Coast Guard Cutter Pequot 1908 by svein erik - FINISHED - 1/48 scale
Svein Erik,
Very nice build of yours, I might try the aluminium tape on my Danmark (Billings Boat), since it's will be painted white.
That hull looks amazing.
Then I have seen some other builds in the background. A Syren, 2 Longboats?, and an upcoming schnellboot Typ S-38.
Are you to make the schnellboot as a remote controlled boat?
Respectfully
Link to comment
Share on other sites
9 hours ago, Nirvana said:
Svein Erik,
hi .... yes there are some builds in the background .... you diddent see the cheerful    LOL,
thanks for the coments by the way,  i have a build log for the schnellboot and this prodjekt was not to be a RC model
yust for the fun of it , but itsgoing to be a nice model ether way 😊
svein erik
Link to comment
thanks for the likes!
a little update... i have painted the cabin and also made the draining system from brass tube , to hold it in place i made eyebolts from wire.
the roof wil be paintet black and i have to paint the windows then i can make the glass simulating 😊
svein erik
Link to comment
thanks for the likes.
my nex task was to finish the dekk planking , so i did  .
the plank is about 3mm × 1.5 mm wood from pine and after gluing it as bin sanded down and for the finish i used
oil, on this model i wil keep it like new .
and here are som photo of the dekk☺
svein erik.
Link to comment
svein erik.
fantastic !
Link to comment
  • 6 months later...
Am back...... wel i started on the huge build again
in most of the photo i have seen you cant see  the dekk clear , i can see there is a wood dekking , but is this for the hole dekk or
some of it ?  so i desided to yust plank the hole dekk an leave it with that.
am starting at the rear end , working my way to the bow .
the planks wil have a curve its going to be alot of edge bending here, i hope it wil work out in the end😊
Link to comment
  • 5 months later...
more update..... i finish painting the brigde and also started to prime the funnel and vents,
i still desiding wat color to use.... is goi g to be black or some sort of orange (funnel and ventes)
may not be the right colors but i do have no info on this and all the orginal photos is black and wite...
so dont put me in yale..... 😉
svein erik
Link to comment
  • 2 months later...
  • 6 months later...
Hi again... its been a wile since some update ,
i have painted the hull fore the last time 😉 and almost finished all the parts on the funnel, am workingr on the fire buckets,
install the drains on the rear deck house , the propeller and shafts are install , most of the parts are not glued yet..
svein erik
Link to comment
Prop support frames can be very tricky with all those compound angles to negotiate but you pulled it off rather well. The hull plating also looks very good. Well done.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
thanks for all the coments and likes☺
am working farword to the end... lol, ok i do have alot to do befor its finished.
The ships name is General. samuel M. Mills. 1909. later named ( Pequot)
so this is the us coast guard (mine laying) ship .
svein.erik
Link to comment
Coming along very nicely and very clean work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Hi, and thanks for likes and coments...
so its near holidays for me, so i did some more work on the mine davidts at the fore dekk.
i have to make some shacles and hooks and some blocks.
in the photos i used single block,  there wil be new ones here (pulleys)
i also made a mine from the year 1900 + (i did try to make it 😉)
svein.erik
Link to comment
The hull is looking rather fine, particularly the plating details. A bit of scale indication on the shackles, blocks and hooks would be helpful. Including a match or something similar might be useful.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
yes keith its to big , am working on it.
i made a new ones , 1 shackle (4.5mm) 1 hook (5mm) thats the smalles i can make out of this wire (05mm)
the biggest shackle in photo is 6.5mm and the hook is 8 mm and to big for the model ☺
svein-erik
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
