mtbediz
HMS Pickle by mtbediz - 1:40
Great start mtbediz. The bulkheads and filler look solid as a rock. Can you tell us if you are using existing plans or your own drawing? And the scale?
Bruce
Share this post
Link to post
Share on other sites
7 hours ago, G.L. said:
Is looking very nice.
What is the wood you are using for the planking?
Thank you GL. It is lime tree.
Edited by mtbediz
Share this post
Link to post
Will you take out the mails of the planks afterwards?
No, I will not take out the nails. Normally lower hull of Pickle (below water line) is covered with copper but i am planning to cover with mahogany veneer. Upper hull will be painted. So, nails will not be visible.
Share this post
Link to post
Really coming along nicely - like the lots of drop planks !
Are you sure your nails contain no iron if you are leaving them - othererwise may get some rust later in life.
I had a nasty surprise a while ago with some nails that I discovered were only brass coloured steel and th moisture from the next layer adhesive did them no good at all
Share this post
Link to post
Thank you. I have learnt one more thing, i didn't know this. I am not sure if they are pure brass. I will never leave nails on my next builds anymore.
Share this post
Link to post
I made the model carrier and I have started deck planking. I am using 1,5x6 mm of walnut strips on the deck. Because of long distance; I added extra plank supports between bulkheads 4-5, 5-6 and 6-7.
Edited by mtbediz
Share this post
Link to post
12 minutes ago, Edwardkenway said:
Great job, love the rivet jig.
I am following this build with interest.
Thanks
Thank you so much Edward.
Edited by mtbediz
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
