Swallow 1779 by tlevine - FINISHED - 1:48 scale
That is part of the beauty of this craft (no pun intended).  There is always something more to learn.  My only regret is that the incorrect information will still be out there  for someone else to take at face value.
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
Share on other sites
Hi Toni -
It's always a delicate matter to raise what may (or may not) be a mistake by another modeler.  I usually hold my tongue unless the issue can be resolved quickly and relatively easily.  I am glad that you had not gone too far before changing direction.  I'm also happy that the final solution will actually be easier than before.
Looking back, you may have been confused between the look of bolts and clench nails.  Both were used in the construction of lapstrake hulls.  The clench nails had broad heads, went through the planking, were fitted with roves on the inside and were hammered from both sides like a rivet.  Bolts went through more substantial timbers and had washers on both sides to prevent overtightening.  The final exterior look of a bolt fitted this way is very much like a clench nail with a rove on the outside.
As well as the articles mentioned by Druxey and Greg, you might look at a thin booklet called "Clenched Lap or Clinker" by Eric McKee and published by the National Maritime Museum in England.  I'm pretty sure it is available for not a lot of money.
Great work nonetheless.
Be well
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
Dan, never worry about pointing out an error.  The drawing in Goodwin's Alert is wrong...no confusion there.  Thanks for the reference.  I will try and get a copy.
Toni
Link to comment
It has been a while since the last post.  Putting all the bolts in the planks is a right royal pain in the you-know-where.  At this point I am half-way through one side.  Once the side is done, I will put up some photos.
Toni
Link to comment
2 hours ago, JJT said:
Sometimes I wonder what drives us to do this hobby 😆
Methinks its some form of mild insanity, Jeff.  Not bad enough to get you locked away or some heavy medication, but enough to build model ships.
Link to comment
Oh, we are all a little nuts.
Toni
Link to comment
My wife often refers to our ship-building hobby as a beautiful madness.
Speaking of madness, Toni, I hope you aren't going to go to the trouble of installing roves on the inboard (invisible) surface of the hull!
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
Link to comment
You could make a little bucking iron to hold on the outboard surface of the rivet, then use a tiny hammer to peen over the inboard end of the rivet...
JD
Link to comment
Bite your tongue, JD.  Maybe next time.  🤔
Toni
Link to comment
Maybe Gus would loan you his trained rigging fleas to hold the buck for riveting.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
I have finally finished installing the rivets on the port side.  As these would have been hand forged, I used square copper wire fit into a size 77 hole.  After all the wires were inserted, the hull looked like a porcupine on a bad hair day.  In the photos, I have started to flatten the heads using a flat file and rotary sanding disc on the Dremel.  Once all the heads were flattened, I finished up with 400 grit sandpaper.
Once the sanding and filing was completed, I put a coat of Watco's on the finished side.  After both sides are completed I will add a second coat and then paint the wale.  Over time, as the pear darkens, there will be more of a contrast between the castello above the wale and the hull below.
Toni
Link to comment
Monumental work on a clinker hull where you can't just smoothen everything with a gentle swipe of a sandpaper.. :) Amazing!
Link to comment
Lovely work Toni. Those fashion pieces came out well and are probably trickier in a clinker planked hull.
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Thanks for looking in everyone.  Yes, Greg, those fashion pieces gave me fits.  As I recall, I made them four times.  Hopefully the starboard side won't take as long!
Toni
Link to comment
The coppering on the starboard side is now finished.  You can see the difference between the port side with a finish applied and the starboard with none.  I have decided to delay applying the finish until the wale has been redone.
While doing research for another project, I discovered that the coamings were built several inches too short (8 inches instead of 13).  You can see the difference in the picture below.  Time to rebuild them all.
Toni
Link to comment
Sometimes things look better in photographs; the fastenings look better in real life.  I was afraid it would be garish looking but the bolts are scale size (#77 drill bit) and so blend in nicely with the planking.
Toni
Link to comment
Hi Tony, What a journey so far! My goodness all the redo s, but as you have discovered sometimes it takes a lot of solid determination to get things right after following a wrong path. What a beautiful job on a difficult task regarding the hull planking.
Michael
Link to comment
Superb work on this clinker planking. What a beautiful hull.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
  • 2 months later...
I cannot believe it has been over three months since I posted on Swallow.  I promise you, I have been busy on her and a few other things.  Take a peek at the Capstan Project.  Also, I was unhappy with the appearance of the upper planking.  It has all been removed and rebuilt.  Trunneling has started and pictures will be forthcoming soon.
Toni
Link to comment
As mentioned earlier, I built the hatch coamings too short.  These have all been remade and the gratings installed.  I will not glue the gratin down over the hatches to allow one to see the lower deck.  The steam vent (in front of the fore hatch) is glued down.  In the middle photo you can appreciate the height difference.
1999645337_Deckwithgrating041121-3a.thumb.jpg.7b73f4019239660b851870b7f6feb85c.jpg2005717952_Deckwithgrating041121-2a.thumb.jpg.fd714b6fa7401b80e327db7265874805.jpg748467494_Deckwithgrating041121-1a.thumb.jpg.9d01d306ea1c8c423b91722785e546d1.jpg
At this point I noticed a problem.  Even though the holly I use is several years old, a crack started to develop between the main hatch and the ladderway.  Part of the problem was insufficient support for the deck because this was built plank on bulkhead without a subdeck.  I gave the deck more support by installing a "beam" just aft of the main mast.  This was accomplished by inserting the wood through the ladderway and holding is secure until dry.  I could not get a clamp with a deep enough throat to fit through the opening.  That part of the deck was resanded and the result is seen in the second picture.  Big improvement.
Toni
Link to comment
I was unhappy with the appearance of the upper hull planking.  As was pointed out to me by Druxey, the decorative strip would have been applied on top of the planking, not between the planks.  They were also too wide.  The next two pictures show the planking before the last row of hull planking was installed.
1988584568_Almostthere5a.jpg.1727c23bdd8cfdd8a0f9419b6a113508.jpg885418513_Almostthere1a.thumb.jpg.bb33ce67197c852f7600b24528deb734.jpg
I removed all of the upper planking and the decorative molding.  Instead of four rows of planking, there are five.  Much better.1694204882_Replacetopworks1a.thumb.jpg.3f07eae5513158f14d30dbe97101721b.jpg1265036212_Replacetopworks2a.thumb.jpg.85ce422d67b24bf1e84d417a446c0c2b.jpg
The bowsprit step and riding bits were made next.  The bowsprit is offset on this ship, which is why the step is to the port-side of midline.  The size and location of the riding bitt was taken from the plan.  The primary wood is castello and the aft strip is pear for contrast.  Nothing will be glued down until all of the exterior work is completed.
1684929122_Bowspritstep2a.thumb.jpg.1797e168657c835d89592f6b82e82f17.jpg1744442261_Ridingbitt1a.thumb.jpg.896cbe688b1042cc1c2289afcfb5ec3f.jpg2081227724_Ridingbitt2a.thumb.jpg.4c9a8ef9e1e04ed8e5863b58fa044eb4.jpg
Toni
Link to comment
just so very nice
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
