HMS Winchelsea 1764 by Rustyj - FINISHED - 1:48
I was a little concerned with the first photo🤣 Glad you’re back at it.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
Thanks Chuck. It took me a minute to figure out where I was last at. :D
It was great to see you and everyone else. I can't believe it's been 2 1/2 years!
Sure thing Joe.
Thanks Bob, Yes I'm itching to have a go at those gun port lids.
Thanks for all the likes too.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Glenn I would wander into the shop to get something and moan every time I saw her covered like that.
Thanks Ben. Great to be back.
Rusty
Link to comment
A little update here. All the gun port lids have been made and painted.
The eye bolts and ring bolts are made and ready to go.
The the hinges have been cut from wider brass stock.
They have the holes for the eye bolts drilled and filed to shape.
The tops now need to be filed and shaped to accept the hinge bolt. That's it for now.
Rusty
Link to comment
Thats not a little update.  They take a long time to make neatly.  They look great.
Chuck
Link to comment
18 hours ago, Chuck said:
That's not a little update.  They take a long time to make neatly
Thanks Chuck, Yes they were long in the making. It's one of those man I've been working
on these for how long and that's all that is done moments. :)
Thanks Glenn. When you get to that point in your build send the brass.
Can't guarantee the turnaround time though!
Rusty
Link to comment
I've been trudging along with the gun ports on the starboard side. They are set in place but the
hinges have not been attached yet. I will remove the three port lids that will be open and attach
them later. Until I make the stand I'll be knocking them off every other day!
On to the port side now.
Rusty
Link to comment
lovely work, your work inspires many of us
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Thanks Kevin, Sorry missed your post. Also thanks for all the likes.
Trudging along slowly. Just got back from a little trip to keep the Admiral happy. :)
I've finished the lids on the port side and heading to the bridle ports.
Rusty
Link to comment
If I send you some brass will you make hinges for me😂🤣. Really great work, one of the reasons I embarked on my own Winnie.
Regards,
Glenn
Link to comment
Thanks Chuck.
Hi Glenn, I found fitting the lids more challenging than the brass so no problem!
Also thanks for the likes!
Rusty
Link to comment
The bridle ports are now finished and permanently in place. I'm glad there aren't any more to do.
Next I'll start on checks, hair brackets and hawse holes but first I had to paint the upper portion of the stem.
Between coats I sanded the faces of the multiple pieces with some 320 grit sandpaper.
These pieces are all cut from Cherry wood and part of the chapter 5 package.
Rusty
Link to comment
Thanks Tim and Glenn!
Rusty
Link to comment
Thanks Chuck, Its all been fun but now it's onto more fun!
I shaped and added the frieze to the checks.
I then started shaping the hair brackets. There are three layers and I started with the center one. I removed the char and rounded the edges. Next I have to shape it to fit snug against the hull and stem. It's hard to see in this picture but I've got a good bit of adjusting to do.
Once the inner piece is shaped to fit the two outer pieces will be glued on. There is an etched line in the top piece that will hopefully give me the correct angle for when attaching the hair brackets. Lots of different angles and planes. Gulp. Here I go!
Rusty
Link to comment
So far so good I think. On the starboard side I used temporary double sided tape to attach the template.
With this I was able to mark off the location of the cheeks and hair bracket. I had to make some minor
adjustments to the stem and figurehead to get everything in an alignment that I liked.
The frieze on the checks was left a little long to overlap onto the hair bracket.
Once the hair bracket was in place I used a sharp scalp blade to cut the frieze.
There will be a lot of cleaning and paint touch up once I'm finished. On to the port side now.
Rusty
Link to comment
Yes Chuck slow and steady it is!
Also thanks, JJ and Vladimir ands all the likes.
Rusty
Link to comment
Thanks Maurice. It's all to the excellent design.
Well I must say I had more time in the workshop these last three days than I did in the last two months. It was wonderful!
There are 3 layers to the hawse hole area. They were clamped on the model and heated to set the curve.
After shaping and gluing them in place I sanded the upper cheek and hair bracket to fit the hull curve. You can see how I left the frieze longer than needed. I then over lapped it and using a sharp scalpel blade cut it to match and glued it in place.
You can see the completed overlap and the scroll also added.
I have to yet permanently attach the figure head as I'm worried I'll do some sort of damage to it. Next I'll shape the bolster, drill out the hawse holes and add the knee above the hawse holes.
What a great weekend! ;)
Rusty
Link to comment
Leaving the frieze long is a simple step but a masterful idea I’ll remember.
did you use the fruitwood gel on your figurehead?  It looks great, for me it seemed to cake on so I’m sure I’m doing something wrong with the thick gel stain.
Regards,
Glenn
Link to comment
Glenn, I used the Fruitwood gel stain. If you brush it on and then rub it off with your thumb, it won't "cake". Just leave enough on to get a change of color. You would be putting it on very thin so maybe two applications would be enough. Btw; using your finger to rub it off is a good way to leave the majority of the color in the recesses of the figure. It will give the figure a more three dimensional look.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
