HMS Winchelsea 1764 by CaptMorgan (Steve) - FINISHED - 1:48
Hello everyone:
Got a little shop time the last few days and was able to get the rudder finished and installed.  It was pretty straight forward.  I also only used 2 pins in the top & bottom hinge.  It is still removable & I will probably do that so I don't damage it down the road.  I tend to be pretty good at that.....
I used a 1/4" stick to hold the hinges to thin them down.  It was easier of me to do it off the ship and get them painted before installing them.  Again, this was to save possible damage to the hull.  One side is shown thinned below....
After that of course was the rudder trunk and benches.  All of that was pretty easy thanks to Chucks talent with the laser cutter.  And the lower window trim was simple enough, just a lot of trial & fitting.
Up next are the gun port covers and hinges.  Something tells me I'll have a lot of trial & error with those before I'm satisfied.  👍
Steve
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Link to comment
Share on other sites
Link to comment
  • 7 months later...
Hello everyone.  Just another update as I see it's been a while.  As in way over due.  Anyway I'm still here and moving along but at a snails pace it seems.
I have finished up Chapter 5 with the exception of attaching some of the cannon lids.
I also have all of the cannon built up & ready to go.
I have a small start of Chapter 7.  The forward walls are not attached yet as they still need a little work.
This is where I am as of now.  I have to thank everyone that has gone way ahead of me as it really helps with a lot of the little things.
Hope everyone is keeping warm....
Steve
Steve
Link to comment
Link to comment
Very nice work!
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
8 hours ago, Vladimir_Wairoa said:
As I observe it closely I particularly like how you treated figurehead and stern ornamentals with little more toned down shade - exactly same shade what I need for my winnie. would you mind sharing your "recipe" for how you painted them? are they wood or resin? Thank you in advance Vlad
Thanks for the comments Frank.  Your doing some beautiful work on your build also.  Looks fantastic!!!!
Vlad
Thank you.....
The ornaments are the resin ones.  I just used a wood stain.  Try some different shades on the back side to find something you like.  I just brushed it on, let it set for a bit, then brushed them off with a clean soft brush to remove any excess.
Mine are a little more 'orange' than I was looking for but they are growing on me.  The pics were before any Wipe On Poly.  Looks a little better now. 😉
Steve
Steve
Link to comment
Vlad
Thank you.....
Steve
Thank you Steve , yes that shade is I am after. true i will definitely try it before. Good luck . V.
Link to comment
Moving on -- I have finished up Chapter 7 today.
A couple of pictures are below that show the current state of affairs.
There were a lot of little parts to this Chapter and a lot of detail in those pumps & handles but I think everything turned out OK.
Now its time to fix up a few little details, do a little clean up, and read Chapter 8 again.
Steve
Edited by CaptMorgan
Steve
Link to comment
Looks really good.  Yes i deed there were a lot of parts for those pumps.  A tricky area for sure and yours looks great.
Link to comment
  • 5 months later...
Hello everyone:
It has been a long time since my las update - almost 6 months.  Been pretty busy with life and a few other things.
I have managed to get in some shop time lately and thought I would let you all know I'm still plugging away.
I have finished up Chapter 9 (still a couple things to add) and have a small start on Chapter 10.  The planking on the sides of the fore deck proved to be quite a challenge.
Below are some pictures to show my current state of the Winnie...
And my beginning of Chapter 10.....
Hopefully it won't be 6 months before I have another update.
Be safe everyone....
Steve
Steve
Link to comment
Here are some pictures of my Chapter 10 work.  It is pretty much finished except the eye bolts along the rails.  I have all the holes drilled but need to make more eye bolts & rings.  I have not done the ships wheel yet as I forgot to order it with the Chapter so will probably wait till Chapter 12 is available & get that done then. I also need the chain plates, etc, for Chapter 11.
20220819_145500.jpg.f0093f82e73f4833935bed551712a6e3.jpg20220819_145530.thumb.jpg.f10e9bcc74d0bb9cdf136dae32414ea1.jpg
None of the cannons are attached yet.  They are pretty glossy so I might dull them down a bit.  I think I will put the emblems on the Binnacle but leave it natural color.  Also leave the capstan natural - I couldn't bring myself to paint it.....
Pretty good progress for the last 3 weeks.   Till next time.....
Steve
Steve
Link to comment
This is some really nice work, not only the model, also the photography. Well done on both!
What is your method on removing char from the cannon trucks, they look great?
Edited by glbarlow
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Thanks everyone for the great comments.  Not sure I deserve them but we are our own worst critics I think.
I just used a small sanding stick very much like a finger nail file.  They were a little time consuming but most of them turned out pretty good.
Steve
Steve
Link to comment
  • 10 months later...
Wow - I can't believe it has been almost a whole year since my last update.  Mostly because I have been in Florida all winter while the ship has been chillin in Michigan.
Anyway, I have been back in the shop for a while and am in the process of finishing up Chapter 11.  While not done yet it is pretty close.
Some photos of the current state of affairs is below.
20230709_174029.jpg.2ea87fd05cfa2acb33b210f4bc0f5eeb.jpg20230710_135723.jpg.4e827fd98478bcb52e282463bb6edf4c.jpg20230710_135548.jpg.975af091b0adc3ca7738b2331ace627a.jpg
Finished up the gangways & ladders.  It was nice to finish up the inside details
20230709_174144.jpg.5959606bb3b1a66cb65d8d4704a9febe.jpg20230710_135556.jpg.33c2a7cc172963767b8c0908cd867bfc.jpg
I have to finish attaching the chain links, the fenders & steps and clean up the nail heads & some other little details.  Then I'll be moving on to Chapter 12 in a while.
Looking forward to that....
Steve
Steve
Link to comment
Welcome back. Very well done!  So cool to see one near finished.
Regards,
Glenn
Link to comment
Very nice work. Well worth the wait!
Rusty
Link to comment
Just a short update since I am officially done with Chapter 11.  I am still debating about adding the swivel gun but they are easily added later.
Moving on to the last chapter.  I will have to keep reminding my self to be patient & take my time...
Steve
Steve
Link to comment
