BETAQDAVE
electrical wiring for cooling fan
    I have a pair of small cooling fans from Radio Shack that have two wires for hook up.  Both wires are the same with no stripe or raised rib on the vinyl insulating cover, so I have no idea which wire is neutral.  If the wires are hooked up wrong, will the fan run in the opposite direction or does it mater?
Share this post
Link to post
Share on other sites
if the rotation of the fan blades is reversed, you may not have the desired air ejected forward at 100%..
Most fans have reverse polarity protection. If you hook it up the wrong way it simply does nothing. (we're talking about cooling PC fans?)
Edited by Captain Poison
Share this post
Link to post
Do you have any numbers on them?
When you speak of neutral,  I'm thinking AC ...  Are they in fact AC with only two wires?   If so, polarity is not an issue.
If they are DC, polarity and how high your voltage is will matter..  Pretty much what Captain P said...
Share this post
Link to post
This is a photo of the now defunct Radio Shack fans being employed for my spray paint booth.
    As you can see here this is an AC powered fan with just two leads that are identical.  Dispite the ends of the wires appearing to be aluminum they are, in fact, just braided copper wire with soldered ends.  The motor is sealed so I can't open it up to see how it is hooked up, so I don't have a clue which wire is which.  I really didn't want to go through all the work of wiring it up only to find out that I had them reversed and have to redo it.  At least the fan housing is marked with an arrow to show which way the fan needs to be mounted, but there were no instructions included with the fans.  I had even scoured the internet for more info, but alas the only info was where I could buy another one. :o
    So, thanks guys for the info.  Sounds like I shouldn't have a problem.
Share this post
Link to post
It's AC. 115VAC (alternating current) it won't matter which wire is connected to the active or neutral. It will always turn in the same direction. You have to turn the fan around to get the direction of flow you want. There may be an arrow on the side indicating the direction of flow.
Share this post
Link to post
alpayed is correct. There is no "polarity" with AC fans. The arrow shows which way the air flows.
In the US house AC wiring is polarized (white, black, green) because some electronics need to be wired a certain way. Motors do not. Just connect the two fan wires to the two "hot" wires from the plug. Don't connect to the green grounding/earthing wire!
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
