USS Essex by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC - as she appeared in February 1944
Was she painted an evenly blue, or did she had some camouflage patten on top of that blue coat?
[edit: forget my question: the answer is in your first post :) ]
On my screen the blue really pops out: is that because of a badly calibrated screen, or was this navy blue that kind of bright blue?
Jan
Edited by amateur
Link to comment
Share on other sites
A mighty steady hand there, very impressive work. Thanks for sharing your log.
Harley
Cheers, Harley<p
Under Construction:       USS Curtis Wilbur DDG-54 1/200 by ILoveKit
Completed:                     F-35A 1/48 by Tamiya
                                        USS Atlanta CL-51 1/350 by Very Fire
                                    Liberty Ship John W. Brown 1/350 by Trumpeter
                                    HMS Spiraea K-08 1/350
                                    USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                  USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                  USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                  USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                  USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                          Brig Syren 1/64 Model Shipways, Wood
Started,On Hold:     Frigate Confederacy 1/64 Model Shipways, Wood
Link to comment
Hi Greg,
I have been following your work.  I just completed the Lexington in 1/700. If I recall, only the Lex and Essex stayed in the overall MS21 sea blue.
I can say one thing, I really got to hate all that blue.  In 1/700, it was a bugger to keep track of all the small details until I started my washes.
I did notice in my research that along the starboard side, the paint seemed to fade to a flat finish that was a lighter shade.  This was probably due to all the direct sun exposure on all that surface area.  After weathering, I went in with a flat brush and added "touch up" areas to represent there areas may had been touched up while at sea.  Anything to break up all that blue.
Great work sir,
Scott
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Link to comment
Very very blue; I can experiment a bit to what I’m happy with. This photo, which I’m pretty sure is from 1943 shows a lighter blue grey on the gun shield  compared to the “sea blue” behind it. I’m thinking this will probable approximate what I’m after.
Edited by RGL
Greg
Link to comment
I like your thinking.  Blue is such a tricky color when trying to pull it off a photo. Who knows if its due to the Kodachrome, faded from the weather, or how it was mixed and applied.  You should go with what your eye tells you.   I used the Navy Measure color codes more as a guide than a rule.
I also built the Enterprise as she may had appeared at Midway.  Talk about trying to figure out the correct gray or blue.  It made my head about to explode.
But its fun to try to experiment with these colors in order to put life into the model.
Link to comment
Ditto!  Looks like shes been in the Pacific exposed to sun, salt,  and countless attempts to retouch and fight the rust by deck apes.
Link to comment
Looks like your looking into the real thing  - Excellent work Greg.👍
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Those interior shots of the hanger deck are so realistic yet at the same time haunting. She looks like even more of a ghost ship than the Graf Zeppelin did when you were building her. It is going to be amazing when you place the planes and possibly people in there to kill some of the echo!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Greg, you have truly captured the feel of the steel hull, the very being of the ship. A great job for us mere mortals to learn from.
Have a Merry and a Happy
Harley
Cheers, Harley<p
Link to comment
Amazing work  greg,   hope you and yours  have a lovely holiday  peace and health to you.
OC.
Current builds
Completed works.
Link to comment
catching up Greg...........can't believe tha amount of realism you've instilled :imNotWorthy:  ........ absolutely amazing!
have a very merry Christmas !
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Well I worked all over Christmas so I finally got some work done on the deck, the metal inserts for the deck joins, arrestor gear cables, elevator boundaries, tomorrow I’ll finish off the remaining 100 or so Tie down inserts and cable lifts and I can then mask and do the deck numbers. It’s a very blue deck which I will then have to weather which is a new learning experience but should be fun.
Edited by RGL
Greg
Link to comment
Awesome work Greg. Dry transfers and paint are the way to go!
Link to comment
The ships cranes; photo one is how they are supposed to look, 1E777F45-C078-4F37-B76E-231E8346654E.thumb.jpeg.34e9dfcb0905cd834c8dd559d70f65cd.jpeg
the kit ones, (see grey blob) actually come with a crank which I cut off and put on the Pontos replacement which is on the fret but no instructions whatsoever. I had to change one of the tackle as the pontos kit one went somewhere into space. B871C5DB-7DD7-42AD-A2D6-26A4659156B5.thumb.jpeg.edd21094b8bcedbf489014d80d0e12de.jpeg
finally the winch controls which I built out of spares E9889A3F-0852-43D2-BE5E-46D4D3C42D92.thumb.jpeg.f47cea8f27ee51ba96beb9a1432233ae.jpeg
Greg
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
