Coast Guard Cutter Pequot 1908 by svein erik - FINISHED - 1/48 scale
Nice plating - well done.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Share on other sites
A very good looking plating job Svein Erik      :rolleyes:
just a question, how thick is the carrier copper tape you have chosen ?  (without paperback, without glue film)
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
just a quetion, how thick is the carrier copper tape you have chosen ?  (without paberback, without glue film)
Nils
hi Nils, thanks for coments,
the copper tape is wery thin, i cant get exackt mesure .
i took some photo  hope that helps!
svein erik
Link to comment
I have to agree that the copper hull is almost too nice to paint.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
thanks for likes and coments
its no returns regarding painting the hull... its dunn😉 but not finish,
there are 2 cote of primer then i used 2 cote of nato black matt, as an under cote for the finish cote.
its going to be a little blacker and more glossy then it is now, am saving that for later,
i also pre drilled the hole for the portholes , it wil be larger then it is now (6mm when install)
svein erik
Link to comment
yes it do..
am using only thinn layers of paint , but 2- 3 layes needed for top coats later,
for that i need more paint .
so am working now with the dekk cabin and trying to deside if am going to
make some inventory at the aft cabin and also the steering house on top dekk.
Link to comment
thanks for coments and likes
the construction of the main dekk cabin is on its way , for this i use evegreen styro yust the main dekk cabin,
wood vil be used for the topp dekk construction.
at the rear you can se the 2 sleeping quaters and a sallon and the doors opening .
later i wil glue some wood panels etc on the wall, beds ,table etc....
at the aft i wil do the same.
the hole construction is loos and not glued on the ship.
i markt the windows , doors etc so i need to take this out to.
the main dekk construction wil get simulated rivvits using the same metod i did with the hull (thats because this part was made of steel plates.
the topp dekk was wood.
svein erik
Link to comment
hi again..
its now time to get some photo out again,
i have get the portholes on ,the first layer of the top coat on the hull is on ,
i also painted the main dekk cabin( yust the first layer) and also the rivitts bands ,
the windowns frames is install .
am working also with upper rear dekk cabin and when this is finish i wil get to work on the front cabin.
svein erik
Link to comment
Definitely looks like a metal hull, and its coming together nicely.
Michael
Link to comment
  • 3 months later...
On 1/25/2020 at 3:57 PM, svein erik said:
hi again..
svein erik
Hi Erik im so happy someone is building this beautiful boat. splendid work and wishing you sucess , following and looking forward ahead . Vlad
Link to comment
hi, thanks for the comments Vlad and Brian☺
Vlad  am doing some work on it now and i yust get the propell for this so i wil soon get this onboard with some new update!
Brian : the wood filler i used is yust basswood but it is harder and  then the light type,
i think its because it has been havest in a different way...
the light ome is very soft .
svein-erik
Link to comment
its a slow going job....
but the outlets are made, just need to get the anker howser on. The splash guard is also glued on.
the reilings are made and glued on and painted one time and need to be sanded and painted many more times,
i also painted the lower cabin black and white  but i need to get som work dunn her due to some over spray 😲,wel there is so many crinkle here so i espect it to happens!
my next task will be the propell etc so i can turn it paint it and last paint the lower hull then maby i can turn it again for the last time😉
best regards
svein erik
Link to comment
Continues to look very good, i look forward to the next instalment.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
started making the rudder, the size i do have on drawings but thats it ,
so the rest i have to make using photo and my eys so it can get as cloes as the orginal .
its made og wood ( boxwood) whit some rod and it wil have some protected plates etc , this is yust the start!
svein erik
Link to comment
10 hours ago, svein erik said:
but close as i can get it
Looks pretty smart to me Erik.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
On 7/7/2020 at 8:06 AM, G.L. said:
Very nice rudder, Erik. What is the function of the wooden beams at both sides of the rudder?
hi... wel... i mad  the rudder from photo because there is not a plan for this ,
after i finish it i was in contakt with chip calamoaro from Arizona
the wood on the rudder is a little to short , i can see in the bad poto that this is fastend to the stem and used to secure the rudder when the ship was buidt.
so i can do it ether way yust for the detajl , i only have to make the wood longer so it can be fixt to the stem or re make it with out
this detajl . i yust find a photo of this to .
svein erik
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
