Endeavour J Class by cdrusn89 - FINISHED - Amati - 1/35 scale
Yves - I am trying to stick with the look as it might have been in the 1930s, so no carbon fiber, white canvas is what I am trying to portray.
Thanks,
Gary
Current Build -  HMS Sphinx 1775
Prior Builds:  HMS Winchelsea
                       USF Confederacy
Link to comment
Share on other sites
In preparation for rigging the running back stays (there are three sets of two) I made up the six tackles that connect the back stay to the hull. I made  two of the type on the left and four of the other. The two with a line to both sides of the block (which is barely visible - sorry) are for the after back stay where both ends belay to cleats and there is a single block at the back stay pendant. The other two sets of back stays have the block shown in the picture at the end of the pendant. That all went without difficulty.
The problem started when I tried to belay the aft back stay tackle to the indicated cleat. The cleats in question are the after most ones which are mounted outside of the deck "railing". It came free from the hull with very little effort. I had suspected this might be a problem, especially since the force on these cleats is mostly vertical given the way the rigging is configured per the provided drawings.  So I decided that I would replace, at a minimum the eight cleats that belay the back stays (the after most set has two cleats per back stay).
I took one of the cleats that came off and managed to drill a .040" (#60)  hole vertically through the more or less center of the cleat. I got a piece of .039 music wire to use as a pin through the cleat and drilled a #60 hole in the hull to hold the cleat. That example cleat is shown on the left in the picture below. I had so much fun doing that one that I decided to make new cleats with the hole from scratch. I needed seven so I decided to make a few extra in case I encounter this issue with some of the other cleats.
There will be a short intermission while I stain and varnish the crop of new cleats.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
While waiting for the varnish on the new cleats to dry I started to get the back stays rigged (as far as possible) without having a place to belay them. This involves getting the pendants to the correct length and rigging the tackles through the appropriate block.
Here are the after back stays with the tackle terminated with a clamp suspended over the side to provide a little tension. The bits of blue tape mark the cleats that need to be replaced.
Thanks,
Gary
                       USF Confederacy
Link to comment
After looking at the aft back stay design awhile I decided that having the bitter end of the aft tackle going more or less directly down to the deck edge cleat was not how I wanted to do things. It is much better (IMHO) to have the line going to a cleat such as used here to approach the cleat from more or less the same level as the cleat - i.e. pulling on the cleat in the horizontal plane instead of the vertical. To facilitate this I replaced the aft single block with a double (which I luckily had in my collect of brass blocks).
As you can see in the photo below the line comes off the becket, around the deck block, around the becket block, around the deck block again and then forward to the cleat.
I am considering changes to the other back stay tackles so they also approach the cleats from deck level not above.
Thanks,
Gary
                       USF Confederacy
Link to comment
All progressing very well Gary - and you productivity continues to amaze.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Keith - when retired and with a cooperative headquarters you can move pretty quickly. I am hearing noises about starting Christmas decorations so I am seizing every opportunity before that evolution begins in earnest.
Thanks,
Gary
                       USF Confederacy
Link to comment
Before replacing the cleats I decided to true up the shrouds.
Used the laser level to get both the model level (side to side) and the mast straight.
I used small pieces of wood to wedge the mast in position while I crimped the tubes to freeze the shrouds to the turnbuckles. Then I carefully removed the wood wedges and adjusted the turnbuckles to keep the mast straight. it did not take much more than a turn or two of the turnbuckles to hold things steady. Hopefully doing the for/aft adjustments will not throw this off.
Thanks,
Gary
                       USF Confederacy
Link to comment
With the mast stabilized (side to side) and the new cleats installed and the epoxy set I went and rigged the three sets of back stays. I added new blocks to locations that the plans show as eyebolts to get the horizontal pull on the cleats that belay the two forward most set of back stays. I had previously replaced the single blocks on the deck with doubles at the after back stay to accomplish the same purpose.
Here are the three sets of back stays as adjusted. I have not yet decided how to handle the excess line and in some cases the lines are  not completely belayed (around the cleat and over  the side with a weight since I will likely have to adjust some when I see the mast alignment.
Thanks,
Gary
                       USF Confederacy
Link to comment
With the back stays in place I used the laser level to check the mast alignment for and aft.
I adjusted the model in the cradle to get the laser and water line matched up as hopefully this means that the hull in "level" at least locally. Then I moved the cradle around on the workbench to get the vertical line in the center of the mast at deck level.
Then I checked where the laser falls on the mast as it goes up.
The laser line is off the mast forward just above the second spreader and at the top looks to be about 8mm (aka 5/16") forward of the mast. This equates to just short of a foot at full scale (5/16 x 35 = 175/16 = 10.9" ~ 1 foot since I am not sure how accurate my measurement was).
There is nothing in the instructions about mast rake but I would assume there was probably some. Looking at the full scale sail plan and assuming that the hull is shown "level" (the entire hull length is not shown on this drawing but the deck clearly rises toward the forward end so...) and that the borders are perpendicular to the hull waterline shows about 1 3/4" inches of rack/bend to the mast. I think I will stick with 5/16". Given the amount of clearance between the mast and the deck opening aft I do not think I can get much more rack and I do not want to stress the fore/back stays to get more bend than is there already. With the sails on her I do not think anyone will take too much notice of the mast as long as it does not bend forward.
Thanks,
Gary
                       USF Confederacy
Link to comment
With the hull complete except for the boom I turned my attention to the sails.
I had previously taken the sail plan (which is at half scale) had it scanned in and enlarged to make it full scale. I wanted to see how the sails would fit on my model since it is certainly possible that I had mis-measured or tolerances had worked against me and the sails would be too small or large if I just took the drawing as gospel.
I cut the main sail out from m y "full-size" sail plan and glued it to a piece of cardboard. I fitted a shackle and halyard to the head and, being careful to route it between all the stays " ran it up to the masthead. Good thing I bothered  - I guess the scaling job at Fed-Ex Office was not as accurate as you might like. As you can see in the picture below, the main sail is about 3" short of what it should be. Not surprisingly it is also about half an inch short at the foot.
I am going to take Sheet 5 (that shows the sails on the boat) to Fed-Ex Office and get several full size copies made so I can get templates for the "real sails" made. It will be easy to verify that the copies are the correct size - just lay them on top of the original.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
While messing around with the sail templates I also fitted the three frames I made with cloth and 50/50 white glue (Elmer's Glue-All) and water to both sides (letting the first side dry before coating the other side) of the three sail frames. I also did a small section as a "test pattern". I had to set the frames on the floor to dry as I was afraid if they were not flat they might dry with funny ripples in them. Had to be careful where I stepped and kept the dog out of the workshop.
My girlfriend is a pretty handy seamstress (she has about half a dozen quilts in various stages of construction) and she wanted to she what she could do to help. So I took my test piece and a length of .025 Syren tan line that had been coated with white glue and hung to dry and got her to stitch the line into a 3/8" (more or less) seam to approximate a bolt rope for the foot and luff of the main sail. She decided to use red thread to make it easier to see where the stitches went.
My next test is to use a pencil to mark the seams in the sail to see how that works. I am pretty sure she could sew them into the sails but I fear it would cause too much puckering (I have seen some pretty ugly examples of this) so I want to try the easy way out first.
Thanks,
Gary
                       USF Confederacy
Link to comment
Here is the redone main sail template laid on the fabric still in the frame. I got lucky. I made the frames based on the erroneous dimensions taken from the enlarged sail plan but I added enough "fudge" that the required dimensions fit, just.
I decided to use metal wire (Beadalon silver) for the main halyard with .018 Syren tan "grafted" on the end to go around the winch I added on the mast. Hopefully my "graft" is strong enough to hold, but there should not be a great deal of tension as the mail sail is attached to the mast at 31 eyebolts.
I ordered 1.5mm eyelets and (hopefully) the tool to set them from Amazon - due here tomorrow in theory. The sewing machine will make eyelets also so we will see what looks best and takes the least effort. A 1.5mm (.06") hole would be about 2" at scale which seems large but is the smallest eyelet I could find and about as small as the sewing machine will do so..... I planned on putting eyelets in the mainsail opposite the eyebolts on the mast and then using "small stuff" between the eyelet and eyebolt. I have yet to figure out how to get that done amongst the back stays but it can't be worse that the running rigging on Niagara and I survived that. Similarly for the jibs, eyebolts in the sail and split rings to serve as jib "hanks". I am considering making my own jib hanks out on annealed steel wire but I have not tried that at this scale before and even when I did they just sat at the base of the fore stay, no sails on that model.
And here is a shot of Endeavour with as much of the background clutter removed as I could accomplish quickly.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
Working the jib as the first sail. Sort of a "test case".
When I added the reinforcement strips at the leach, foot and one in the middle, i used the 50/50 glue water mix again with the sail on a piece of parchment paper to keep from gluing it to the table. That worked "okay" but there were a couple of places on the leech where the reinforcement strip did not stick (or I didn't get it in down exactly correctly. Anyway when the sail dried I noticed "watermarks" around the reinforcements. After the bolt rope was sewn into the sail I coated the entire sail with 50/50 glue/water to try and remove the watermark. The jib is hanging up to dry while I work on the flying jib.
Here are pictures of the jib hanging to dry and the bolt rope seam.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
Working the Flying Jib, then on to the Main sail.
Lesson learned from the Jib. Use gloves (cheapy nitrile exam gloves) when working with the fabric. Especially with the white sails - every bit of dirt around seems to find its way to my figures and then to the sail.
I cut the Flying Jib per the pattern that I validated for correct size on the model using a cutting board, ruler and cutting wheel from the quilt czar (aka girlfriend). I also cut two strips 3/8" wide to make the reinforcements from. The blue file folder I used to help see when I had the sail and the reinforcement lined up. I put a line of 50/50 glue water on the sail applied and aligned to strip and then put a line of 50/50 on the reinforcement strip. I smoothed things out trying to make sure there all air bubbles were removed.
The eyelet "kit" has also arrived and it looks like this is going to work.
The kit includes a punch to cut the hole and an anvil and tool to crush the sides down.
Here is my first try on my test strip. These will good in the seamed edge of all three sails - I counted 31 on the main, 28 on the jib and 35 on the flying jib. Good thing I got 125 eyelets in antique brass. I am not sure I can get the eyelets close enough to the sail edge to use the split rings provided in the kit plus I do not relish having to open and the successfully close 60+ split rings. I will see about making some jib hanks from annealed steel or maybe brass wire.
Thanks,
Gary
                       USF Confederacy
Link to comment
Having read some of the reviews of the eyelet "tools" and having had to take the anvil apart once already after only 4-5 test eyelets I ordered another set (they are less than $15 on Amazon) and a 2mm set as well since at least one person said the setting tools for the 2mm works better than the 1.5m tool on the 1.5mm eyelets. They all should be here tomorrow. In the mean time I have the reinforcements on the main and am waiting for the stiffened line for the bolt rope on the main and flying jib to harden so the "seamstress" (aka girl friend) and sew them into the seams.
Thanks,
Gary
                       USF Confederacy
Link to comment
Thanks for sharing your build, Gary.  You've made remarkably quick work on a not-so-easy model.  Mine is taking a bit longer than yours, by about 4 years. :rolleyes:
Nice work! :) Hope you don't mind me using your build to help me move along with mine.
Julie
First and only build: Endeavour - 1934 American's Cup, UK Challenger, J-Class - Amati 1:35
Link to comment
Julie - no problem; I have read your build log (and Kieth's) from end to end and picked up some good tips that helped me get this far. Good luck getting to the finish line.
Thanks,
Gary
                       USF Confederacy
Link to comment
So where are we now?
I have the jib completed - all the eyelets are there just manufacturing jib hanks to get it on the boat. So, at first I hung the jib from the halyard, made a few hanks and started to install them on the sail and stay. That didn't work out so well as getting the hanks (at least the ones I designed-more on this later) onto the sail proved to be more difficult than I expected. So I took the jib down and am putting the hanks, as I make them, on the sail. When I have them all done THEN I will hang the sail on the halyard and try and get the hanks on the stay, which should be much easier than getting them on the sail - at least I hope so. Here are pictures of the first attempt and where I am now, about 25% done with the hanks.
Thanks,
Gary
                       USF Confederacy
Link to comment
Making Jib Hanks
The instructions and material provided would use simple brass split rings (the ones with no overlap - just the two ends butted together) for the jibs hanks (and on the main as well). My experience with these is that I can never get the gap closed up again as well as it was when I started and thus keeping the split ring on the stay would likely be a continuing challenge. As I get three on one of the previous ones slips off, when I put that one back another slips off, etc. etc.
So I decided to make my own. I use 24 ga (.020: diameter) steel annealed wire (I think what I have came from Bluejackets) and the Micro Mark wire "bender" (see picture) on the middle (3/16") barrel.
I make a ring until the ends cross, then reverse the "bender" and complete the ring with the wire overlapping itself. I trim the end cutting at an angle close to the ring and end up with a 3/16" split ring with the ends overlapping about 25% of the circumference. This makes it more difficult to get onto the sail but much less likely to slip off the stay.
I apologize in advance for the pictures not being in the correct order (unless by some miracle they are).
Thanks,
Gary
                       USF Confederacy
Link to comment
As for the other sails, they are finished except for the seam marking (H hardness charcoal artist's pencil) and the eyelets. Speaking of eyelets, the cheapy Chinese eyelet installation hardware lasted through doing the jib eyelets but had to be repaired four times. The little pin that holds the eyelet keeps sticking inside the mandrel and without the pin returning (there is a spring in the mandrel that in theory would force the pin back out after the eyelet has been seated) you can't do another eyelet. It seems the metal on the head of the mandrel gets distorted and the pin hangs up. At the end I resorted to taking a file to the pin (which also gets distorted) to try and remove any burrs but still had to take it apart after every two or three eyelets. I have a new set coming today that hopefully (given what I know now) will last me through the flying jib and main but am considering ordering another just to be on the safe side.
Here are the two sails patiently waiting for attention. There is also a spare piece of sail cloth that is big enough to become the jib if something happens that makes me have to redo it. I decided to take one sail all the way through the process in case there are some lessons to be learned that can be applied to the others (like ordering additional eyelet hardware).
I also busied myself during football on Monday making rope coils. Here they are dry and ready for removal from the double sided tape that holds the coil while the 50/50 glue/water dries. The other things in the picture are used to weigh down some of the coils while they dry to keep them from becoming "dished".
Thanks,
Gary
                       USF Confederacy
Link to comment
Jib is up!
But it doesn't look as good as I had hoped. First mistake I think is that I should have ironed it one more time just before I threaded it on the stay. The other mistake I think is I should have put the jib on a new wire and re-rigged the stay with the jib threaded on - that would make handling the jib, which is bound to put wrinkles and potentially other damage at a minimum. That and two of the eyelets came out of the fabric while I was threading the hank on the stay.
Reconsidering my next move, possibly cutting the stay to get the jib down, ironing, replacing the eyelets that pulled out and then replacing the stay with the jib already threaded on. Also thinking maybe redoing the hanks using brass wire instead of the annealed steel. In spite of wearing exam gloves while handling the hanks I think the sail got dirtier from the annealed wire which is not the cleanest stuff to deal with. Making hanks is pretty easy now that I have "the system" down.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
I have decided to delay any rework of the jib and shift attention to the main. I need to get it on the boom and the boom on the mast to establish where, exactly, the eyebolts on the mast would fall on the sail so the eyelets are in the right place. I had been considering using brass for the main eyelets anyway and using white line to link the eyelet and eyebolt instead on a brass split ring as my experience with the jib shows that can lead to excessive handling of the sail. Not sure rope would be easier/less handling but I will at least try that for a few to see how it goes (and looks).
Thanks,
Gary
                       USF Confederacy
Link to comment
Two discoveries today.
First the hardware from China for cutting holes and seating the eyelets leaves a residue on your hands/gloves which eventually ends up,on the sail, especially in and around the eyelet where you have to maneuver the fabric over the eyelet blank. This was quite evident with the jib so I covered the hardware with masking tape (blue painters) to try and eliminate/reduce the a=mount of dirt getting on the sail.
Second, there is a similar residue that comes with the annealed steel wire. So I am shifting to brass wire for the split rings on the jibs. For the main I am still leaning toward using line - probably Bluejackets white .010 (of which I have several spools). I want to use white (rather than tan) so it does not stand out against the white sail. I need to try a test somehow.
I managed to get all the eyelets on the main (31 of them) without a single episode of the guide pin sticking. Not sure why I had such problems using the antique brass eyelets, maybe it is different material. Anyway the main eyelets are done. I hoisted the main to mark where the eyelets had to go to match up with the eyebolts in the mast - see picture below. Looked pretty good.  Not sure how the boom will sit with the sail secured but I really can't control that much so probably best to not worry.
Now to sail seams. On the jib I used a pencil. On my model of Benjamin Latham I used 1/32" (or maybe 1/16") masking tape to simulate the seams in the sails. The sails (main and fore sail only) were made from silkspan (essentially tissue paper) and the sails were furred on the booms so not much of the seams showed and the sails had been colored closer to the color of the masking tape. I bought a roll of spinnaker mending tape colored blue to use to put the sail numbers on the sail and though it might be possible to cut thin (maybe 1/8" which would be a little over 4" (4.3 to be close to exact)) strips of the spinnaker tape (in white) to use to simulate the seams in the sail. From the back side all you see is the shadow. Not sure how it would look on the front side. I have some spare sail material (already coated with glue/water) I will have to do another experiment. My fear is that over time the adhesive would pull away from the sail material and it would look terrible. I have no idea how sticky (or long lasting) the adhesive in the spinnaker tape might be. You would think it would b e pretty sticky since it has to stand up to a pretty unforgiving environment and customers who are not known for being of a forgiving nature.
Anyway here is the boat with the main and jib in place (more or less) and two shots of the main with the eyelets in plac e.
Thanks,
Gary
                       USF Confederacy
Link to comment
So here is my test of attaching the main using line and split ring.
Both that a good bit of maneuvering the sail around. Can't iron again after this - it is "done".
Still on the fence about how to proceed.
Will sleep on it.
Edited by cdrusn89
Thanks,
Gary
                       USF Confederacy
Link to comment
I had to drive to Tampa and back to see a relative in the hospital so spent most of the day in the car (300 miles round trip). Decided to work on something "easy" this evening. Will tackle more sails tomorrow.
I can only find a few pictures of the 1934 Endeavour and none of them show the sail numbers in any detail. You can tell there is something at the top of the sail but not what. Kieth Aug's Endeavour (although portraying the 1989 version) used J/K4 as the sail number and I am going to follow his lead.
I cut the letters out of spinnaker repair tape (another Kieth Aug idea) and set them on the sail. I am thinking of ways (besides the adhesive that comes on the tape) to get these attached - I have a fabric roller coming so I am pretty sure I can get them on the fabric correctly. Am considering trying a glue/water mix or matte medium but will  not do anything without an experiment. I am assuming that the numbers go on both sides of the sail but not directly opposite - one set is above or below the other on the opposite side. I am cutting another set out now (and maybe a third i9n case I screw on up getting it on the sail.
Thanks,
Gary
                       USF Confederacy
Link to comment
Gary - my Endeavour was completed about 4 years ago - no separation whatsoever.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Gary - have a look at https://www.jclassyachts.com/yachts. The official site of the J Class Association. You can see Endeavour is JK4. Although I accept that this isn't proof that it had the same number in 1934.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Gary - I think this confirms it:-
1594142339_Screenshot2019-11-16at21_19_53.thumb.png.caa68f0945a6ddbafa0c57c8da880e0b.png
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thanks Keith - I decided to go with the penciled seams. Cutting about 100 1/8" stripes of spinnaker tape (and then getting them on straight) seemed "a bridge too far". And J/K4 it is.
Main Sail is "finished". I just glued the battens on so that is why it is not onboard already. I used .010" X 1/4" Evergreen Strips for the battens. Based on the drawing they should be more like 5/16" but Evergreen only makes the really thin stuff max 1/4" width so that is what I used. What's a 1/16" (2.2 inches at scale) among friends. I used the fabric roller in the picture to try and make sure the numbers are firmly attached to the sail. To make the numbers I taped the template (in the picture also) to a piece of spinnaker tape which was also taped down and then using a brand new #11 Xacto blade and metal ruler I cut through the tape and backing. The hardest part was the curve on the "J". At close range it is still somewhat jagged. I am not sure the numbers are exactly where they supposed to be but they are close based on the limited pictures of the 1934 version I have been able to find.
Will mount the main (and boom) tomorrow and begin to address the 30 attachment points.
Edited by cdrusn89
add picture
Thanks,
Gary
                       USF Confederacy
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
