be bridge wings,
my soldering has greatly improved, but i still make the occasional mistake and still lots to learn
also remounted the brackets for the gunmount platforms
again sorry for the photos, i will need to rethink how to shoot something as bright as this is
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Very fine work mate  she is looking lovely  - we all need to  remember  your are soldering the joints not simply gluing  (that in itself is amazing)
OC.
Current builds
Completed works.
Link to comment
very nice work Kevin! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Post birthday celebrations, and no alcohol involved
Bridge supports
two trpes are given in the etch set one of them for the Bluebell, there are a lot of choices to be made, and i can see it being easy to make a mistake
the legs are braced from behind, a week ago this would have been a nightmare for me, but with the right flux and lower temp solder it is working for me
IMG_4887.thumb.JPG.4d50a2b14e7f0142edacb368e4b4a5a8.JPGIMG_4888.thumb.JPG.69c0c57294d76a81011245046907e896.JPGIMG_4884.thumb.JPG.fc011194f1ee8e8a2d07518dce391af5.JPGIMG_4885.thumb.JPG.a55e009485516e65c6073b92f7494100.JPGIMG_4886.thumb.JPG.1717236bad88d4214c9314d8074431e9.JPGIMG_4892.thumb.JPG.d3006c9bf354e538a602eb3acbe50f0f.JPG
centre braces fittedIMG_4893.thumb.JPG.61cec589c05c1f34aba88fe472a01802.JPGIMG_4894.thumb.JPG.bbad51193ea0110995fc5bb8a69715ad.JPGIMG_4895.thumb.JPG.c879f3469b8fba04db82d5fc645fa3fb.JPGIMG_4896.thumb.JPG.01d9249e8295b35fb4eb049c41e4983e.JPGIMG_4898.thumb.JPG.fe97246546aefe457c6228b972274680.JPG
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Excellent work mate  - really impressive.
OC.
Current builds
Completed works.
Link to comment
Nice clean soldering there - fantastic!
Mike
Link to comment
Good evening everyone
whether it is right or wrong, yet again i find myself building the big bits, and yes even some of the kit is being used
Funnel and mast
the moulded banding is removed, as is the top spider the body is then covered from the PE set
IMG_4902.thumb.JPG.4a83777a2f5855434f1f8ab7dd6f86a5.JPGIMG_4903.thumb.JPG.c963b751bcaf0289dc8236dee8f41e11.JPGIMG_4905.thumb.JPG.b73e2cbd934e75d4295e4ee655823b93.JPGIMG_4901.thumb.JPG.905ceb184c3c0b5abb2aa1cde3bbe996.JPGthese two units are made up from the box
IMG_4912.thumb.JPG.45449965109e2c3350402e0b2e415b59.JPGIMG_4913.thumb.JPG.fd600230090debb92a69b8635307e6e5.JPG
more soldering
IMG_4907.thumb.JPG.dd9cb200d2fab1087a02785b3245b958.JPGIMG_4908.thumb.JPG.01c55cd31a0e48ff2ea5ac18a4ee7d91.JPGIMG_4909.thumb.JPG.59154f60e931b2c6ed7f1d483424ae72.JPGIMG_4910.thumb.JPG.e85d4e743ad0c33f1838568d37b8d291.JPG
poor photo, was there to show the ladder against the funnel
4" gun
two shields are in the kit 1 suare the other curved, not know which im using yet so made them both
IMG_4932.thumb.JPG.12b47915418fd4f8aeadd0b45fefd671.JPGIMG_4943.thumb.JPG.95719dbee1d1f5a2a775671d86566d95.JPGIMG_4935.thumb.JPG.7571cdc535da16e230c8364cef59bf7f.JPGIMG_4936.thumb.JPG.f70833741ebc11cbeaf56687f92adf07.JPGIMG_4938.thumb.JPG.5e40158349c39669dc88842cce264ec9.JPGIMG_4939.thumb.JPG.3a71399573b8cc43333a5a392e7f1df3.JPGIMG_4940.thumb.JPG.68b95a2dd087bc2dae2b73bc99a10b68.JPGIMG_4941.thumb.JPG.4a9eb58f1a63320c9f2c8fc9badb8126.JPGIMG_4942.thumb.JPG.f3940ac2f8b13ac9391b42008e09425b.JPG
the bandstand went together better and anticipated
legs folded out
wooden spoon to shape the ring
IMG_4920.thumb.JPG.f7e44b9a0a3a5c494b1f9305126122da.JPGIMG_4922.thumb.JPG.dded3f6413bc6308c2e45a57c18bc117.JPGIMG_4923.thumb.JPG.92f919b1fbee192c75de8c0031085f63.JPGIMG_4925.thumb.JPG.1a2f2aba3291174ba5026faace43f362.JPGIMG_4926.thumb.JPG.207a530c59123123c39ec4846ebb81b8.JPG
edges tacked in numerous locations
i decided to solder this first before adding, it actually worked ok, there is a ridge the disc sits in, so once in place it was just tacked again
IMG_4928.thumb.JPG.93013261cffc8108190e12611a90b802.JPGthIMG_4929.thumb.JPG.31eb4f8bd7efe7574d398942dc3376d6.JPGIMG_4930.thumb.JPG.26cd6983657a783c33963c7b0ba6de61.JPGIMG_4931.thumb.JPG.d9b7550f11012487859d857c00876444.JPG
and the wheely bin again
IMG_4954.thumb.JPG.fca4fe0ffd30a8927c84c2a9eb0ca72c.JPGIMG_4944.thumb.JPG.5ed73dac39e34f158fb21608abdd0157.JPGIMG_4945.thumb.JPG.0d2dfb372181e053296c54a09d86436f.JPGIMG_4946.thumb.JPG.86393f6d025c9f71cb48ea7868b4b6ed.JPGIMG_4947.thumb.JPG.6e85fe5b992d9fad1acce1beeece57a8.JPGIMG_4948.thumb.JPG.22bf95bd692bb2b492354a74b1dbd12d.JPGIMG_4949.thumb.JPG.db6dda8ed60c8cdbc7f5b0da32390ff3.JPGIMG_4950.thumb.JPG.40db9ffc7d5b871b864fbff8e9c8870d.JPGIMG_4951.thumb.JPG.161ef0b4421dc66968513e246a5df1cd.JPGIMG_4952.thumb.JPG.f87ee6b7362ef810609bcdf7272666c3.JPGIMG_4953.thumb.JPG.c149d8f7b766fb2be5b455d91f7003bd.JPG
Edited by Kevin
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Superb work.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
