ASAT
HMS Winchelsea 1764 by ASAT 1/48
Signing on for this awesome opportunity- I plan on building her with Pear and Boxwood, going to use Chris L Bren’s Confederacy as inspiration and imitation. 😎  I will probably use every laser advantage that I can’t cut using my scroll saw,   mostly in Cherry I think, even if it’s just to use them as templates to remake from Pear.
Share this post
Link to post
Share on other sites
For a lot of those parts....the cherry will be indistinguishable from pear.   The fittings will have such small parts.....like the ships wheel for example, that the cherry version will blend in as if it were pear.   Same is true for the lantern, pumps, qgallery and stern parts like the window frames.  You will only have to worry about the big stuff for the most part.  You might even be able to use the deck beams in cherry and just plank with pear strips.   So once you get past chapter three it should be smooth sailing.
Chuck
Share this post
Link to post
That’s kinda what I was planning on although I might like the contrast of the cedar for the window frames and other accents at the stern and head.  I asked some other ?? On the plans discussion thread....  thanks!!
Edited by ASAT
CRS
Share this post
Link to post
    No registered users viewing this page.
Our Emblem
