HMS Winchelsea 1764 by Rustyj - FINISHED - 1:48
Thanks Bob, I hope you are holding up well!
Also thank for all the likes.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Share on other sites
Thanks Ben. Very appreciated!
Rusty
Link to comment
I received chapter 3 laser cut parts in cherry from Syren today and I must say they looked great online and are even more impressive in person.
Now the quarter galleries fun begins!
Rusty
Link to comment
I've cut the transom out of 3/64" thick stock. This is the third attempt and it seems it was the proverbial charm.
First one the scroll saw went a wee bit out side the lines. The second one succumbed to heavy handed me.
I rough cut it on the scroll saw leaving the lines. I then fine tuned it with knives, files and sanding sticks.
I've clamped the transom in place so far the fit doesn't look to bad to me.
Before I permanently glue it in place and plank the upper counter I will test fit as many pieces to see if there are any potential issues.
Rusty
Link to comment
Thanks Jorge and thanks for all the like too!
I've glued the transom in place and the filler pieces have been placed on top of the transom to cover the two layers. They are 1/64" thick!
I've also placed the quarter galleries window.
The starboard side framing has started. The two pieces have been temporally placed with rubber cement as I check them out before permanently gluing them in.
Rusty
Link to comment
Link to comment
15 hours ago, Chuck said:
Take your time with those qgalleries.   They are tricky buggers.
Oh don't I know that. I must say I like the changes you've made to the v2.0 qgalleries over the ones we did in v1.0.
Thanks  nzreg. I've downloaded all sorts of pictures from various build logs and continuously bounce between them,
the plans and Chucks directions. I'll still mess some up but hopefully will keep it to a minimum.
Rusty
Link to comment
I'm tinkering with scrapping the moldings for the qgalleries and stern. This is the third attempt
and the first worth posting. The molding is 1/8" wide and 1/32" thick.
The picture isn't real clear but I think this is close.
Rusty
Link to comment
She looks really beautiful this molding. Very nice work.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
I like your use of rubber cement to check things out, yet another of your practices I’ve stolen, I mean adopted. Beautiful work!
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Thanks Glenn. I've been "adopting" everyone's practices here for years.
Thanks Jean-Paul and all the likes too.
Rusty
Link to comment
I've placed the molding across the stern under the windows. I've also shaped the tops of the qgallaries and
temporarily tacked them in place as well and glued the molding to the lower portion of the qgallaries.
Excuse all the dust and shop debris in the background. :)
Rusty
Link to comment
Thanks Fred. With summer upon us you will probably go roaring past me in no time.
I've framed in the windows for the qgallaries. The window frames as well as the rest of the
chapter three parts that came from Syren are first rate. Not that it comes as any surprise.
Chuck includes extra window frames and lucky for me as I had one casualty.
As I said it's busy the summer time with home projects so progress will definitely suffer.
Rusty
Link to comment
Thanks Mike! Having fun when I can get into the shop!  Also thanks for the likes.
Rusty
Link to comment
The galleries look really excellent. Great detail and craftsmanship. I would have needed more than one extra.
Regards,
Glenn
Link to comment
That gallery is coming along really well.   The cherry blends in with the Pear perfectly.   Well done.
Link to comment
Thanks Glenn!
Thank you Chuck. Yes they go together very nicely. If I didn't already have the pear I definitely would have done her in cherry.
Rusty
Link to comment
I've added the Syren laser cut fluted columns to the qgalleries and sanded the slope for the roof.
I've also made a test run of the shingles for the roof sticking them in place with rubber cement.
I just wanted to familiarize myself with the placement prior to gluing them in place.
This size roofing shingles are much easier on the body though I'm having a hard time finding a nail gun in this scale!
Rusty
Link to comment
Funny....it looks great.  Just remember to sand each row of shingles down even thinner after they are glued and dry.  They should be very thin...before moving to the next row.  In addition, measure the width of the entire area to be shingled to see if its consistent.   Because the angle of the roof changes the area to be covered will change as well.   Try and keep the area to be covered by shingles the same on the aft side and the fore side.  And finally....leave just the smallest of space between each shingle.  This way after you paint them.....if you are going to paint them I mean, you will have defined shape for the shingles.
Link to comment
That shot with the supervisor also presents an interesting perspective.  It looks like the model  is at least 1:10 scale..
Luck is just another word for good preparation.
—MICHAEL ROSE
Current builds:    Rattlesnake (Scratch From MS Plans
On Hold:  HMS Resolution ( AKA Ferrett )
Link to comment
Thanks Chuck. Yes I plan on painting them black and use some weathering powder. I'll
definitely sand them down and try my best to balance them!
Thanks nzreg, She had her walkies and needed a nap! When she's awake she's usually asking for a treat.
Rusty
Link to comment
Picking that hull up and moving around makes it seem 1:10 scale too! Thanks
Rusty
Link to comment
Incredible work Rusty, the level of detail is amazing.
Regards,
Glenn
Link to comment
