Wooden box by Wiktor.L - FINISHED
Wiktor.L
Hi.
Some times ago i try to make a wood casket, here are the effect...
Regards.
End: Bryg corsair occre, Black Pearl Hachette, Scottish maid artesania, BKA 1125
In build: Vasa deagostini, Dwunastu Apostołów deagostini, Hms FLY amati Novik modelik, spitfire airfix,
Wait for build: hms alert shipyard, orp kujawiak wak, hms Beagle occre, thermopyle revell, few JSC models,
Link to comment
Share on other sites
And my try to make glass-case for souvenirs, and in the future maybe for the ship models.... Its my 1st time to make electric circuit....
Regards.
Link to comment
Trying to make work table
Regards.
Link to comment
Frame....
Regards.
Link to comment
have you run the top through a planer to even it out,  or are you just going to sand it?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
All wood i cut manullay. there for the innacuracies. they will disapeer under the belt grinder.
Regards.
Link to comment
when i built my work table I joined the planks vertically together. It made the top 'thick' but gave it a lot of strength that I think it looses by joining width ways. Here are some quick shots (you#ll have to forgive the mess as as I am obviously mid model)
So front view showing size
Side view to show how the table top planks join together
And finally how the base structure works (this is actually similar to your approach I think)
It is very heavy but will not move anywhere and if the table top gets cut up then I can always re-plane and varnish and it would still be huge...
Link to comment
This my 1st project that type. Next can be better. But that table i made for heavier work than making models :) I wanted to avoid buckling the countertop... In the previous Bought  tables are twisted....
By the way i glue counter top to legs. This need onlky grind, and look corrects. And after i try to make a drawer and the shelf for tools...
Regards.
Link to comment
the last picture is interesting.......I'd be proud of the table.   most I've done of late is hang a picture ;)   nice table as well Matrim.........that top certainly won't buckle ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Main workbench is end. Was 2 shelf and a drawer.
And the his place in the workroom.
Regards.
Link to comment
Hi.
Drawel rail.
Regards.
Link to comment
Drawer is end.
I finished it with tung oil.
Edited by Wiktor.L
Regards.
Link to comment
Top shelf fot the table in progress,  lower shelf in progress, sides are done.
Closer to the end..
Regards.
Link to comment
I going to build a drum grinder.
Some missing this tool in workshop.
Yes, i know, wood is not the best option to make this type of tools, but for now i dont have a plywood...
In progress
Regards.
Link to comment
Table is end, but not yet :D
In the near future i make a stronger a countertop...( I glue beech on the "old" countertop)
Regards.
Link to comment
New version of drum and continuation the base
Regards.
Link to comment
Main piece of sander is done. There is the bearing and the new 10mm screw
Regards.
Link to comment
Continued.
I should end it in max 2 days.
For now everything is going accoridng to plan.
Regards.
Link to comment
hi.
Durum sander is end.
I finished the drum with roll, after it the sandpaper.
I m happy with the effect, it is not most beatiful, but it work, and this is the most important thing in this utensil type.
The biggest problem with it anchorage the sandpaper to drum....
Precision is very well. For pre-treatment pank to the model, where the harvest is small it can do it good. To set the table top precisely need a little time,  but it's worth?
I'll add to it the extraction soon.
Regards.
Link to comment
I started to make a glass-case to another "souvenir". Again a little different.
This is the beech wood, buckram.
I solder the leds parallel.
It is not sanded definitely.
Regards.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
