Kevin
What did you receive today?
On 10/10/2017 at 12:13 PM, Azzoun said:
A few days ago, I picked this up - Light ship duty is really interesting for me.  There is an excellent presentation on lightship duty on youtube.
I've always thought the light ships were nice looking ships. I'm looking forward to your build log.
Share this post
Link to post
Share on other sites
1 hour ago, Landlocked123 said:
Hi Azzoun,
I believe there were a number of iterations of the Nantucket Lightship.  Two summers ago (2015) I took the photos below in New Bedford, MA.  She's probably still there.
Best,
John
Cannot believe that piece of history is turning into the proverbial rust bucket.
Share this post
Link to post
Nice the cordless version, Ive got the wired one (Dremel 2000) you'll enjoy that flexible shaft. I changed the head so I do not need to switch those "grips" for every different size drill or other bit's shaft
Share this post
Link to post
Later you might want to add the Dremel Micro1850 cordless. I almost didn't purchase due to a built in battery. Love this tool I use more then my other Dremels and flex shaft. Holds a charge, I do pop it in the charger as I use it instead of laying it down. Extremely light and small cannot brag enough about its capablities of heavy duty cutting and sanding.
Share this post
Link to post
Received this gem two weeks ago, but forgot to post it...
The plan set is of an amazing quality, 32 sheets plus the book and jacket. If you want to built a beautiful ship in an rather big scale (1/36), then L' Amarante is definitely worth a look :)
And it comes with top notch customer service, I got it within 6 days after ordering.
Share this post
Link to post
 Definitely love the look of the ship.  User giampieroricci has a true masterpiece in the scratch build section.
Share this post
Link to post
Fellow member Pythagoras and I took a trip down to Model Expo and I picked up a couple of things. I really need to start a go fund me page a couple of weeks before my next trip down there.
The two kits are plank on frame life boats to replace the cast metal ones that came with my AL Bluenose which I will be putting on the work bench this week.
Share this post
Link to post
We recently moved so now I have moved my shipyard to a detached single garage. There is no ceiling though, no insulation and an up and over non insulated door. With the British weather very near, I looked into heating the place.
I got a couple of quotes to install a ceiling in the roof and they were around £2000. Adding a new door etc the cost would be very high. However, as I now can work for very short periods and rather infrequently, it does not make sense to go down this road. Better to just heat the place taking on the losses.
I thought of just getting many electric heaters but there is not enough power supply in the garage. So I got a Butane gas heater which should heat the place very quickly despite the lack of insulation.
With all the combustibles and chemicals though, precautions are needed. So I got a foam and a CO2 extinguisher, as well as a fire blanket.
Another concern is a possible oxygen depletion and CO poisoning. The heater has a low oxygen sensor and I got also a CO detector.
The heater is very good quality and Calor sells it as a package with a 15 Kg bottle for just £100 which is a very good deal. Excellent customer service as well. I think now even in low temperatures I could pop in and work my weekly one hour allowance!
Edited by vaddoc
Share this post
Link to post
Hi John,
You really seem to like the Dremei Micro.  I think I bought my Dremel when I was teenager, which definitely makes it a bona fife antique.  The bearing have finally started to go and I’ll need to replace it.  My biggest problem with the tool is that it is rediculously noisey.  How’s loud is the Micro.  Thanks.
best,
John
Share this post
Link to post
John,
Dremel micro is kind of noisy in my opinion and has a lot of vibrations.
This is my third as the previous two was under recall from Robert Bosch.
But otherwise it is a good machine,
Waiting for the day when they are coming out with a better one.
I also have a corded version that I  hardly use.
Edited by Nirvana
Share this post
Link to post
Are we talking about the same Dremel Micro? Model 8050? Mine is pretty quiet comparing to a corded version, and vibrations are pretty low. But I am not doing anything heavy though, using a corded version when I need power (aggressive sanding, for example). The mini version is perfect for light tasks where precision is important - drilling, cutting, light sanding. It is used 80% of the time, with corded version collecting dust. The battery capacity is impressive as well - I charge it roughly once per month.
Share this post
Link to post
After the last time my wife said no way am I using her hair dryer anymore for bending planks.  So instead of getting a nice little hair dryer I had to do the only logical thing and came home with this....
Uhhh it gets real hot.  Almost set my hand on fire trying it out :o
Share this post
Link to post
While working on the rigging for my Bluenose build, I've started prepping the workbench for the next build...restocking supplies, etc.  My MicroMark table saw died while making some jewelry displays for my wife, so she agreed to let me buy a Byrnes table saw to replace it.  Night and day difference from the MircroMark saw.  This thing feels solid and precise.  I went with the extended fence and a micro meter.
I also pulled the trigger on upgrading my mill.  I've been using a Proxxon MF70 for the last year.  I originally went with the Proxxon because I wasn't sure how much I'd use it, and I wanted to try doing a CNC conversion on it, so going with something less expensive made sense.  I've ended up using the mill a TON, so I took the plunge and upgraded to a Sherline 5410 with DRO (Package A).  The Sherline will be my general purpose manual mill, handling the bulk of the work, and the Proxxon will be converted to CNC for 'playing around'.  (I got the controllers and motors working last year for the Proxxon CNC conversion, but held off on mounting the motors to the mill because once you do, you can't manually control it with the hand wheels).
I wasn't going to get the Sherline for a few more months, but I was following Thistle17's thread about mills and couldn't help myself.  If my wife asks why I had to buy another mill now, I'm blaming Thistle17.  :)  Still need to pick up a rotary table for the mill...I was waiting to see if the rotary vise from my Proxxon would fit on the Sherline (it doesn't).
Both machines arrived within a day of each other, and I feel like my shop just took a major leap forward.   Now I just have to learn how to use the Sherline properly, figure out all the bits and pieces, and rework my 'wood shop in a closet' to have room for the new tools.
Share this post
Link to post
Kurt,
The t-slots on the Sherline are closer together than on the Proxxon, so I can only get one bolt in to secure the Proxxon's rotary vise (and I think I'd need two to ensure its square).  The Sherline only has two t-slots on the included table, so I could probably solve this with a tooling plate for the Sherline (which has 3 t-slots), but at this point I think I'd rather just invest in the Sherline rotary table and a tilting table since those are MUCH more versatile.
Share this post
Link to post
Our washer died a week ago, and we've been hunting for another (used) one. Yesterday my wife found a washer and dryer set that the couple was giving away free! Nice side load washer and dryer, with electronic controls.
They are presently sitting in the living room, as I have to remove part of the bathroom wall to get the old ones out. I'm going to replumb them to go into the adjacent hallway, which is wide enough to hold them and still get to the back bedroom.
Share this post
Link to post
The old washer and dryer had walls built around them leaving no means of removing them? First time I ever heard of that happening.
But all kidding aside, there was once a person in my town who gained so much weight that when they passed away up on the 2nd floor of where they lived, they had to remove part of the exterior wall and use a hydraulic lift to remove the body from the building.
Share this post
Link to post
Today I had a visit from the Amazon fairy.  In addition to some new Xuron needlenosed pliers, I got a bunch of very nice tweezers. They were unbelievably cheap at just over 10 bucks for seven pair. The fit and finish is excellent and now I just need to see how they hold up.
I also picked up 100 Swan-Morton no. 11 scalpel blades.  They came with handle, a plastic box that is somehow going help to removing blades and a pair of hemostats.  There were no instructions on how to install blades and everything I tried seemed to be too hard and clumsy.  All this was exacerbated by total fear that I was going to cut off a finger.  I would truly appreciate any help on how to use this thing.  Thanks.
Best.
John
Share this post
Link to post
I did a first aid call years back where we rigged a setup to get a patient out of an upper story apartment. It was pretty icy, so we didn't want to risk using the outdoor stairs while hauling a stretcher. One of our EMTs was a bos'n in the USN. The FD had all the ropes and blocks we needed.
Share this post
Link to post
Best.
John
Use those new needle nose pliers to hold the back corner of a new scalpel blade with the point of the blade pointed straight out in front of the pliers. Slide your scalpel blade handle into the slot in the blade and use the needle node pliers to pull the blade back until it locks into position. Whatever you do, do not use your hands to try and attach the blade to the handle. It's a sure way to have an accident.
Share this post
Link to post
Several years ago we remodeled. The house had originally been setup for the washer/dryer to be put in the hall, by the bathroom. Much to my, and our handyman's horror, the Admiral insisted that they go in the bathroom!! This left no room for the sink, in said bathroom, but she was adamant!
We had to replace some of the subfloor, so out came the wall, in went the equipment, and up went the wall. Now the sink is in the hallway! And everything had to be replumbed accordingly. I could, with a lot of work, get the stuff out, but I want the original setup. I also never taped the wall board, for just this case, so the removal of that wall section will not be too bad.
This time everything will revert to the original setup!
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
